What are folks with Platinum and 1794s doing for extra switches?
Discussion in 'Electrical' started by TunsofFon, Nov 9, 2021.
  1. Nov 9, 2021 at 9:28 AM
    TunsofFon
    TunsofFon [OP] New Member
    Pacific NW
    2021 MGM Platinum
    Looks like there are no extra switch spots on the Platinum and 1794. What are the options for adding switch locations? I found a part number for the OEM credit card holder behind the shifter (58805-0C090-C0). Besides this, has anyone else added switch locations another way?
  2. Nov 9, 2021 at 9:32 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
  3. Nov 9, 2021 at 9:36 AM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
  4. Nov 9, 2021 at 9:45 AM
    NoRcptn
    NorCal
    2017 Platinum
    Yeah i ended up buying the whole deal simply due to the ease of wiring.
    I suppose you could buy their mount and put anything in the blank spot.
    There are a ton of options to put switches in that spot with any Upfitter switch panel.
    The issues I was avoiding is running a ton of wires in and out of the cab. The switchpro is simple and all your connection/wiring points are in the engine bay.
    Here is a thread if you look into that route. If your just adding one or two switches I don't know if it would be worth the cost.
    https://www.tundras.com/threads/switch-pros-9100-install.47597/page-3
    TunsofFon[OP] likes this.
  5. Nov 9, 2021 at 9:46 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    If you don’t use all your home link garage door opener buttons you can also use those
  6. Nov 9, 2021 at 10:38 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    TRDFerguson and RobertD like this.
  7. Nov 9, 2021 at 10:40 AM
    Taco-Spike
    Two Trucks
  8. Nov 9, 2021 at 12:36 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    This is intriguing. Do you know if there is a write up or schematics for this?
  9. Nov 9, 2021 at 12:43 PM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    I run the Trigger 6 system made by ACS. I think they're primarily used by Jeep but I liked the configuration freedom they allow with their system. It's a wireless system so there will be moments of interference, depending on your environment but I haven't ran into any issues so far with the supplied switch panel.
    I can control my light bars through the switch (which is tapped into a constant fuse), remove the switch panel and use it wirelessly outside the truck, connect through their app on my phone (which when connected is great because you can control the brightness and allow the lights to strobe), or directly through the trigger 6 system under the hood.
    I double-side taped my switch panel at the front of the center console lid. If you have an early second gen, it's right where that ambient light is that shines at your center stack with the cupholders.
    The only downsides are the app can be finicky and the battery drain on the switch remote can be bad, but I could be wrong on that one as I may have had near expiring batteries. I'm currently testing out my latest replacement batteries and they're running on a month so far.
  10. Nov 9, 2021 at 12:54 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    You would purchase something like this (I have one in my garage just havent had the time to wire it all up. This would be your switch and you would use this as the switch to trigger a relay (which your device would be connected to). This RF has an operating range of 433mhz, and homelink operates between 300 and 433mhz. So, it should work in theory. Maybe if I can find a few minutes this week I could make a quick video for you all and post it up. I have some lights laying around so shouldnt take too long to set up.
    https://www.amazon.com/gp/product/B07JLXYLHW?ie=UTF8&th=1
  11. Nov 9, 2021 at 1:19 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Shadowfax1 and TunsofFon[OP] like this.
  12. Nov 9, 2021 at 1:24 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    The Trigger 4 or 6 looks pretty sweet. Could mount it to the center dash. I’ll definitely look into this more. Thanks for the rec:thumbsup:
  13. Nov 9, 2021 at 1:38 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Have any pics of how you wired the Trigger 6? I have one that I need to install.
  14. Nov 9, 2021 at 3:13 PM
    g6t9ed
    Sure, not too terribly difficult. I don't know which part you're referring to (trigger system or the switch panel).
    For the trigger system, I didn't want anything permanent drilled into the fuse panel so I used heavy duty 3M velcro between the bottom of the trigger to the top lid of the fuse. Wired up the fused + and - and I believe that was it. No wires to throw into the firewall since it's a wireless system. I currently only have my light bar hooked up into slot 1 since that has the highest amp fuse (there are different amperages allowed for each slot).
    For the trigger panel, I ran the hot and trigger wires to the internal fuse location and the ground cable to.. well, ground. Ran the wire up and underneath the steering column and then through the center shift knob area. You can barely see it on the right hand side of the switch panel where I have the double sided tape. I'm debating on getting an adapter mount since it has a flat surface and allows for a rotation adjustment. I just haven't committed yet to see how this current setup shapes up. I only hardwired everything a month ago. I'd been using everything either wirelessly or through the app.
    Edit: Bonus photo of the trigger as a standalone.
  15. Nov 9, 2021 at 4:05 PM
    camron1039
    camron1039 New Member
    Camron
    2021 Tundra Platinum
    Shadowfax1 likes this.
  16. Nov 9, 2021 at 4:15 PM
    Dsptundra
    Austin TX Area
    Is your yellow lead for the trigger connected direct to battery or did you connect to a fuse inside the fuse box?
    Love the location of the switches! I have been looking at the visor clip as an option but I will try your location first.
    g6t9ed[QUOTED] likes this.
  17. Nov 9, 2021 at 4:31 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    So does the trigger have the option to be wireless or hardwired? I didn’t think the trigger needed any hardwiring.
  18. Nov 9, 2021 at 5:37 PM
    Dsptundra
    Austin TX Area
    If you want the switches to be backlit you can wire to a power source. You can also tie in wired switches if you wanted to use them instead of the switches it comes with.
    g6t9ed likes this.
  19. Nov 9, 2021 at 5:39 PM
    TundraTool13
    TundraTool13 New Member
    2020 Tundra Platinum
    Here’s my setup……
  20. Nov 9, 2021 at 5:50 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    I have been contemplating the Trigger...
    g6t9ed likes this.
  21. Nov 9, 2021 at 5:55 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    After looking at it for a while I think I may go with the Trigger 4 Plus. Looks like a sweet, modular setup. I’m still confused at what @g6t9ed hard wired to the trigger or the purpose of it as I don’t see the trigger hard wire in the 4 Plus instructions. Maybe a 6 shooter feature? Or I’m oblivious to something going on.
    g6t9ed likes this.
  22. Nov 9, 2021 at 5:56 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    For those who have the Trigger already, did you buy the generic one, Tacoma or 4 Runner kit?
    g6t9ed likes this.
  23. Nov 9, 2021 at 5:59 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Looks like the Trigger remote hardwire is 6 Shooter specific…
    g6t9ed likes this.
  24. Nov 9, 2021 at 7:11 PM
    Dsptundra
    Austin TX Area
    Generic for me.
    TunsofFon[QUOTED][OP] and g6t9ed like this.
  25. Nov 9, 2021 at 7:31 PM
    g6t9ed
    Directly to the battery. I can take additional photos tomorrow.
    You can see the fused red positive and yellow trigger wire are connected to the positive side of the battery.
    If you switch the location, let me know. I've had this thing installed for a year but just decided a month ago to put it where I did. Been racking my brain on a good spot. So, if you find a better one, I'd like to know.
    On mine, I had to double up on the double sided tape because of the curve of the backplate, just FYI.
    Technically, both. I hardwired it so I don't completely rely on the battery.
    Looks like others answered your question. I didn't know this wasn't an option on the 4.
    Edit: Sorry, it looks like you answered your own question. I didn't see that you responded to it, lol. Along with the backlighting when it's on, I also use it to save the internal replaceable batteries as the hardwire keeps it useable.
  26. Nov 11, 2021 at 2:59 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    @TunsofFon made a little video for you. I will say there is a little bit of a delay using the homelink and it can be spotty but it might be much better(or worse) with the receiver under the hood. Not sure how the metal hood would interfere or if the shortened distance would make it more reliable. As it’s currently set up, I’m not sure I would run it as a primary switch, but it is a nice option to have. Let me know if you have any questions
    https://youtube.com/shorts/sLrcNZc6110?feature=share
    g6t9ed and TunsofFon[OP] like this.
  27. Nov 11, 2021 at 3:03 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Cool idea and simple enough. I’m 99% sure I’m going to go with the Trigger 4 plus. If I ever find myself needing more than 4 inputs I may use this setup too.
    Thanks for the inspiration :thumbsup:
    g6t9ed and Mater[QUOTED] like this.
  28. Nov 11, 2021 at 3:09 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    No problem. I will say that my homelink sucks in general. It will drop programming and not open the garage door often. I actually stopped using it and went to a traditional garage door opener and keep it as a backup. So if your truck’s homelink works better than mine, it could be a viable option. Just don’t want to sell someone on something I haven’t fully vetted. And yeah that trigger 4 looks sweet! Good luck with whatever you go with
    g6t9ed and TunsofFon[QUOTED][OP] like this.
  29. Nov 18, 2021 at 3:33 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Well, well…look at what came in yesterday…6AB3F065-76A5-4686-B296-7545719A0DCB.jpg
    g6t9ed and Dsptundra like this.
  30. Dec 11, 2021 at 11:56 AM
    Romulus
    Romulus New Member
    2021 Tundra Limited Nightshade in Windchill Pearl
    How did the install go for you? I just picked one up during Black Friday. I haven't installed mine yet.
