Vibration after wheels and Tires
Discussion in 'Wheels & Tires' started by greentrbo95gst, Jul 8, 2021.
  1. Jul 9, 2021 at 11:31 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
  2. Jul 9, 2021 at 12:40 PM
    greentrbo95gst
    greentrbo95gst [OP] New Member
    Huntington Beach
    I think I will try the road force balance next and maybe balance bags after
  3. Jul 10, 2021 at 12:13 PM
    Mr_Kane
    Mr_Kane New Member
    2019 TSS Crewmax
    :Eibach 2.5" Lift :SPC UCA's :34" Toyo AT3's :10" BA Muffler
    This is the reason why I have been avoiding aftermarket wheels so far. I have a 2.5" lift and have 34" Toyo AT 3's installed and it looks and rides great on the stock TSS wheels.
    However, I know new wheels and a better "looking" offset can make the truck "look" even better, but It's a $1,400+ gamble that I have not come to terms with..
    Ely010606 likes this.
  4. Jul 10, 2021 at 2:55 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Shouldn't need the balance bags after. Was studying up on the road force balance and its good shit. I can see why they have to charge extra for it though, special machine, mounting and dismounting each tire multiple times, requires a competent employee trained on machine (probably the hardest thing to find now days :crazy:). But, it should definitely fix your shit or at least tell you what wheel/tire is screwed up and needs replaced/warranteed.
    Hbjeff likes this.
  5. Jul 10, 2021 at 3:26 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I had the same problem also , I went back to the shop where i bought the tires, they balanced it again, same problem. Went to the dealership to get it balanced and alignment. Alignment was fine but still vibrating. Then I went to DTC and they do the road force balance, holy moly what a big difference. The DTC
    where i go to do not do alignment. I was gonna go back to the dealership to get aligned again but didn’t need to. I say get it road force balanced if you have a DTC around you
    Gravy likes this.
  6. Jul 18, 2021 at 8:32 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    So mine has been having bad vibrations since I got new tires started about 6 months after buying them I’ve had them re balanced and everything multiple times everything checks out then the other day I was playing with tire pressure. I was at 35 or 36psi and I lowered down to 32 psi and no more vibes!!!!!! So give that a go if you have issues.
    Hbjeff and Ely010606 like this.
  7. Oct 5, 2021 at 6:18 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    Figured I would update this thread if anyone cares. I was still battling wheel vibration up until this past weekend. I took my truck in for an alignment to bring the total toe down to .14 from .28 to try and help with tire wear. Went for a test drive on the freeway afterwards and guess what? No more vibration at any speed. I have since put 250 miles on the new alignment and still running smooth. I'm dumbfounded but happy it seems to be fixed after a year.
    FISHN43 likes this.
  8. Oct 16, 2021 at 7:59 AM
    Ghostsolo
    Ghostsolo New Member
    Did you ever figure out the balancing issues and shimmy??? I have a 2020 tacoma sr and.bought icon rebounds....icon told me.they are lug centric even tho the hub bore is the correct size as my axle ..my installer blew me.off when I told.him they are lug centric bc.the hubs the same but my ride feels off...when i get.to about.60 my steering wheel.shakes .yesterday he replaced a tire so im.hoping.that took away the shimmy.tire had high road force ....i wont know if its gone until.i drive to work Monday and get up to speed...did your issues go away after.lug centric balancing? Any thoughts on it a lug csntric balance will help even tho the hub bore is the right size?
  9. Oct 23, 2021 at 7:25 AM
    ultra1988
    ultra1988 New Member
    2019 tundra
    I had a similar issue with my Silverado, I battled it with cooper 33” tires for over a year until discount tire finally replaced two of them and the shimmy went away. I had another issue with cooper tires on my tundra and will never buy cooper again.
    newer grand cherokees have this inherent problem that the steering wheel shakes unless everything is perfect. I battled with stock size Michelin’s for a few months. Road force balancing made it ok for a normal person, but I still noticed a shimmy. It would take 10 minutes on the freeway for it to go away due to flat spots. Also two tires road forced balanced better than the other two so at rotation the shimmy came back. In the end they had to be road forced, at a specific psi, and driven around for 5-10 minutes before the shimmy would go away. It was a living nightmare.
    lessons learned: tire manufacturer matters big time, newer tires still develop small flat spots, tire pressure matters, I’ll never get aftermarket wheels.
  10. Dec 31, 2021 at 5:58 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Ditched my AT3s last week, with 5K on them, for AintYoMamma Geolander A/Ts. The Coopers couldn't be balanced. Working through DT, who say they road force balance, but I suspect it depends on who is working the machine. The Geolanders are much better than the Coopers, but there is still shake. The manager told me they see it with Toyotas, due to the lug centric nature of the wheels. Am kicking around taking it to 4WP, who did the conversion on the truck before I bought it, just to see if they know how to balance tires better than DT.
