Want to learn how to properly lube the drive shaft in my Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1999cutiger, Aug 12, 2018.
  1. Aug 14, 2018 at 4:49 PM
    TTund16
    TTund16 New Member
    Have you guys tighten the bolts @csuviper posted?
    never done it with my old Tacoma!
  2. Aug 14, 2018 at 7:27 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    It is in the maintenance manual to tighten I believe but I haven’t done it myself.
  3. Aug 15, 2018 at 5:04 PM
    1999cutiger
    1999cutiger [OP] Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    Can anybody confirm if the needle is required for lubrication on at least one zerk on a 2017 4x4 Crewmax?
  4. Aug 15, 2018 at 5:31 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    needle? just jam the zerk fitting thing on the zerk and pump the gun. be sure to clean off factory paint from the zerks on the truck.
    landphil, WAtundra4x4 and 15whtrd like this.
  5. Aug 15, 2018 at 5:33 PM
    1999cutiger
    Yes...a previous poster mentioned a zerk that requires a needle.
  6. Aug 15, 2018 at 5:37 PM
    B737
    Jersey Shore
    you just need a grease gun
    landphil and 15whtrd like this.
  7. Aug 15, 2018 at 10:13 PM
    Tundra101
    Tundra101 New Member
    ODee
    Upstate NY
    2017 Quicksand Tundra SR5 4X4
    Pro Comp 6” Lift
  8. Aug 15, 2018 at 10:45 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  9. Aug 16, 2018 at 4:35 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    @gosolo I'd like to hear more about this needle too. Does the needle just push into the zerk on the U-joint? Last time I greased my shaft (giggity) I couldn't get to one of the zerks.
    TTund16 and Sas like this.
  10. Aug 16, 2018 at 5:07 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    $9 single tube?!?!?! Try to find it local, convince a small auto part store to start carrying CAM2 products. I payed $6.89/tube last month. It's good grease, but it's not $9 a tube good grease.
    http://www.cam2.com/
    They are a full line petroleum company. I like CAM2 products a lot. They were readily available to me in PA. 2 Gas stations near me even had CAM2 race fuel at the pump, I believe this is now just Sunoco Race Fuel.
  11. Aug 16, 2018 at 5:38 AM
    Tundra101
    ODee
    Upstate NY
    Pro Comp 6” Lift
    I know, Did you see what they charge for shipping?! $25!
    OBXTundra[QUOTED] likes this.
  12. Aug 16, 2018 at 6:52 AM
    gosolo
    Ray
    NW Oregon
    Yep, that’s what you do. That’s a very difficult zerk to access.
    SOB[QUOTED] likes this.
  13. Aug 16, 2018 at 7:33 AM
    tundras00
    tundras00 New Member
    How much grease should you have at hand when doing this? What grease gun are you guys using?
  14. Aug 16, 2018 at 7:40 AM
    gosolo
    Ray
    NW Oregon
    you can probably lube your truck 4 times with 1 tube.
    I prefer the small 1 hand grease gun and always add a flexible line.
    Brand doesn’t matter, but cheap ones don’t last long.
    Lots of dirt contractors are supplying the field guys with battery pack electric guns.
  15. Aug 16, 2018 at 7:40 AM
    csuviper
    Broomfield, CO
    One tube. You barely use any of it.
  16. Aug 16, 2018 at 7:41 AM
    csuviper
    Broomfield, CO
    Mine looks like this. Not sure of brand
    tundras00, 15whtrd and gosolo like this.
  17. Aug 16, 2018 at 9:43 AM
    SOB
    SOB Big Member
    Ohio
    Electric ones are very nice esp. if you do a lot of greasing. My dad has one at the farm since equipment is constantly being greased. They aren't cheap though so I can't get myself to buy one for home.
  18. Aug 16, 2018 at 9:54 AM
    tundras00
    Most simple ones don't last long like you said from all the reviews. I looked into Milwaukee M18 line if there is a gun but it is too expensive for a bare tool that will be used once a year.
    Found this from Lincoln: https://www.amazon.com/gp/product/B0002NYDZ8/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
    For $20 more you get a bundle with the needle like someone suggested here: https://www.amazon.com/gp/product/B00KHJL3ZK/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&th=1
    Looks to be reliable.
  19. Aug 16, 2018 at 9:56 AM
    #49
    csuviper
    Broomfield, CO
    Problem i have is every one of the manual style lube guns leak. Think its when it gets hot and the grease gets thin it is able to seep out.
    jtwags and 15whtrd like this.
  20. Aug 16, 2018 at 9:59 AM
    #50
    tundras00
    rmcgrath and OBXTundra like this.
  21. Aug 16, 2018 at 10:17 AM
    #51
    OBXTundra
    OBXTundra Member
    Southeast USA
    I like Lucas grease as well. This or the Red 'n Tacky is good stuff. The Red actually looks like it goes through more testing, has higher ratings, and a higher dropping point.
    https://lucasoil.com/pdf/TDS_XtraHDGrease.pdf
    https://lucasoil.com/pdf/TDS_Red-Tacky-Grease.pdf
    SouthBoundSteve likes this.
  22. Aug 16, 2018 at 10:40 AM
    #52
    15whtrd
    15whtrd Mr. Blonde
    The red is what I use for my truck. Seems to be good stuff. Although what the hell what I know I’m no grease analyzer LOL. I have a cheap gun from O’Reillys. I’m able to get to each zerk fitting. Some are tough but I’m able to snap it on there. Just had to make sure the paint was scraped off each one the first time.
    My gun does seem to weep a little bit when hanging on the wall. I just put a bag around it.
    I grease at each oil change. GTG!
  23. Aug 16, 2018 at 1:07 PM
    #53
    tundras00
    Are the Lucas oil with moly content? Didn't see it anywhere on the label.
  24. Aug 16, 2018 at 1:21 PM
    #54
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    SmartSelect_20180816-151941_eBay.jpg You can pick this up from Summit for $20, or make one out of PVC
  25. Aug 16, 2018 at 2:24 PM
    #55
    Professional Hand Model
    Hand Protectors
    Go to AutoZone and get one. Send me a check for saving you money.
  26. Aug 16, 2018 at 2:26 PM
    #56
    Hand Protectors
    Put your gun in a plastic bag during storage to catch the mess. Thats what she said.
    15whtrd and deepblu89 like this.
  27. Aug 16, 2018 at 2:38 PM
    #57
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    and no one jumped on that? god, you guys are slacking.
    fall is coming so, you'll want this...
  28. Aug 16, 2018 at 2:42 PM
    #58
    Pudge
    CT
    2015 Blue Ribbon Platinum
    It's almost that time of year
    smslavin[QUOTED] likes this.
  29. Aug 16, 2018 at 3:02 PM
    #59
    15whtrd
    15whtrd Mr. Blonde
    It was too easy! Almost not as fun.
    Nevertheless... got to make sure you keep it lubed
    aperezsh likes this.
  30. Aug 16, 2018 at 4:18 PM
    #60
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Ok gents....So I just did this last night. Easy peasy!
    Few points and thoughts:
    • SAFETY FIRST: Parked it, chocked the wheels and put it in Neutral (so I could spin the drive shafts).
    • Any good, single arm grease gun like the one @csuviper listed (above), is the way to go.
    • Having a flexible hose is a must, if the grease gun you get doesn't already come with one. If your rig is lifted, I recommend getting a hose at least 18".
    • The standard grease gun fitting (like the one in the pic above) will fit all the zerks on our rigs.
    Regarding the zerk's locations and accessibility:
    • The diagram (pdf) listed earlier in the thread is for an '07 (and I'm assuming all Gen 2's). The only difference for the Gen 3's is the center universal joint/shaft connection on the main drive shaft doesn't have 3, like in the diagram.
    • So, for the Gen 3's there are a total of (5): (3) along the main drive shaft, and (2) for the front drive shaft (for those w/ 4X4).
    • The (3) along the main drive shaft are easily accessible as they are all on the end of one of the four heads, like in the pic below.
    • I parked mine such that the zerk faced down. Perhaps coincidental, but all three along the main shaft were in line and faced down, so I was able to move along pretty quick.
    • The front drive shaft is a bit more tricky...especially the one coming off the transfer case b/c of the cross member's perfect placement. Also, the zerks on these joints are in the middle like in the pic below.
    • Using an angled fitting will make it more easily accessible. The other option is to rotate the shaft so the zerk is facing upward. I found this makes getting the fitting off a harder task b/c you don't have as much room to pull/push it off the zerk when you're done, regardless of what fitting you use.
    • The front joint zerk is easily accessible. Just rotate the shaft so that the zerk is facing downward and go at it.
    Regarding the Grease:
    • I used the Lucas Oil, Red 'N Tacky: NLGI #2.
    blcooper7, vtl, Nic146 and 14 others like this.
