  1. Sep 8, 2021 at 7:22 AM
    For lifted trucks, it corrects the length of the sway bar end link to match the lift. Prevents premature wear of the bushings.
  2. Sep 8, 2021 at 7:27 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    In addition to what @KNABORES said, if you wheel hard with the stock sway bar links on a lifted truck, you will likely snap them eventually. I snapped both of my OEMs, then tried two different auto parts store brands, snapping one of each. The extra two inches of length on my links prevent the suspension from binding as much as well and they've held up very well.
    Filthyphil, oscardog86 and KNABORES like this.
  3. Sep 8, 2021 at 8:05 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Just to add on to what was mentioned above the overland custom designs links are 1 inch longer than stock and can be adjusted further if need be. Right now mine are adjusted all the way down. They were pricey but are completely re-buildable. And I’m a big fan of overkill lol
    Filthyphil, oscardog86 and des2mtn like this.
  4. Sep 8, 2021 at 5:31 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    I greased my frame liberally last summer with moly EP after soaking with PB. Been hitting some other areas underneath with some Skyco Ospho recently on the Sienna and truck. Will be pressure washing then spraying some cosmoline RP 342 on both before winter.
    bmf4069 likes this.
  5. Sep 8, 2021 at 8:07 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Tundra on call51D5EEDE-C824-44C8-8E95-E067B432EE29.jpgnice night out, backed up condensate drain in the basement Rec room, made a good mess, blew the line with the whipit cartridges.
    plumbers should have fun tomorrow, the floor sink the condensate spits into is backed up going to the injector pumps:) my bet is they will say it’s a dry well and just let it overflow and say it’s Hvacs problem because it’s our condensate water hahah
    oh and the attire for the night was shorter white sun dress type things, saw about 40 deep walking
    Darkness, bmf4069, Lil Steve and 3 others like this.
  6. Sep 8, 2021 at 8:37 PM
    Casper421
    In the woods
    06 DC
    Pics or it didn’t happen!!
  7. Sep 8, 2021 at 8:42 PM
    FrenchToasty
    Mo
    Bone stock
    Haha my flash went off taking the truck pic, I would been mean mugged so hard if I took a pic of the gaggle. Some of the faces we see when we look at them is great. Put some shorts on haha
  8. Sep 8, 2021 at 9:22 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Finished install of interior and bedlight LED's today. Bought good quality LED's from Superbrightleds. Thing I noticed that I hadn't really given much thought before is that any time any LED's are on my remote door lock/unlock doesn't work. Usually this isn't an issue as all the lights are off when the doors are closed but since the bedlights take about 8 to 10 seconds to turn off I can't lock the truck till they do. For now I just put incandescent bulbs back in because I'd rather have the remote. Not sure if anyone has ever ran into this issue. (Factory RS-(insert number here) style security system and remote with security led and glass break mic on left of steering column)
    May try out some different brand LED's for bed lights like sylvania as @Tundra2 stated he has no issues with his remote with those installed.
    daveeasa likes this.
  9. Sep 8, 2021 at 10:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  10. Sep 8, 2021 at 10:51 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Changed the title of the RCLB with inspiration from @shifty`
    shifty`, NWPirate and bmf4069 like this.
  11. Sep 8, 2021 at 11:22 PM
    NickB_01TRD
    Nick
    KY
    Ah yes. We talked about a few different brands earlier. Yeah $50 for some light bulbs is a bit much. I might try out a sylvania equivalent at some point. Just want to try and keep from melting this housing anymore really.
    KK6PD likes this.
  12. Sep 9, 2021 at 12:03 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes. I definitely would not have paid that for two bulbs. I've got much better uses for my money. Pinky nail is longer than the rest for a reason...
    shifty` likes this.
  13. Sep 9, 2021 at 5:19 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    So only one of my driverside washer fluid thingies is spraying and it's a weak stream, while the passenger side is fine. This is a new development this week. They were both working fine before. Any suggestions on how to fix this?
  14. Sep 9, 2021 at 5:30 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    A)Make sure the hose hasn't come partially loose(unlikely). B) make sure the hole isn't clogged. You can try using a tooth pick or something smaller. c) upgrade to the FJ Cruiser squirters.
    bmf4069, Lil Steve, RUSTYNUTS and 2 others like this.
  15. Sep 9, 2021 at 6:07 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    Thanks
    Edit:
    So what makes the FJ squirters special?
  16. Sep 9, 2021 at 6:25 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I don't know about yours, but my original squirters only put out a stream, not a spray. So when I try to clean the windshiled it only soaks a tiny area. The FJ cruiser nozzles send out a spray.
    https://www.tundras.com/threads/windshield-washer-nozzles.85304/
  17. Sep 9, 2021 at 9:04 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Cant keep my emergency funnel here.
    catches water. 1qt bottle doesnt seem to be the right size.
    jerryallday likes this.
  18. Sep 9, 2021 at 1:39 PM
    Brewer50
    Brewer50 New Member
    Bend
    2006 Tundra DC SR5
    JBA LT headers, Dirty Deeds full race exhaust, 12 hole injectors, K&N modified stock box, Roar Pedal controller, leveled with Belstien 5100, Sumo Springs, Helwig rear sway bar, 20" 4Runner limited wheels w/ Fallen snowpeaks, have everything ready to do electric fan conversion. Wanting a tune but DAP is busy! So if anyone has info on anyone that knows how to tune these first gens, pass it along. It can be done, requires a pig back ECU.
  19. Sep 9, 2021 at 1:41 PM
    Good luck with the tune, not sure there's much to be gained there. I would skip the electric fan conversion. Especially if your towing. Truck looks awesome. Love those wheels on there.
  20. Sep 9, 2021 at 1:46 PM
    Brewer50
    Brewer50 New Member
    Bend
    2006 Tundra DC SR5
    Thanks!
    DAP claims 19 top end and 22 low. More about bringing everything together and running with a more suited mapping. Could be right about the fan but I tinker and can always go back.
  21. Sep 9, 2021 at 1:57 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    @Brewer50 sweet set up! I have the same exact mods, except I'm running a AFE Stage 2 cold air intake and URD MAF Calibrator. I sent my spare ECU to R9K in PR for a reflash, they claim remapped fuel curves and removal of governor.
    FrenchToasty likes this.
  22. Sep 9, 2021 at 2:11 PM
    Brewer50
    Brewer50 New Member
    Bend
    2006 Tundra DC SR5
    @KingSequioa007 funny you bring up the URD MAF calibration unit. I'm currently trying to sell mine. Won't work with air pump delete kit. Never heard of anyone being able to tune 1st Gens, only with a piggy back. Anymore you could tell me about that. Noticable? Everything worked. Wasn't a remote tune?
  23. Sep 9, 2021 at 2:15 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Get a bright enough flash and you'll temporarily blind them long enough to escape unidentified.
    bmf4069 and FrenchToasty[QUOTED] like this.
  24. Sep 9, 2021 at 2:31 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    @Brewer50 works perfectly fine with my air pump delete kit. Had a tuner in Huntington Beach load a map onto the Calibrator and got decent pulls on the dyno with it. The reflashed ecu I sent R9K, I still haven't got back. As soon as I do I report what improvements it made or not made along with a 2nd dyno tune. With your 12 whole DD Injectors, did you do any aftermarket fuel pump upgrade? URD makes a nice kit for our trucks.
  25. Sep 9, 2021 at 2:45 PM
    Brewer50
    Brewer50 New Member
    Bend
    2006 Tundra DC SR5
    @KingSequioa007 that is very interesting that you did not get any codes. URD did make it sound like it doesn't always happen. Maybe I have a different problem, but only comes on with the calibrator. No pump upgrades. I did add them to a stock truck other than air box mod. It was very noticeable.
  26. Sep 9, 2021 at 3:22 PM
    Brewer50
    Brewer50 New Member
    Bend
    2006 Tundra DC SR5
    Same, can't tell much difference
  27. Sep 9, 2021 at 3:30 PM
    shifty` Inside his chest they found ten thousand pencils
    Noah way!
    RUSTYNUTS and FrenchToasty like this.
  28. Sep 9, 2021 at 3:34 PM
    Cummins3500
    Logan
    no issues with my diode dynamics bulbs but they get pricey quickly. Throwin another option out there for ya
  29. Sep 9, 2021 at 6:59 PM
    aknickyota22
    aknickyota22 New Member
    Durango, CO
    2005 Tundra Access Cab, 2001 Corolla "oil burner"
    Stock AF
    Just ordered new lower ball joints and bolts for my 2005 AC 4x4, but I'm confused on which bolts are correct. I ordered 90080-10066, but McGeorge Toyota emailed me saying the correct part number is 90105-12316. Anyone know which one is right?
    Cummins3500 likes this.
  30. Sep 9, 2021 at 7:14 PM
    Cummins3500
    Logan
    @aknickyota22 that 90080-10066 isn’t the correct ones. I did the same thing and ordered those and they were too small. Didn’t catch it till I had already pulled my old ones. I ended having to reuse the old bolts.
    I haven’t seen that other part number anywhere
    Dannydirtyfingers likes this.
