What are folks with Platinum and 1794s doing for extra switches?
Discussion in 'Electrical' started by TunsofFon, Nov 9, 2021.
  1. Dec 11, 2021 at 12:27 PM
    TunsofFon
    TunsofFon [OP] New Member
    Pacific NW
    2021 MGM Platinum
    It’s still sitting in the box. I am waiting on my ditch lights and hood bulge lights to show so I don’t have anything to hook up to it yet. It looks like a very simple install though so I don’t anticipate any problems.
  2. Dec 13, 2021 at 7:51 AM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Are you planning on hooking the yellow to the transmission or the battery. I’ve seen both so far, straight to the battery is a cool option as the truck doesn’t have to be on to run your lights. Mine is coming this week as well, but my ditches are a few weeks out.
  3. Dec 13, 2021 at 8:04 AM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    I plan to connect to the battery. My ditches are also a few weeks out.
  4. Dec 14, 2021 at 4:24 AM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    Just got a shipping notification today, ditches are coming Saturday. Baja quoted 3-4 weeks, only took 2 days to ship! Trigger will be here Thursday, should be able to run the whole setup this weekend
    TunsofFon[QUOTED][OP] likes this.
  5. Dec 14, 2021 at 9:43 AM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Hopefully mine ship soon too then
  6. Dec 14, 2021 at 9:44 AM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    What did you order?
    I've got a pair of squadron sport WC on order with a 55" splitter
  7. Dec 14, 2021 at 9:47 AM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    I went with the Rago ditch light bundle. Comes with Squadron Pros in WC. I have the amber rock guards for them too
  8. Dec 14, 2021 at 9:49 AM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Also waiting on an amber 40” S8 for the hood bulge. SDHQ brackets for that one.
  9. Jan 7, 2022 at 12:25 PM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    went this route with a 6 switch Auxbeam.
  10. Feb 17, 2022 at 10:21 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I put in SPOD bantam x with LED panel. I run two lights off other switches...fogs and rear bumper lights. Didn't need the truck bed switch since I have a cap. SPOD runs the rest of my baja design lights.
    Shadowfax1 and TunsofFon[OP] like this.
  11. Feb 19, 2022 at 8:11 AM
    Nickatnight
    Nickatnight New Member
    Nick
    98445
    2021 1794 Tundra
    Rhino running boards, Amber running lights, Underhood automatic LED Lighting, OEM Fender Flares, Tech12 Volt New Killer Audio System with factory Head Unit.
    TundraTool13, when you installed the switch and cut into the leather, was the leather glued down? Thanks
    trevorklat likes this.
  12. Feb 19, 2022 at 8:18 AM
    Shadowfax1
    Shadowfax1 New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
  13. Feb 19, 2022 at 9:51 AM
    Nickatnight
    Nick
    98445
    2021 1794 Tundra
    You could get one and swap out the metal around the gearshift. I think there a bit expensive, but it probably work.
  14. Mar 1, 2022 at 5:04 AM
    BlueLighting
    BlueLighting New Member
    Rick
    California
    2015 Platinum
    4.5 RC Lift, fuel wheels, RC front bumper & front struts
    Shadowfax1 likes this.
  15. Mar 7, 2022 at 4:16 AM
    thedonn
    thedonn New Member
    I put this in yesterday - very easy to add lights etc. it has bluetooth control and also low voltage mode so the system shuts down when the battery gets down to 11.7 or so
    dkrou likes this.
  16. Aug 7, 2023 at 6:24 AM
    Wambam57
    Wambam57 New Member
    I would also like to know how TundraTool13 did this with the leather
  17. Aug 7, 2023 at 6:36 AM
    Nickatnight
    Nick
    98445
    2021 1794 Tundra
  18. Aug 7, 2023 at 6:40 AM
    Wambam57
    Wambam57 New Member
    love it! How did you do that?
  19. Aug 7, 2023 at 6:44 AM
    #49
    Nickatnight
    Nick
    98445
    2021 1794 Tundra
    Very slowly, removed the plastic welds underneath, cut the hole, and stretched the leather after inserting the switch block. Then hot glued the stretched panels. I admit took some courage to cut the leather but it turned out great.
  20. Aug 7, 2023 at 6:49 AM
    #50
    Wambam57
    Wambam57 New Member
    I’m not sure what you mean by the plastic welds. Any pics? How is the switch block attached? I’m assuming you hot glued the stretched leather under the switch block?
  21. Aug 7, 2023 at 7:13 AM
    #51
    Nickatnight
    Nick
    98445
    2021 1794 Tundra
    When you take apart the panel, underneath is a series of plastic welds that will need to be removed before the switch block will fit. Just trial and error until it fits. Use a dremel Front Camera Switch Side Leather Raw.jpg gearshift panel rough.jpg
  22. Aug 7, 2023 at 8:21 AM
    #52
    Wambam57
    Wambam57 New Member
    Did you add the 1794 leather to that sr5 trim panel?
