What are your top 5 mods on your Tundra?
Discussion in 'General Tundra Discussion' started by CTX84, Apr 11, 2017.
  1. Apr 11, 2017 at 6:04 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What's up fellas, auxiliary ?. When people put billstein 61? Or 51? That means they haven't done a 6 inch plus full lift right? The billstein are shocks or coilovers that lift the truck and keep it stock ??
  2. Apr 11, 2017 at 6:06 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The 5100 is a coilover that has lift settings from 0", .75". 1.5" and 2" lift heights for the front with 0" rear lift.
  3. Apr 11, 2017 at 6:10 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Ok cool and the 61 is an upgraded one?
  4. Apr 11, 2017 at 6:26 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Bprose no I didn't install the tank myself. Cost was around $280.00, to install. Installer was on the transfer flow authorized list and local too.
    Yep, all sensors and sending units work like original. Miles to empty is off, but this frequently is off anyway and I don't care.
  5. Apr 11, 2017 at 6:31 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Tint
    Tonneau
    6!inch lift
    20x 35
    De-chrome
  6. Apr 11, 2017 at 6:47 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    TRD rear sway bar-Do this now!!
    Nerf steps
    Backflip Tonneau cover
    3/1.5 lift
    Tires/wheels
  7. Apr 11, 2017 at 8:16 PM
    What lift u considering? Only asking cause i have a 6" RC lift and its "Rough" alright! I bought truck used it came with it i didnt know what i was getting into...Dont like feel every bump on road dont like my front cv axle angles turning radius decreases wanna lower truck down ...check out toytec.com boss kit
    gosolo likes this.
  8. Apr 11, 2017 at 8:23 PM
    Hello i did! Duh! C'MON MAN!
    GNTundra and T-Rex266[QUOTED] like this.
  9. Apr 11, 2017 at 8:25 PM
    Can't u reset like when u do maintenance required light reset to fix MPG??? Jus a thought im considering TF tank as well
  10. Apr 11, 2017 at 8:43 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @aramirez73 , the threads about how the MTE aren't accurate, abound. Just like we all know how the tank has 4 to 6 gallons left even when the gauge says empty. I know I have 46 gallons and get about 14 mpg. So I fill up after around 500 miles and always before 550. Not really rocket science and I'm not complaining! I'm comfortable knowing I can go to 600 miles in a pinch, but why bother?
    PermaFrostTRD likes this.
  11. Apr 12, 2017 at 2:18 AM
    PermaFrostTRD
    Northern NY
    Does the fuel guage not work either with the transfer flow? Or do folks just not use those anymore.
  12. Apr 12, 2017 at 3:02 AM
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    that's because we don't have all that extra income from being a moderator like you do.
  13. Apr 12, 2017 at 3:05 AM
    TRDFaux
    follow the rules Joon!!!! you can only pick 5.
    joonbug[QUOTED] likes this.
  14. Apr 12, 2017 at 3:13 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    As of now.....
    * Custom Rod Rack
    *Retrofitted Headlights
    *Sabm
    *Bullet Lined Steps & Grill
    *Devil Horns
    This is subject to change
    :cool:
  15. Apr 12, 2017 at 5:20 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Bprose @PermaFrostTRD , the fuel gauge, when installed in the transfer flow tank, works exactly like it did on the factory fuel tank.
    The Toyota fuel gauge is designed to show empty when there is actually 4 to 6 gallons remaining. I have read several different reasons for why Toyota did this. I don't know why but it's the way it is.
    Some fuel may be required to keep the submerged pump cooled, is the most plausible explanation.
    Hope this helps.
  16. Apr 12, 2017 at 5:38 AM
    Tundra Pirate
    Tundra Pirate Bamf
    Kelly
    Stanley, NC
    2014 Super White Tundra Crewmax 4x4 Limited
    Bilsteins 5100 Leveled Method NV Machine KO2
    Generic list here:
    Bilstein 5100 level
    Method NV machine
    KO2
    Husky liner/ESP lock storage system
  17. Apr 12, 2017 at 6:00 AM
    VA10
    VA10 New Member
    2020 Tundra Limited TRD Off-Road
    If I were you I would establish what functionality NEEDS to be modified. If you do not need larger tires or more ground clearance all you are doing is paying for more rubber. Unless you are trying level/lift purely for looks. that is a different story. Functional top 5 mods in in my opinion are below.
    upgraded head light bulbs (led)
    upgraded fog bulbs (led)
    Aux reverse/area lighting
    husky liner or weather tech mats - if it fits you're needs.
  18. Apr 12, 2017 at 7:14 AM
    $0.00/hr :D
  19. Apr 12, 2017 at 2:03 PM
    #49
    TRDFaux
    Baller!
    T-Rex266[QUOTED] likes this.
  20. Apr 12, 2017 at 2:17 PM
    #50
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Imagine if you got paid minimum wage... at 18 hours a day you'd make over $70k a year. :D
    FireAC and T-Rex266[QUOTED] like this.
  21. Dec 28, 2020 at 2:01 PM
    #51
    Dg191
    Dg191 New Member
    2007 2 who drive limited tundra
    None
    Can someone tell me about the “Retro Headlight” mod, which ones did you use, Did you do tail lights as well. Thank you. Also, I’m seriously mechanically challenged ( I hate admitting that ) so I’d be looking for someone to install these?
  22. Dec 28, 2020 at 2:08 PM
    #52
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    1. Upgraded Sound System with sound deadening
    2. BAMUFFLER
    3. ToyTec lift/bigger tires
    4. Sequoia grille
    5. AlphaRex Pro headlights
  23. Dec 28, 2020 at 2:23 PM
    #53
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Lift, wheels, pop lock, wireless charger, and front anytime camera.
  24. Dec 28, 2020 at 2:29 PM
    #54
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    My 2019 TRD Pro
    1- Center Council Safe
    2- NSV Hood Light Bar
    3- FRAC Harness and Camera
    4- 1-3 Coach builder level kit
    5- Pop Lock
    I Have several others that I like but those I believe are the most important to me.
  25. Dec 28, 2020 at 2:35 PM
    #55
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Mine's a daily driver/work/play truck.
    Sometimes work is up to 300 miles away.
    Said work requires hauling 300-500lbs of tools/ materials. The following reflects that.
    1. 46g Transfer Flo tank
    2. Firestone air bags
    3. Arb bull bar
    4. 5100's (8112's soon)
    5. 37's
    A re-gear should be in there somewhere but somehow I manage 11.3mpg @75mph(gps)
  26. Dec 28, 2020 at 2:35 PM
    #56
    snowman19
    snowman19 New Member
    Scott
    Cypress, Texas
    2019 White Tundra CM
    Katskin leather seats, painted engine cover, fuse box cover, Rigid 30" light bar in bumper, Method 605 wheels, Bak roll up bedcover, Rhino lined grill surround and bumper caps
    1. Full stereo upgrade...subs, doors, amp, sound deadening, etc...
    2. Pro Comp 4” lift/Method wheels and 35’s
    3. Drivers side grab handle
    4. TRD Pro led headlights
    5. Full de-chrome inside and out
  27. Dec 28, 2020 at 2:41 PM
    #57
    Rgross2112
    Rush
    2020 Silver TRD Limited
    So far I would say:
    • Nerf side step
    • BA 10” muffler (Dirty Deeds)
    • Bed liner
    • Footwell lighting
    • Puddle lights
    I have a feeling though this list may change
  28. Dec 28, 2020 at 4:02 PM
    #58
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Done:
    1. Bed liner
    2. Canopy
    3. Winter tires
    To do:
    4. Rear sway bar
    5. Towing mirrors
    Can't remember what else
  29. Dec 28, 2020 at 4:48 PM
    #59
    jstyle
    jstyle New Member
    Josh
    2016 Magnetic Gray Offroad CrewMax
    Dechrome :)
    DeeZee roll bar
    SCS wheels (because almost everything else is pig heavy)
    275/70 again weight is a thing
    Tonneau cover :)
  30. Dec 28, 2020 at 5:05 PM
    #60
    jstyle
    jstyle New Member
    Josh
    I’m certainly not at the top of the pile in Tundra mods but I have quite a few at this point :) It just depends on what your looking to accomplish.
    Cpl_Punishment likes this.
