  1. Aug 9, 2021 at 9:28 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Just ordered mine this morning.
  2. Aug 9, 2021 at 11:29 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Install
    If you don’t have time to give any love to the neglected prerunner off yonder, I could take that burden off yer hands, give it a good home…… Just tryin to be helpful.
    oscardog86, Voss, Darkness and 4 others like this.
  3. Aug 10, 2021 at 12:51 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    WARNING: lengthy post
    About: mini projector LED’s.
    Quick backstory I’ve long been hunting for the brightest light I could get outta stock housings, but with a solid, clean cutoff, without doin the whole retrofit. I’ve tried an HID kit, several different LEDs (all bright but everywhere), and a handful of high watt halogens. Looking back at the time and money I spent, retrofit was probably the way to go. Oh well. I was actually pretty happy with the last set of halogens, Sylvania ZXR’s I believe, but they were like $65. Then I came across these.
    you can see how clean the cutoff is and they’re super bright. Low beam gets cut then goes thru the lens. High beam floods from stock housing reflector, also low stays on with high. Great lights but there are two cons I will share for anyone interested in these. 1- you have to remove the internal shield/reflector cap thingy from inside the housing, it’s just two little screws and yank it out with pliers. Not hard to do but once it’s done there’s no turning back to regular bulbs. 2- at the cutoff, there is a purple edge separating light from dark. If you zoom in on the pic where it says “real shot” you can kinda see it. It’s not obvious there, but when you’re driving, you see flashes of purple from anything reflective that’s above the cutoff line, which is just traffic signs and street signs really. The ad doesn’t mention it, nor did any of the reviews I read before buying them. They would be pretty much flawless otherwise, so I dissected one to see if it were possible to get rid of it. Unfortunately, it is within the polycarbonate lens itself. Stuck fukt. I’m not sure if other brands are the same, but it’s definitely something you want to look out for before buying. And if anyone knows or finds better, please share. Didn’t mean to make such a long post, but a wise man once said “if you can be anything, be efficient.”
    Voss, Lil Steve, Darkness and 2 others like this.
  4. Aug 10, 2021 at 4:53 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Voss, NUDRAT and bmf4069 like this.
  5. Aug 10, 2021 at 4:54 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Quit working nights. We need you here in the daytime.
  6. Aug 10, 2021 at 4:55 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Honestly, I heard something from supervisor last night that he'd heard. If it's true, I might just be on days soon, or in Knoxville.
    Why do you all need me here on days?
    Darkness and bmf4069[QUOTED] like this.
  7. Aug 10, 2021 at 4:57 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  8. Aug 10, 2021 at 4:58 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Aug 10, 2021 at 5:32 AM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    Can you grab a photo of the cutoff line on your setup? I had a slight hue even on my retrofits (for my old Tacoma) but it certainly wasn't something that caused issue or obstruction of view.
    RUSTYNUTS[QUOTED] and Darkness like this.
  10. Aug 10, 2021 at 5:44 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Here’s mine with the exact same setup. It should be noted that I have done some adjusting since then.
    Voss, NUDRAT, RUSTYNUTS and 2 others like this.
  11. Aug 10, 2021 at 6:14 AM
    alee891
    Now/here
    Shitbox
    Pretty wild that it has such a defined cutoff for not being a true retrofit. Thank you for the photo.
    RUSTYNUTS likes this.
  12. Aug 10, 2021 at 6:38 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    This is my first foray into projectors but from my understanding, they are just mini projectors, scaled down to fit on an H4 chassis. I have zero complaints so far other than now I need to color match my fogs.
  13. Aug 10, 2021 at 7:00 AM
    tacoguybill
    tacoguybill The Burrito Bandido
    Bill
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    @RUSTYNUTS these didn't mess with your fog lights at all? I did just order a set so now I'll have an excuse to wet sand and clear coat the "hazy eye"
  14. Aug 10, 2021 at 7:39 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Raben Tar had the truck about an hour for rotation, and alignment. Feels like everything is about right. I'll never understand what really is right with these as I'm lifted, and don't get alignments enough.
    Darkness likes this.
  15. Aug 10, 2021 at 10:38 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Crap cross caster. Got a pull?
  16. Aug 10, 2021 at 11:42 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
  17. Aug 10, 2021 at 11:43 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I did have to mod the foglight circuit with the first set of LED's that i installed, but it was just a simple jumper wire on the back of the switch. (button on dash, not on steering column) I ended up using my foglight circuit to power my lightbar, but that's irrelevant. Also, I tried alot of wet-sanding, buffing, polishing, clear-coating, and all that, and I was unable to get em crystal clear to where I was satisfied. Bought new housings for $110. well worth it to me
    tacoguybill[QUOTED] likes this.
  18. Aug 10, 2021 at 11:46 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I can see the purple in yours as well. It doesn't bother you at all?
  19. Aug 10, 2021 at 12:07 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I don't believe so. My understanding is that the mini projectors have an actual lens that 100% of the low beam passes thru, so 0% of it is reflected from the housing. That's how they're able to achieve such a clean cutoff. Also, those morimotos are for fogs, even tho they are H4's they don't have hi/lo beam.
  20. Aug 10, 2021 at 12:54 PM
    Strangebird22
    Strangebird22 New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    Over the last couple of weeks I have:
    Cleaned throttle body
    Polished headlights
    Replaced burnt out D bulb in cluster.
    Replaced rear brake shoes and hardware.
    Replaced parking brake bell cranks.(parking brake works for first time since I've owned it)
    Adjusted the LSPV.
    Upgraded front brakes to to the 13WL calipers and pads.
    Attemped to clean the caked on brake dust off wheels.(about 80% successful)
    Mostly all on the advise and help of the good people on this forum:bananadance:
    oscardog86, hammeron, NUDRAT and 6 others like this.
  21. Aug 10, 2021 at 1:26 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    there was a dude in CA trying to sell just the grill for about $750. I will see if its still up
    https://offerup.com/item/detail/817720920?q=ivan+stewart
  22. Aug 10, 2021 at 1:27 PM
    jImmegart
    Jonah
    California
    I remember you talking about this before, but what exactly is to gain? I know airaid still makes a full cold air intake kit, but you want just the pipe?
  23. Aug 10, 2021 at 2:15 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    Ooof
    jImmegart[QUOTED] likes this.
  24. Aug 10, 2021 at 2:35 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think I know that guy. I think that's a guy from TS from way back, he collected a lot of IS stuff.
  25. Aug 10, 2021 at 4:39 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Yeah, it’s not ideal. Don’t really like the attention it brings honestly. But not really worth spending the $$ to try another brand.
    RUSTYNUTS[QUOTED] likes this.
  26. Aug 10, 2021 at 4:59 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Smoother air intake “should” make a wee bit more power.
    but to be honest I just want the noise and cleaner looking engine bay by getting rid of the bug resonator on the intake. I run the MIT in the Tacoma and like it
    TRDGen and Darkness like this.
  27. Aug 10, 2021 at 5:00 PM
    empty_lord
    05 rollover special
  28. Aug 10, 2021 at 5:17 PM
    daveeasa
    David
    Please do not encourage me any more, I am tempted…
    oscardog86, TRDGen, jImmegart and 2 others like this.
  29. Aug 10, 2021 at 5:29 PM
    empty_lord
    05 rollover special
    I won’t say do it, but I won’t say don’t either
  30. Aug 10, 2021 at 5:29 PM
    empty_lord
    05 rollover special
    In other news, the intake shipped. Looks like e trailer actually had old stock. Schweet
    NUDRAT and abcinv like this.
