Vote please, I cant decide
Discussion in 'Audio & Video' started by herd, May 5, 2023.
  1. Jun 5, 2023 at 6:39 PM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    On the drivers door above the door lock button is another button. That locks out control of the windows from the other switches. It's been accidently engaged. Just push the button and all shall be as it was before.
  2. Jun 5, 2023 at 6:44 PM
    herd
    herd [OP] New Member
    I wish this was the problem but sadly it isn't.
  3. Jun 5, 2023 at 8:07 PM
    Jack_A_Lope
    Aaron
    Are you sure about that? Because that is exactly what happens when that button get's pushed in. I know because it happened to me. So if you haven't actually checked it to make certain I would go do that.
  4. Jun 6, 2023 at 12:46 PM
    herd
    I'm sure, have tried it loads of times to no avail. I've purchased a new power window switch wondering if somehow in the process I messed it up.
  5. Jun 7, 2023 at 12:57 AM
    Jack_A_Lope
    Aaron
    Have you checked the fuses? You are going to have to take a multi meter and do some diagnostics. First you will need to verify that the fuses are good then using a multi meter verify that there is power at the switch and that the switch is working. Then verify that there is power at the window. It's just a matter of starting at one end of the circuit and working your way to the window. You might want to also verify that the lockout switch hasn't gone out on you. I'm not sure if the switch is normally open or normally closed but try and disconnect it and see if that has any effect on it.
  6. Jun 7, 2023 at 4:06 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    Wondering which of these units mentioned use the factory back up camera?
  7. Jun 7, 2023 at 5:08 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    All of them.
  8. Jun 11, 2023 at 5:24 AM
    herd
    t's official, I'm an idiot. Solved my problem yesterday by removing one of the back doors and realized I hadn't connected the wiring harness to the door. Same thing for all three doors. User error strikes again.
