  1. Jun 30, 2021 at 5:38 AM
    Well, how'd it do? you definitely have the tires for it.
    Tundra2 and lsaami like this.
  2. Jun 30, 2021 at 5:42 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I love that shell.
  3. Jun 30, 2021 at 6:25 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  4. Jun 30, 2021 at 6:28 AM
    Grilling today?
    NUDRAT, FirstGenVol, des2mtn and 4 others like this.
  5. Jun 30, 2021 at 7:04 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    HA!
    Tundra2 likes this.
  6. Jun 30, 2021 at 9:52 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Drove home today and noticed the AC compressor sounds like a humpback whale in heat. I can only hear it with the fan set at low and if I feather the rpms while sitting at idle.
    Hope that’s not an early indicator I’ll need a new compressor soon.
  7. Jun 30, 2021 at 10:16 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Hopefully just belt slippage but more likely is clutch slippage. Have a look at the compressor with the A/C off and engine running and have someone slightly rev the engine (1500rpm or so) and then turn the A/C on, if you see the clutch chatter/slip while it's screeching, then your clutch is worn. Sometimes it's available as a replacement instead of having to replace the entire compressor which would be nice since you wont have to open the system.
    NUDRAT, bmf4069, Filthyphil and 2 others like this.
  8. Jun 30, 2021 at 10:56 AM
    Jack McCarthy
    Bill
    North of Boston
    I can’t really hear any screeching with the AC off, only when it’s on. I’ll have someone rev it when they come by later today.
  9. Jun 30, 2021 at 1:48 PM
    Lil Steve
    Gilbert, AZ
    Sorry, I just realized I forgot to add the part about turning the A/C on after reving the engine slightly. I edited the original post.
    NUDRAT likes this.
  10. Jun 30, 2021 at 1:49 PM
    Jack McCarthy
    Bill
    North of Boston
    Okay, thanks. Will do.
    Lil Steve[QUOTED] likes this.
  11. Jun 30, 2021 at 3:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Think I've found my suspension squeak. Sway bar link where it attaches to the lower control arm. 200 miles with no squeak so far after spraying only that with PB blaster.
    Wonder if it's rubbing on the arm.
    tacoguybill, onesojourner and jpink like this.
  12. Jun 30, 2021 at 4:26 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    You have the suspension maxx links? Maybe the metal bushings aren’t lined up vertically/correctly?
    NUDRAT and Tundra2[QUOTED] like this.
  13. Jun 30, 2021 at 5:17 PM
    Lil Steve
    Gilbert, AZ
    Barely flaps at 75mph, not an issue at all.
  14. Jun 30, 2021 at 5:17 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes, Maxx links. Could very well be. I'll have to compare drivers side versus passenger side and see what it do.
    oscardog86 and CodyP[QUOTED] like this.
  15. Jun 30, 2021 at 6:28 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    I’m noticing all the squeaks from front end now. And I’m just driving normal roads. No Kentucky craziness.
  16. Jun 30, 2021 at 6:59 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Jumped on Toyota's website and entered my VIN to get the breakdown on the factory options the truck has and discovered that the timing belt, etc., was replaced at a dealer at 110k in 2015, so I'm going to put off replacing it all myself at this time. I've already pulled the covers back and done a visual and the belt is in good condition, so I'm confident it's (relatively) safe at this time.
    Also getting the lower fan shroud ordered since it's missing.
  17. Jun 30, 2021 at 7:59 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Damn you guys werent kidding about the Suspension Maxx end links leaving hardly any clearance for getting to that lower nut, keeping the whole thing from spinning. Im thinking of grabbing a wrench from harbor freight and grinding it down to fit in the slot. Although someone in here posted that stubby wrench to buy. Does that fit in the slot without much if any modification? Its 14mm correct? Thanks!
    FirstGenVol and des2mtn like this.
  18. Jun 30, 2021 at 8:01 PM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    I know the ARB bumpers take some bracket shenanigans to work, but if this guy got it on a Sequoia, I can get it on a tundra right?
    onesojourner and oscardog86 like this.
  19. Jun 30, 2021 at 8:03 PM
    oscardog86
    Southern California
    I hope this does work for you, looks sick and its a great price!
    FrenchToasty likes this.
  20. Jun 30, 2021 at 10:36 PM
    Orange devil
    Orange devil New Member
    Almost done with the filler turn single panels..super bright !! ..and No chihuahuas were hurt in the modification lol 20210630_215618.jpg 20210630_215620.jpg
    RUSTYNUTS, 1genjunky, Tundra2 and 6 others like this.
  21. Jul 1, 2021 at 3:25 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I was the one that mentioned the stubby wrench, no modification needed. It should slip right on depending on how the bolt is oriented. If the bolt is oriented off, turn it by putting a wrench just on the top nut.
    9/16" for the bottom bolt has worked best for me. Top nut is 14mm. The stubby wrench will catch on the LBJ/ rotor cover and you can tighten it from the top.
    oscardog86[QUOTED] likes this.
  22. Jul 1, 2021 at 5:51 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    It's my favorite bumper. I don't care that it looks like Bubba. The hoop is perfect.
    bmf4069, Tundra2 and FirstGenVol like this.
  23. Jul 1, 2021 at 6:11 AM
    oscardog86
    Southern California
    Thanks man, Ill order one today!
    Tundra2 likes this.
  24. Jul 1, 2021 at 6:22 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    I second this! Last summer I was having issues finding antifreeze spewing outta the blue. Turns out when the supercharger was taken off my truck they left the hacked up shroud on and it didn't direct airflow to cool as designed and was causing this. It wasn't the only.problem but a big contributing factor.
    https://www.tundras.com/threads/coolant-leak-got-home-and-found-coolant-on-fender-shit.46837/
    NUDRAT likes this.
  25. Jul 1, 2021 at 6:27 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Mine was lost long ago by some shop, but the sequoias lower shroud wouldnt fit. The plastic tabs were a tad too close together, and the metal clips didnt line up. I’ll order one or hunt a jy.
  26. Jul 1, 2021 at 6:36 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    I
    Believe that entire shroud I got for the replacement was from a sequoia...
  27. Jul 1, 2021 at 6:37 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    But dc’s are sequoia ridgelines.
    Everything looks identical, just different enough. Sequoias is stamped suv and tundras is stamped v8
    Hi06silver likes this.
  28. Jul 1, 2021 at 7:25 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Can't remember if I replied to you or not.
    The truck did fantastic. it was loaded up with some cooking stuff and 3 people. it wasn't a super gnarly trail, but there were some washes and ruts. I felt the rear bottom out once or twice, and ready a few coil knocks up front, but I also had 40lbs of air in the tires and no way to deflate or reinflate. I know, shame on me.
    as far as grip is concerned, I never even took it out of 2WD.
  29. Jul 1, 2021 at 8:25 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Every once in a while I do enough truck gang shit to keep my truck gang status.
    1,460 pounds of grade 57 gravel.
    Compare that picture to this picture from a similar run on OEM suspension. (Angles aren't quite the same... but real close.)
    I was 100% riding on the one bumpstop I still had at the time.
    NUDRAT, jpink, tacoguybill and 4 others like this.
  30. Jul 1, 2021 at 8:27 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Actually, I think I had two scoops on the OEM run based on pictures which would have been closer to 3,000 lbs.
