  1. Jul 30, 2021 at 11:56 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Welp, she's still not liking 100+ ambient temps.
    The temp rises about 1/8" from where it normally runs at after it sits at idle for a bit. It no longer keeps climbing though. So overall a success, just not staying as cool as I'd like.
    Darkness likes this.
  2. Jul 31, 2021 at 2:20 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    How's the condition of the belt? Is it slipping maybe?
  3. Jul 31, 2021 at 3:07 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Belt seems fine. I can just rev up to 1500rpms and temps drop back to 'normal'.
  4. Jul 31, 2021 at 3:19 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    Acrylic can be formed to curves with heat.
  5. Jul 31, 2021 at 4:14 AM
    Desert Dog
    Interesting. Sounds like the water pump and/or radiator then.
  6. Jul 31, 2021 at 5:11 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I ordered the fan clutch so I'm going to give that a shot. I get the same temperature creep at idle or occasionally in stop and go traffic. Like you said though, revving up to 1500rpms and getting air flow from the engine fan brings the temperature down to normal.
    Are you on your original radiator/ thermostat?
  7. Jul 31, 2021 at 5:35 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    jpink likes this.
  8. Jul 31, 2021 at 6:36 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    My coolant and transtemps get considerably higher when outside temp is 100+. Its interesting because 90* doesn't show any real rise.
  9. Jul 31, 2021 at 8:00 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    bmf4069[QUOTED] likes this.
  10. Jul 31, 2021 at 8:06 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    The best way to get tobacco smell out of your truck. Give it a few ozium spritzes a day for a few days when you're done driving. When you do drive, roll down the windows. Bam the smoke smell is gone in a few days.
    oscardog86 likes this.
  11. Jul 31, 2021 at 8:21 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    What happens in the garage stays in the garage. :anonymous:
    Alcolhol, big tools - best not to share.
    bmf4069 and Sirfive[QUOTED] like this.
  12. Jul 31, 2021 at 8:25 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Would be a certain awesomeness to a back glass in two part (plexiglass?) where the top 1/2 could be lowered to the outside of the lower 1/2 so you could have the top 1/2 open for venting & full value of magic back DC window. Would be good if you had dawgs back there too.
    A little panels overlap for water resistance. Guess you'd have a double track within the lifting backglass frame.
  13. Jul 31, 2021 at 8:29 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Do you rinse out the radiator? A lot of little crap gets caught up between the fins. I try to use the hose to clear out road grit with each truck warshing.
    But don't really get the heat here to know if I'm succeeding.
    Jack McCarthy and FrenchToasty like this.
  14. Jul 31, 2021 at 9:32 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    B*tch hates me.
    I felt a difference when merging from hwy A to hwy B. There was full use of 8cyls & a downshift happening when I felt 'a difference'....
    Heard a difference couple miles later when I was fortunately 3 blocks from home. Tried to be :anonymous: coming into my block.
    Dad has the red, I have the yellow & green. I went yellow for a change.
    Northern trucks, but new frame + fluid film = black goodness.
    I seem to have lost a hangar somewhere along the way & failed to notice until... too late.
    At least it's behind the muffler. Sounding throaty though. Need to check things out down under & see what's what.
    FrenchToasty and BubbaW like this.
  15. Jul 31, 2021 at 10:08 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    From experience the Walker stainless is about $200 and mounts right up.
    oscardog86 and NUDRAT[QUOTED] like this.
  16. Jul 31, 2021 at 11:05 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I installed a GPS speedometer, cuz my tires are big and OE speedo is false as a result. Has some cool features, I like it. https://www.amazon.com/dp/B07FNHGRZ9?ref=ppx_yo2_dt_b_product_details
    The sticky-pad you get with it didn't work well for me so I used adhesive Velcro. My phone is officially relieved of speedometer duty. Happy with this product.
    [​IMG]2021-07-31_11-51-42 by GhostCreekMine, on Flickr
    I used the cig plug next to the hash tray and routed the wire under the dash, pretty easy.
    [​IMG]2021-07-31_11-51-55 by GhostCreekMine, on Flickr
    Can change the brightness and colors of the different categories, speed, altitude, direction, etc
    [​IMG]2021-07-31_11-53-13 by GhostCreekMine, on Flickr
    [​IMG]2021-07-31_11-52-57 by GhostCreekMine, on Flickr
    I haven't tried the acceleration or braking tests yet but a pretty neat feature.
    [​IMG]2021-07-31_11-52-30 by GhostCreekMine, on Flickr
    [​IMG]2021-07-31_11-52-42 by GhostCreekMine, on Flickr
    [​IMG]2021-07-31_11-52-17 by GhostCreekMine, on Flickr
  17. Jul 31, 2021 at 11:32 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Not bad for 36 doll hairs. Is it accurate?
    Glock 40[QUOTED] likes this.
  18. Jul 31, 2021 at 11:42 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Pumps been replaced IIRC. Dealer did the timing belt and water pump by previous owner.
    Radiator yes, not 100% sure on t-stat.
    So this may be normal then? Hmmm...
    Not ever had to do that. I suppose I could pop the hood and give her a rinse out.
  19. Jul 31, 2021 at 11:58 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Yes. It has a calibration feature and I manually synchronized it to my phone GPS which is spot-on according to roadside radar setups.
  20. Jul 31, 2021 at 12:04 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    in theory if you put a bright flashlight on the other side, you should see it shining through the fins. In theory. Doesn't take much to clog up the fins - morning dew+dust+pollen+road salt.... clogged
  21. Jul 31, 2021 at 12:05 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I put walker on something & could immediately feel how restricted the motor was. But they have various models I'm sure.
  22. Jul 31, 2021 at 12:54 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Well wait, you mean the coolant gets hotter while at idle? I meant driving around in general. During temps under 100 my coolant tends to stay 194-200 but anytime it is 100 or hotter outside the temps seem to jump by a greater amount than the ambient temp (for example if its 105 my temp goes around 215).
    At a stationary idle I haven't looked really, when its that hot I want the truck moving.
  23. Jul 31, 2021 at 12:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I like this a lot. Probably could add a fuse tap if the 12V was important to you.
  24. Jul 31, 2021 at 1:02 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Not sure what you mean.
    Tundra2[QUOTED] likes this.
  25. Jul 31, 2021 at 1:09 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Correct. Only while sitting still at idle do I see a rise on the gauge after things heat soak a bit.
    des2mtn likes this.
  26. Jul 31, 2021 at 1:25 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    A fuse tap on the interior fuse box instead of using the the 12V ug for the cigarette lighter if it were important to you for phone charging, blow up doll inflation, etc.
  27. Jul 31, 2021 at 1:27 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I used the Quiet Flow series. They have cheaper but that's supposed to be stainless.
    Other cheap option is a cherry bomb :thumbsup: and you're out $30.
    NUDRAT[QUOTED] and Darkness like this.
  28. Jul 31, 2021 at 1:33 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    :rofl: Busted, you nailed it. That's how I get to use the HOV lane.
    I thought about hard-wiring it but then realized I was feeling too lazy. :bored:
    The easy way only took about 10 minutes and I washed my hands of it. I still might hard-wire it if I get bored one day.
  29. Jul 31, 2021 at 4:34 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  30. Jul 31, 2021 at 4:41 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Aluminized steel pipe like that is lucky to last 2 years.
