Want more power from 2006 vvti 4.7L v8
Discussion in 'Performance and Tuning' started by because_wumbo-truck, Oct 22, 2018.
  1. Apr 19, 2019 at 2:28 AM
    #61
    because_wumbo-truck
    because_wumbo-truck [OP] TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Anybody run the URD 170°F thermostat?
    Thinking about buying one along with the DDI 270cc injectors
  2. Apr 19, 2019 at 7:31 AM
    #62
    dirtydeeds
    Keith
    USA
    more than I can list here
    I wouldn’t run the thermostat unless you’re boosted.
  3. Apr 19, 2019 at 10:02 AM
    #63
    because_wumbo-truck
    Jon
    Houston, Texas
    Got it. Thanks. Now I just gotta figure out if there's a way I can run long tubes on my truck in an emissions county. I think I just need an o2 simulator.
  4. Jun 21, 2019 at 9:40 AM
    #64
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Did this ever happen?
  5. Jun 24, 2019 at 3:00 PM
    #65
    because_wumbo-truck
    Jon
    Houston, Texas
  6. Jun 26, 2019 at 4:54 PM
    #66
    Matty4wd
    Matty4wd Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    Anyone know what exhaust setup would give me the most power , i know i want duals but idk if i want an H- Pipe, Or X- Pipe. Can someone help?? Im doing a cat-back exhaust setup and i dont want to put any mufflers
  7. Jun 26, 2019 at 9:04 PM
    #67
    because_wumbo-truck
    Jon
    Houston, Texas
    you need to speak with Keith @dirtydeeds
    Personally I want headers and his full race exhaust with cats. But I have a ton of questions first.
    Matty4wd[QUOTED] likes this.
  8. Jul 17, 2019 at 5:37 PM
    #68
    Mr. Pink
    Mr. Pink New Member
    Ontario, CA
    06 DC 4x4
    Tint, stereo system, lift , more to come
    Benefits of coolant bypass?
  9. Sep 17, 2019 at 11:19 AM
    #69
    because_wumbo-truck
    Jon
    Houston, Texas
    Bump
  10. Sep 17, 2019 at 12:12 PM
    #70
    because_wumbo-truck
    Jon
    Houston, Texas
    I just see it for 2014 tundra
  11. Oct 6, 2019 at 12:36 PM
    #71
    Red05
    Red05 New Member
    2006 Double Cab
    This truck is a 4.7 not the 5.7, in case anyone didn't watch the video.
  12. Oct 6, 2019 at 4:19 PM
    #72
    because_wumbo-truck
    Jon
    Houston, Texas
    Dude went 1m miles on 2 water pumps... Doesn't mention timing belts. Either way that's insane.
    OR18TRD[QUOTED] likes this.
  13. Oct 6, 2019 at 5:25 PM
    #73
    because_wumbo-truck
    Jon
    Houston, Texas
    Those air seats aren't all they're cracked up to be imho. Plus the semi has such stiff suspension. I mean I've never driven a semi but I climb in and out of em all the time.at work. And I've driven plenty of different size box trucks. The slightest crack in the road will go up your spine.
  14. Oct 6, 2019 at 7:00 PM
    #74
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    So headers. Injectors. That’s pretty much it for easy bolt on power yes?
  15. Oct 6, 2019 at 11:25 PM
    #75
    because_wumbo-truck
    Jon
    Houston, Texas
    :laugh:
    Chemical plant security
  16. Oct 6, 2019 at 11:26 PM
    #76
    because_wumbo-truck
    Jon
    Houston, Texas
    I think so unless you wanna include a full exhaust system and cold air intake.
    URD has a stage 3 supercharger with inter cooler kit for the vvti 4.7 4runner and gx470 that could probably be modified to fit our trucks. Supposedly they're working on the kit for our tundra.
    15whtrd likes this.
  17. Oct 6, 2019 at 11:27 PM
    #77
    empty_lord
    05 rollover special
    "cold" air intakes ive never seen make more power.. intake tube with the stock box? likely a small bump. and yes full exhaust.
  18. Oct 6, 2019 at 11:28 PM
    #78
    because_wumbo-truck
    Jon
    Houston, Texas
    Yes.
    See edited post.above about Underdog Racing Developments supercharger kit
    Oh and gears.
    Also I have the URD 170°F tstat and iridium plugs
    OR18TRD likes this.
  19. Oct 6, 2019 at 11:32 PM
    #79
    empty_lord
    05 rollover special
    i'll pop the motor open before i do boost. but we'll see. ill tinker with what i can to make it more powerful. lol i tend to....
  20. Oct 7, 2019 at 6:10 AM
    #80
    empty_lord
    05 rollover special
    They do really make a massive difference when running larger tires for sure
  21. Oct 7, 2019 at 7:28 AM
    #81
    thexcolexman
    thexcolexman New Member
    2005 Tundra Double Cab
    I looked at Alientech online but they don't show First Gen Tundras as a supported vehicle. Which tuners will be available from them?
  22. Oct 7, 2019 at 7:57 AM
    #82
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I came to the same conclusion.
    Yep. I thought cold air intakes had largely been debunked?
  23. Oct 7, 2019 at 8:33 AM
    #83
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Your telling me. I was trying to help in another thread and they did the same thing. Tundra Envy? LOL Haters gonna hate! Funny both post asked how can we get more power but both posts also swear by the smaller engine and both OP's dont want shitter gas mileage. Where is this magical MOD that gives you power, gas mileage, is very cheap, and does not affect reliability?
    https://media.giphy.com/media/12NUbkX6p4xOO4/giphy.gif
    15whtrd and OR18TRD[QUOTED] like this.
  24. Oct 7, 2019 at 9:44 AM
    #84
    because_wumbo-truck
    Jon
    Houston, Texas
    True. What I should have said was upgraded intake tube on stock air box or a "true" CAI kit. Not sure if any of those two options exist for our trucks. I had the Airaid modular intake tube on my 99 taco and stock air box. Then the aFe pro dry S intake kit on my 03 taco. Both sounded great. I didn't have a scan gauge when I had the 99 to read the intake temps but I did on the 03 and I do on my tundra. The stock air box definately keeps the temp down better when stopped.and city driving by about 10°F maybe more. But at high ways speeds the intake temps are almost the same if not the same. However the CAI kits tend to be stupid expensive. Like $200-400 vs maybe $100 for the tube and a new filter.
    OR18TRD likes this.
  25. Oct 7, 2019 at 9:46 AM
    #85
    because_wumbo-truck
    Jon
    Houston, Texas
    Please don't derail my thread with your irrelevant 2nd and 3rd gen stuff. You're not helping. And you're cluttering up the thread with off topic chatter. :)
    OR18TRD likes this.
  26. Oct 7, 2019 at 10:25 AM
    #86
    empty_lord
    05 rollover special
    Airaid makes a tube for these trucks. K&ns cold air also reuses the factory air box. Personally I’ll run the airaid just because I like the sound. Have one on my taco too. Don’t expect gains. I may look into knife edging the throttle and boring it slightly
  27. Oct 7, 2019 at 1:19 PM
    #87
    Tundyfundy
    Bay Area, CA
    Copy that. I’m with the Panda, later guys.
    OR18TRD likes this.
  28. Dec 8, 2019 at 8:42 AM
    #88
    because_wumbo-truck
    Jon
    Houston, Texas
  29. Aug 17, 2024 at 11:20 AM
    #89
    stevechumo
    stevechumo New Member
    I've swapped hydraulic fans to electric fans on several Lexus V8 to make rooms for turbo and superchargers. Before putting the turbo/superchargers on, I didn't see any improved performance. Electric fans are complicated to set up correctly and they're unreliable. And without the fan shroud, the coolant gets hot. Basically, electric fans swap is the last thing to do.
  30. Aug 17, 2024 at 12:18 PM
    #90
    JustDSM
    JustDSM New Member
    Justin
    Just as a FYI, I saw there was some previous chatter about tuning support (and the lack thereof back in 2019).
    It should be noted that times have changed, and we have full support (engine and transmission) control for 2003+ 4.7L platforms (Tundra, Sequoia, Land Cruiser, LX470, GX470, 4.7L 4Runner, etc.). We have optimized fueling targets, reworked ignition timing tables, VVTi targets, multiple throttle sensitivity options (including setting Tow/Haul independently), reworked shift schedule options, TCC lockup/release, and more.
    We can provide you the hardware for "DIY"ers who'd like to flash themselves, or you can get our dyno proven calibrations at one of our 60+ international retailers. Find one near you! https://overlandtailor.com/retailer-locations
    *NOTE* - K-Line (Non-VVTi 4.7) vehicles must be flashed in person with one of our retailers.
    We're happy to answer any questions you may have. Send us an email to info@overlandtailor.com.
    Here's a recent example:
    2006 Toyota Tundra 4.7L Double Cab 4x4
    -Stock vehicle, aftermarket muffler in OEM exhaust, 34" A/T tires, 91 Oct Fuel
    RED - Stock Calibration
    BLUE - OTT Base Calibration
    PNW15 likes this.
