  1. Jul 14, 2021 at 8:56 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Valve Cover I believe
    BubbaW likes this.
  2. Jul 14, 2021 at 8:56 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    valve cover
  3. Jul 14, 2021 at 9:10 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I have no idea why I thought you lived in Alabama. I knew you liked TN but thought you lived across state lines.
    Howdy neighbor. :wave:
    Darkness and BubbaW[QUOTED] like this.
  4. Jul 14, 2021 at 9:19 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    B
    We'll be in your neck of the woods a few times this fall, got season tickets. Unless they suck like they have for last 10 years, then we'll be selling some :facepalm:
    Darkness and FirstGenVol[QUOTED] like this.
  5. Jul 14, 2021 at 4:19 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Hmm… Not sure how I’ve never heard of this event but I miiiight have gotten the wheels turning with the wife.
  6. Jul 14, 2021 at 4:21 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Hell yeah!
    des2mtn likes this.
  7. Jul 14, 2021 at 6:21 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Ugh. I went out to play a little today and noticed some gnarly CV popping on the passenger side.
    I had a feeling this outer joint was bad back when I did the boots because it wasn’t nearly as smooth as the other one.
    Regardless, can I buy a cage, race, bearings and rebuild? Or am I better off looking at a CVJ reman? These are OEM by the way.
    oscardog86 likes this.
  8. Jul 14, 2021 at 7:11 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I installed a good reman from NAPA. I think it was under $100 after core.
    Filthyphil likes this.
  9. Jul 14, 2021 at 7:16 PM
    JhadTRD
    JhadTRD New Member
    2005 Tundra DoubleCab TRD
    Lift, tires, bumper, winch
    Anyone ever used the rough country coil overs on their double cab? I put them on my truck probably 4-5 months ago. They claimed 2.5” lift but not with the extra weight of bumper and winch plus some settling I’ve got a fair amount of rub. Debating on swapping these out with the 5100s and stock springs I have on the wife’s sequoia. Anyone ever tried the 5100s all the way up on DC? Thinking it would offset the extra weight hanging off the front
  10. Jul 14, 2021 at 9:01 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    If you're 4x4 then you can't use the top circlip location. Bottom (#1) is stock, then you can go only the next 3 locations.
    https://www.bilsteinlifts.com/shop/...able-5100-shocks-for-2000-2006-toyota-tundra/
  11. Jul 15, 2021 at 3:29 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well, that's different. Wonder if some of the water I spilled in the engine bay triggered this, or if it's a left over code from the overheat yesterday. Still says pending after all...
    No light. Just pulled codes because I was looking at live values.
  12. Jul 15, 2021 at 4:10 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Simply means it has happened at least one time as it goes thru a drive cycle(Readiness Monitor Drive Pattern). Eventually it will either clear during future drive cycles or it won't. If it continues, swap the 2 rear O2's and see if problem switches to passenger side(P0156).
    Sirfive and Tundra2[QUOTED] like this.
  13. Jul 15, 2021 at 4:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Appreciate the info! Didn't know codes could clear on their own if the error condition was not detected again. Only one rear sensor on V6.
    BubbaW[QUOTED] likes this.
  14. Jul 15, 2021 at 4:21 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    It can take a few drive cycles but some will clear if it doesn't happen again....gas cap for example and in your case hopefully, O2 sensor.
    onesojourner and Tundra2[QUOTED] like this.
  15. Jul 15, 2021 at 4:34 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Gas cap, and oxygen senior are less than 2 years old. My "Cadillac" converter is bad, and I have an oxygen sensor extender/fouler on it to keep the P0420 code way. Post about install quoted below.
    Here's hoping that the next oil change isn't Watery...
  16. Jul 15, 2021 at 8:25 AM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    I got the fluid changed in my differential and transfer case today. Apparently, the diff was "very dirty".
    bmf4069 and hammeron like this.
  17. Jul 15, 2021 at 8:52 AM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Have you considered removing that "Cadillac" converter entirely? I bet your v6 would breathe a lot better afterwards. Enough of those antifoulers will keep your o2 senior from noticing the change as well.
  18. Jul 15, 2021 at 9:41 AM
    Legender
    Legender New Member
    Carlton
    DFW
    2006 Tundra DC Limited 2WD
    None yet.
  19. Jul 15, 2021 at 9:42 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Just ordered a new driver side door check for the Tundra and some other misc parts including air filter and cabin filter for the Rav. Took advantage of the free shipping they are still offering. I hope they continue that.
    Filthyphil, NWPirate, BubbaW and 2 others like this.
  20. Jul 15, 2021 at 9:44 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Legender My OCD approves. You should sand and paint that battery hold down bracket. I did that to mine. It seems like a common area for them to rust.
  21. Jul 15, 2021 at 9:57 AM
    Legender
    Legender New Member
    Carlton
    DFW
    None yet.
    Thanks, pretty much gone on one side. Looking for a replacement. I think too much sanding would cause it to disappear. :)
  22. Jul 15, 2021 at 9:58 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    the red, abcinv and bmf4069 like this.
  23. Jul 15, 2021 at 10:11 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Will that shine attract dust? I have always been hesitant to do anything after cleaning.
  24. Jul 15, 2021 at 10:14 AM
    Legender
    Legender New Member
    Carlton
    DFW
    None yet.
    I'm assuming that it would but I don't live in dusty area so no experience there. Would think a little light spray would rinse it off, but have not tried it.
    onesojourner likes this.
  25. Jul 15, 2021 at 10:19 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  26. Jul 15, 2021 at 11:20 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    ive been thinking about getting cvj’s and rebuilding the stockers. But theres not enough price differencing a rebuild + core charge & shipping. Vs an extra pair of new axles.
    ill eat that core charge and use these to start a 4wd squaw build.
  27. Jul 15, 2021 at 11:27 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    In my experience it really helps if you use a product that isn't oil based. That's where you get more dust. Plus I've heard those products are bad for rubber long term. I like Silk Shine By Chemical Guys.
    onesojourner[QUOTED] likes this.
  28. Jul 15, 2021 at 1:03 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
  29. Jul 15, 2021 at 8:00 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
  30. Jul 15, 2021 at 10:52 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Who sells those plates for the door check? I was checking mine yesterday and I’m starting to see the tiniest of cracks
