Washboard Frontend Vibration 60km/hr + Fox 2.5
Discussion in 'Suspension' started by Uncle O, Aug 9, 2019.
  1. Aug 12, 2019 at 9:46 AM
    Uncle O
    Uncle O [OP] Life is Good
    Justin
    British Columbia
    2019 Tundra SX
    295 / 70 / 17 Wrangler Duratracs Method 702 Camburg UCA Fox 2.5 Remote x 4 Icon RXT leaf pack Rigid lighting
    Will do, thanks! :thumbsup:
    831Tun[QUOTED] likes this.
  2. Aug 12, 2019 at 10:17 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    That sound is normal. Every truck will do it if the washboard surface produces the right frequency of vibration. I just slow down or speed up until it stops or I just ignore it.
    Its something in the dash or steering column that makes that noise, but has to be the perfect vibration
  3. Aug 12, 2019 at 10:31 AM
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    I appreciate the response, definitely helps put my safety concern to rest. Now how to relax my OCD. :lalala:
  4. Aug 12, 2019 at 11:18 AM
    Tacotundra
    Tacotundra New Member
    Vegas
    2017 Tundra
    Mine does the same. Not as loud as yours but same thing. Just go faster:)
    Uncle O[OP] likes this.
  5. Aug 12, 2019 at 5:48 PM
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    The general consensus seems to be “me too” and go faster. :burnrubber:
    831Tun likes this.
  6. Aug 12, 2019 at 5:55 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I agree that going faster will smooth the front vibration. Until the back bucks you like a bull :). 4 inches is so high on the coil-overs that you have very little down travel from ride height. This can make it jerky off road
    Is your traction control off in these situations? Maybe you are feeling a little of the abs kicking in?
  7. Aug 12, 2019 at 6:28 PM
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    Ya, as much as “go faster” is funny and somewhat true, it doesn’t solve my search in this case. . I’ve pushed it to 120+ km/hr and it only gets worse. Yes I agree, 4.5” is too high, sorting it out and alignment tomorrow night. Traction control is always off for me, good call though.
    Hoping the extra 1” or so lower will help smooth things out. :fingerscrossed:
    Thanks for your 2 cents.
  8. Aug 12, 2019 at 6:57 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Personally i feel like my truck handled and rode like crap higher than 2.5 inches of lift. The angle on the arms when you go higher causes the poor feel.
    If you need an alignment too that will contribute to the vibration at speed too
  9. Aug 12, 2019 at 7:07 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Yep, 2.5” is the sweet spot for MT. Too bad Fox don’t give a crap and sell 0 - 3” coilovers that can barely be dialed down to 3”.
    GodlessPro, sr5shark, 831Tun and 2 others like this.
  10. Aug 12, 2019 at 7:15 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Sadly most coilover buyers want bro height
    831Tun and Uncle O[OP] like this.
  11. Aug 12, 2019 at 7:41 PM
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    I’m definitely excited for this tuning session tomorrow. It’s aligned now, but will need alignment again after preload adjust. ;)
  12. Aug 12, 2019 at 7:41 PM
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    Performance please. :benchpress:
    Hbjeff[QUOTED] likes this.
  13. Aug 12, 2019 at 7:42 PM
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    Ya, an interesting measurement they have indeed. Glad I’m not missing something. :cheers:
  14. Aug 13, 2019 at 4:40 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    That just means the springs are too heavy. Fox specs them for trucks with bumpers winches and skids. They came with 700# coils when I was MT back in 2013. I was able to dial them in to 2.5" lift because of the gear I had on my truck.
    If someone can't get them dialed down, then they just need to switch to 600# coils.
    Kings come with 600# but then you can't take big hits...
    Bottom line is guys need to be smarter with their trucks and not just throw sht on and call it a day.
    joonbug and Uncle O[OP] like this.
  15. Aug 13, 2019 at 4:41 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    you do need to make sure you're at 2.5" lift. More than that and your CVs are running at bad angles. Plus you don't have enough droop to make them ride well. If you run out of adjustment, switch coils
    joonbug and Uncle O[QUOTED][OP] like this.
  16. Aug 13, 2019 at 6:57 AM
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    Ah yes, 700# spring rate explains the high ride height with minimal preload. Thanks for the info.:thumbsup: I’m searching for the best ride results as I transition through my build. 700# will hopefully be perfect once a bumper and winch finds its way onto the front end. In the mean time I’m hopeful the 8 threads I have left will reduce the preload and front end height enough to be within the sweet spot as I save for round 2 of the build. :transformer:
    osidepunker[QUOTED] likes this.
  17. Aug 13, 2019 at 7:04 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    yeah I wouldn't worry about changing springs until you get the final gear weight on your truck
    Uncle O[QUOTED][OP] likes this.
  18. Aug 13, 2019 at 7:04 AM
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    Again, thank you. I appreciate the information.
    I’m dialling the 700# down today and getting re-aligned tonight. Shake down ride 2.0 coming up shortly. :bikewhoops:
    Then for the 600# or 700# decision.
  19. Aug 13, 2019 at 7:07 AM
    #49
    osidepunker
    Alex
    2013 Tundra DC 4x4
    wait until you get the bumpers and stuff on before you spend money on coils.
    and don't forget that you have shocks that are easy to revalve. The default valve stacks are usually not the best for every situation. Get your ride height as best you can, get your gear installed, figure out your final springs, then have them revalved. A flutter or double flutter will smooth out the small bumps
    But don't think you're going to get rid of that rattle. every tundra will do that at the right frequency
  20. Aug 13, 2019 at 7:12 AM
    #50
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    Ok sweet, thank you for the piece of mind and info. I’ll post preload results tomorrow. :fingerscrossed:
  21. Aug 13, 2019 at 7:18 AM
    #51
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    Solid! Thanks for the timeline map to saving money! :yes:
    I just got my Mavcoat in the mail yesterday, hoping to keep these 2.5’s alive and well long enough to enjoy the ability to tune as you’ve mentioned. For now, the clickers are my friend.
  22. Aug 15, 2019 at 7:39 AM
    #52
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    Update:
    Dropped the preload down to 1 thread showing. Sitting about 25.5” hub to fender.
    (Approx 3.5” lift) I’m going to keep the diff drop in until I get bumper and winch this winter. Did an alignment and went for a shake down drive.
    :eek: VIBRATION GONE! :thumbsup:
    60-110km/hr, same road, full air pressure in tires and still no vibration. Thank you everyone for feedback and advise, I appreciate it. Rides so much better! 04C4B03C-E659-417D-BD05-A42B1D4D9420.jpg
  23. Aug 15, 2019 at 7:45 AM
    #53
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    I will add that the split collar preload ring on the Fox 2.5 is a delicate flower. Very easy to jump a thread if the collar locking screw is undone much more than 1 full turn.
    Ask me how I know. :anonymous:
    I’m sure many of you are already aware of this, I was not. But fear not, crisis averted with a little time spent on the spring compressor. :benchpress:
    osidepunker and monaco730 like this.
  24. Aug 15, 2019 at 1:53 PM
    #54
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    A bit off thread topic, but here we go.
    After reducing preload, reinstalling driver side coil over and doing an alignment I’m getting a dull “clunk, clunk” when I turn the wheel 1/4 turn either direction. No sound during compression or extension in straight line. No clearance issues or rubbing I can see.
    Where to look first? Any ideas?
  25. Aug 15, 2019 at 2:44 PM
    #55
    Vizsla
    Vizsla ☠️☠️☠️
    Need to torque everything that was loosened during coilover adjustment, and alignment. I have never had an alignment where the lower cams and tie rod ends were torqued proper. Also look at the lower coilover mount, is it twisted all the way to one side in the mount as opposed to neutral? That will make noise as well.
  26. Aug 15, 2019 at 3:04 PM
    #56
    Uncle O
    Justin
    British Columbia
    2019 Tundra SX
    Thank you sir. I’ll look into it tonight. :thumbsup:
  27. Aug 15, 2019 at 3:07 PM
    #57
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think the torque spec on the cam tabs is around 176? I torque mine to 200.
    Also, check your sway bar/ coil perch for contact. Tie rod/ coil contact too.
    Uncle O[QUOTED][OP] and Vizsla like this.
  28. Aug 15, 2019 at 3:13 PM
    #58
    Vizsla
    Vizsla ☠️☠️☠️
    207
  29. Aug 15, 2019 at 3:14 PM
    #59
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Is that stock spec?
    Uncle O[OP] and GodlessPro like this.
  30. Aug 15, 2019 at 3:16 PM
    #60
    Vizsla
    Vizsla ☠️☠️☠️
    Yep.
