Vibration in steering wheel
Discussion in 'General Tundra Discussion' started by koreanthunda, Mar 25, 2019.
  1. Mar 26, 2019 at 9:39 AM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    Mine feels like an over active power steering pump or the valves in the rack are not allowing fluid to flow smoothly :crazy:
  2. Mar 26, 2019 at 1:58 PM
    2manytoys
    2manytoys New Member
    Lupe
    Carlsbad, New Mexico
    2017 black tundra crewmax
    Fab fours premium bumpers frt & rr, retracing bed cover, 5% window tint cept frt which is 60%, has lift from dealer maybe 3 inch
    Had same problem on my 2017 the dealer had leveled it and installed off-road tires before i bought it. They tried road force balancing and every time it would work for a little while, then it would start vibrating. I just aired them up between 45 and 50 psi and the vibration quit. It comes back when the dealer rotates the tires at the oil change. So i just air them up again. Just got back from a trip to Beaumont, TX. ran smooth as can be, except the hood bulge popped up, broken brackets.
  3. Apr 4, 2019 at 3:54 PM
    koreanthunda
    koreanthunda [OP] New Member
    Joseph
    2018 Toyota Tundra limited
    Did they charge you for the alignment ?
  4. Apr 4, 2019 at 3:55 PM
    koreanthunda
    Joseph
    Did you have any problems with un even wear because of this ?
  5. Apr 4, 2019 at 3:57 PM
    koreanthunda
    Joseph
    Did the dealer charge for the alignment ? Also I’ve heard of others airing up the tires and don’t want to void my warranty . Yes the tires I believe are complete sh— . And test drove a tundra with 4wd and Michelin’s and it drive fine but . I’m writing to Toyota and complaining for spending $50,000 on a truck it’s not acceptable in my opinion .
  6. Apr 4, 2019 at 10:01 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    No they did it under warranty.
  7. Feb 18, 2020 at 10:08 AM
    1st tundra owner
    1st tundra owner New Member
    Richard
    2017 tundra limited
    i know the felling my 2017 tundra has the "EXACT" issue been to dealer 4 times they can see it but cant fix it. i have had it balanced 5 times replaced the tires with Michelin's, replaced the rotors, and its still there even when you rotate tires, between 60-70 mph doesn't seem to be as bad as it once was but still there. when you are in a slight turn it seems to be almost completely gone
  8. Feb 18, 2020 at 10:46 AM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    I had this on an older vehicle and it was the tires were out of round when cold and you first take off then after a bit they were fine. If that is not the problem have you tried to have the tires Road Force Balanced and see if the problem goes away?
  9. Feb 18, 2020 at 6:27 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Just had three tires replaced for excessive Road Force Pressure. Now it seems a lot better. I wish the tech would take a little more pride in his work because now I have left over wheel weight balance weight sticky on the inside of my wheels. I can look at weights but ragged weight tape is just nasty.
  10. Aug 5, 2020 at 7:11 AM
    dekeray
    dekeray New Member
    2018 limited 4x4
    Trd rear sway bar
    I have the exact same truck and problem. Replaced original tires with Michelins. Same problem. Also noticed that driver front leans down almost an inch when full. Att the dealer now. Suspect shock/spring/suspension problem.
