Want to learn how to properly lube the drive shaft in my Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1999cutiger, Aug 12, 2018.
  1. Aug 16, 2018 at 4:23 PM
    #61
    TTund16
    TTund16 New Member
    Which zerk is hard to access? Is it on the front? @gosolo @SOB
  2. Aug 16, 2018 at 4:59 PM
    #62
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    This blue one is like mine, I have had for over 40 years. I’ve bought other tips over the years.
  3. Aug 16, 2018 at 6:01 PM
    #63
    VRC
    VRC :)
    Vic
    Northern New Jersey
    2017 MGM CM Limited TRD Off Road
    I have a 2017 CM 4WD and the rear shaft does not have any zerk fittings. I have check all of the rear bearing caps and inside each U-joint and there are none. I do have the zerks on the front shaft. Anyone else have this?
    GAknight likes this.
  4. Aug 16, 2018 at 9:16 PM
    #64
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Curious...Maybe Toyota switched to closed universal joints at some point.
    I'm not sure why they would only do it for the main shaft and not the fronts too. Either way, sounds like it will save you some time/ maintenance in the long run.
  5. Aug 16, 2018 at 10:53 PM
    #65
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Rear u-joint on the front driveshaft (4x4 models) at the transfer case is the hardest to reach, but I get it on just fine without resorting to a needle. I do have a lot of practice getting my long grease hose into tight spots though. Rotate the driveshaft for the easiest access.
    Nothing wrong with using a needle either, there’s a lot more room to wiggle it around in there. :)
  6. Aug 17, 2018 at 1:24 AM
    #66
    TTund16
    TTund16 New Member
    landphil likes this.
  7. Aug 17, 2018 at 4:37 AM
    #67
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    Yeah what @landphil said - the one that goes into the front of the transfer case. I have tried rotating the shaft to all angles and can't seem to get it to an opening where it's straight enough that my gun will reach the zerk. Gun has a flexible hose like the ones posted above.
    TTund16 and landphil[QUOTED] like this.
  8. Aug 17, 2018 at 6:52 AM
    #68
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    They all do. My dad keeps his in an old sock and on top of a piece of cardboard to store it (pretty sure it's the original box). its disgusting and i always use gloves because it's so damn slippery, but it works. That thing has got to be 40 years old but will probably outlast anything made today, they don't make 'em like the used to.
    TTund16 and landphil like this.
  9. Aug 17, 2018 at 7:15 AM
    #69
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @TTund16 this is the one, described here. On my truck there’s no way to lube this zerk without a needle. Interesting that there’s a difference between some of these trucks. @landphil has room but I don’t. Possibly a different yoke mfg?
  10. Aug 17, 2018 at 7:39 AM
    #70
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Might be differences in the grease coupler as well, I use Lincoln couplers that are fairly streamlined, but some on the market are a bit larger OD. :notsure:
    I believe that all of these drivelines are Dana/Spicer, mine are for sure, proven by the large decal on it.
    TTund16, B737 and 15whtrd like this.
  11. Aug 17, 2018 at 7:50 AM
    #71
    15whtrd
    15whtrd Mr. Blonde
    I think it’s like what @landphil said. You and I have the same year truck. It is difficult but not impossible. Definitely need some strong fingers to get it snapped into place but I am able to accomplish it.
  12. Aug 17, 2018 at 9:02 AM
    #72
    reaper3030
    reaper3030 New Member
    Charles
    Tundra 2018 SR5 4X4 Concrete Crewcab
    Rock star wheels, off road tires, LED interior lights, LED fog lights, and .50 cal antenna.
    So that needle would poke through the zerk fitting or do you have to stick it somewhere else around it?
  13. Aug 17, 2018 at 9:24 AM
    #73
    SOB
    SOB Big Member
    Ohio
    You stick the needle in the hole of the zerk and pump in grease. I plan to get one later today and if I re-grease this weekend like I plan to I'll report back.
    TTund16 likes this.
  14. Aug 17, 2018 at 9:55 AM
    #74
    reaper3030
    Charles
    Nice, my work sells grease guns so I got this red lithium grease with that black gun and 2’ hose and a Locknlube for $36.
    landphil and Pudge like this.
  15. Aug 17, 2018 at 12:08 PM
    #75
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Very informative post Phil :thumbsup::rofl:
    landphil[QUOTED] likes this.
  16. Aug 17, 2018 at 2:08 PM
    #76
    1999cutiger
    1999cutiger [OP] Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    Bought this for my shaft...
  17. Aug 18, 2018 at 8:38 AM
    #77
    SOB
    SOB Big Member
    Ohio
    Tried the needle and it just squirted grease all over. Couldn’t get it into the zerk far enough. However, after taking more time to get the shaft in the perfect position I was able to grease that zerk with no special attachments. So it is possible - the zerk needs to be in about the 2 o’clock position (when viewed from underneath and feet towards the front of the truck).
  18. Aug 18, 2018 at 10:53 AM
    #78
    1999cutiger
    YES!
    This is what I found as well with my 2017 4x4 Crewmax. I have only been able to find one zerk on either end of the 4WD shaft. I have not found any zerks on the main drive shaft.
    Is this all of them? What am I missing?
    reaper3030 likes this.
  19. Aug 18, 2018 at 1:00 PM
    #79
    reaper3030
    Charles
    I got a 2018 and interested as well, before I climb under there...
  20. Aug 18, 2018 at 5:11 PM
    #80
    TTund16
    TTund16 New Member
    wonder if the drive shaft may have a different length or angle between DC and CM models or different year models! Tundra keep getting wider and longer. I read newer Tundras are 1/2 or 1" longer than Ford and 1/2 or 1" wider than Silverado or something to that effect. My neighbor has an older Tundra a little bigger than Tacoma!
    gosolo[QUOTED] likes this.
  21. Aug 18, 2018 at 9:38 PM
    #81
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m gonna have to try again, based on that
  22. Aug 25, 2018 at 2:07 PM
    #82
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Came to ask about this. I bought my 2018 a month ago. Just climbed under the truck, figured I'd go ahead and lube the prop shaft (I let it go too long on my first Tacoma once and had to replace the u-joints). I can't find any grease fittings on the rear. Didn't get up to really examining the front shaft ahead of the transfer case.
  23. Aug 25, 2018 at 2:10 PM
    #83
    15whtrd
    15whtrd Mr. Blonde
    4 x 4 or 2 x? My understanding is the 2 x has none.
  24. Aug 25, 2018 at 2:19 PM
    #84
    PA452
    PA452 New Member
    4x4
  25. Aug 25, 2018 at 6:33 PM
    #85
    15whtrd
    15whtrd Mr. Blonde
    Hmm that’s weird
  26. Aug 26, 2018 at 3:07 PM
    #86
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    So do you have to remove those C clamps to get at the rest of the zerks? I can only find 3 total on 3 shafts, none on the front, 1 in each end of the 2 sections of rear.
  27. Aug 26, 2018 at 3:53 PM
    #87
    Rica25
    Ricardo
    Tulare
    Do 2wds also have to be serviced and how if so?
  28. Aug 26, 2018 at 4:56 PM
    #88
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    No....
    The zerks will either be on one of the four ends, or in the middle...if you have them. @VRC noted that his '17 rear joints didn't have any zerks. Which is entirely possible. There are closed universal joints. Perhaps Toyota switched up the joints sometime in the last few years?
  29. Aug 26, 2018 at 4:57 PM
    #89
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    BTW, mine is 2016.
  30. Aug 26, 2018 at 10:38 PM
    #90
    Rica25
    Ricardo
    Tulare
    So u was looking at manual and only shows 4wd needs service......so my guess is 2wd dont need service or do they not have the fittings ?
