Want to learn how to properly lube the drive shaft in my Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1999cutiger, Aug 12, 2018.
  1. Jul 9, 2021 at 5:52 AM
    #151
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    So no needle type required? I guess I could just try them all myself before trying to source one...
    15whtrd[QUOTED] likes this.
  2. Jul 9, 2021 at 7:44 AM
    #152
    15whtrd
    15whtrd Mr. Blonde
    For me, no. I can just squeeze it in there. If you have a fatter nozzle on your gun, there are a couple that may give you some grief. They definitely takes some strong fingers on a few of them.
  3. Jul 9, 2021 at 8:10 AM
    #153
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Someone on here gave the tip about removing the heat shield for the front driveshaft ones. Great advice!
    jgullace likes this.
  4. Jul 9, 2021 at 9:52 AM
    #154
    FortyNorth
    Northern ON
    OK roger that, thanks!
  5. Jul 9, 2021 at 10:54 AM
    #155
    GatorBodine
    GatorBodine New Member
    Alright I’ll be the retard - My last 3 trucks I’ve had since 95’ (1 chev and 2 Ford’s) and I’ve never greased a drive shaft. Is Toyota the only one requiring this ?
  6. Jul 9, 2021 at 11:44 AM
    #156
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    What's the interval to lubricate the driveshaft? I think the Toyota maintenance schedule is saying every 15,000 miles but the Tundras.com schedule says 5,000 miles.
  7. Jul 9, 2021 at 12:06 PM
    #157
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I wouldn't be surprised if some of your old trucks had grease fittings on the the prop shafts.
  8. Jul 9, 2021 at 3:10 PM
    #158
    GatorBodine
    They may very well have had them, just wasn't aware of that being a maintenance item and I've always done my own basic maintenance. I will admit I never read the manual on every item that needed maintenance. I just paid attention to the obvious things that needed it.
    92' Chev S-10
    98' F-150
    11' F250
  9. Jul 9, 2021 at 8:20 PM
    #159
    PA452
    PA452 New Member
    Well, I see you have a '21 Tundra? If so, I think your u-joints on the prop shaft are probably sealed.
    I just got my '21 Tundra a few weeks ago, haven't even checked yet to see if there are grease fittings on the u-joints, but I doubt there are as my '18 Tundra didn't have them.
    GatorBodine[QUOTED] likes this.
  10. Jul 9, 2021 at 8:36 PM
    #160
    737fixer
    737fixer New Member
    So from reading this the 18 - 21 have a sealed driveshaft. Are there any lube points at all or is everything now sealed?
  11. Jul 10, 2021 at 5:41 AM
    #161
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
  12. Jul 17, 2021 at 8:10 AM
    #162
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Just looked under mine, no zerks! Bad thing is I already bought a grease gun and grease but no where to put it ... Guess I'll just lube my '13 tacoma and wife's Malibu.
  13. Jul 17, 2021 at 9:39 AM
    #163
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    My old 97 Chev 1500 had sealed u-joints. That's why they had to be replaced, lol. Sealed is a terrible way to go. More $$$ for the dealer.
    Wallygator likes this.
  14. Sep 25, 2021 at 9:17 AM
    #164
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Hey so I was able to grease my 4x4 on all but one point.. The rear front driveshaft (One attached to the transfer case) zerk fitting was at an angle that my grease fitting was not fitting in. So I had a needle as many recommended to use that for that. Using that did'nt work either. Even putting the needle into the front (back) fitting the grease was pretty much not getting into the joint.
    Any advise as to how to get the front back zerk efficiently ?? is there a way to remove the cross member maybe? confused and needed advise....thanks
    farnsrocket likes this.
  15. Sep 25, 2021 at 9:24 AM
    #165
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Any advise as to how to get the front back zerk efficiently ?? is there a way to remove the cross member maybe? confused and needed advise....thanks[/QUOTE]
    if it’s the same one I’m thinking it is, there’s a small heat shield you can remove to get at that zerk. It’s 2 bolts I think. Learned that from another member on here.
  16. Sep 25, 2021 at 10:06 AM
    #166
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I get that one by rotating the shaft to point the zerk up and toward the driver’s side, then get straight on it with a long grease hose on the gun. You’re working by feel, but it’s not bad.
    Barrett50 likes this.
  17. Aug 30, 2022 at 12:12 AM
    #167
    cougarhound
    cougarhound New Member
    you can always grind the grease gun fitting to make it slimmer. It would definitely have made things easier on my 4runner's driveshaft. I was able to squeeze it in there though. Having another person around to squeeze the gun while you hold the hose onto the zerk helps greatly. Listen for air and watch for grease oozing out or you will make a mess. My rear ujoint basically shattered cause I didn't grease them for over 15 years. Pain to replace... So yeah I would say that it is important.
  18. Sep 4, 2023 at 7:03 PM
    #168
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Thread necromancy - does this require removal of cat shields to do? Cause if so, it's gonna wait until my next transfer case fluid change.
    Powder Hound likes this.
  19. Sep 4, 2023 at 7:37 PM
    #169
    Powder Hound
    Powder Hound New Member
    2015 Limited TRD Double Cab
    I have just recently installed my cat shields, it is pretty hard or impossible to access the second front zerk fitting. If you’re planning to install cat shields lube everything prior and perhaps think about changing fluids as well.
    TheBeast likes this.
  20. Sep 12, 2023 at 6:08 PM
    #170
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
  21. Jun 6, 2024 at 1:28 PM
    #171
    Andhon
    Andhon 2014 Platinum MGM CM
    Andy
    2014 Tundra Platinum MGM CM
    I assume I have to take apart my drive shaft to grease the slip yolk? I have a 2014 crew max 4x4
  22. Jan 9, 2025 at 1:45 PM
    #172
    akshorts
    akshorts New Member
    2021 CMAX with 6112/5160s
    Just crawled under my 2021, didn't see a single zerk. Assuming the 2020+ are sealed or am I blind?
  23. Jan 9, 2025 at 2:21 PM
    #173
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Same here. I had the same reaction after picking up a ‘21 a couple months ago.
    My 2016 Tundra had Zerks… and a transmission cooler, too, lol.
  24. Mar 20, 2025 at 2:55 PM
    #174
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    So am I good on my 19’? Realized I’ve never greased anything and freaked out. Then saw I have no zerks. What about the propeller shaft? Anyone have a diagram on that?
  25. Mar 21, 2025 at 11:18 AM
    #175
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Don't believe the 19's have grease fittings on the propeller shaft. If you did, look at all 4 out sides of the U joint, they would be there with a fitting going into the U joint cap
