VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Aug 18, 2020 at 8:07 PM
    #4321
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Does it work on the fly? Or do you have to come to a complete stop for it to turn off the nannies?
  2. Aug 18, 2020 at 8:20 PM
    #4322
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Yea there's a guy on the forum that sells the setup for like $90, I have it and it's the tits. If I don't want the lights on or to re-enable TC I just hit the stock button once and it turns everything back on.
    Only issue, which I'm hoping is solved in the next patch I get from OVT, is with TC totally off it seems to over ride the tune. The truck will sit in the lowest gear possible, even to redline at times. I have to be in S mode to get the truck to even shift past 4th, sometimes 3rd, even when under almost zero load and the truck is screaming at 5000rpm. What the deal is, I'm not sure, but I still like the auto-TC off enough to work around the quirks which I'm sure will get fixed in the ECu/TCU eventually.
    HulkSmurf14 and Wynnded[QUOTED] like this.
  3. Aug 18, 2020 at 11:31 PM
    #4323
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    ryanwgregg likes this.
  4. Aug 19, 2020 at 3:31 AM
    #4324
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
  5. Aug 19, 2020 at 6:21 AM
    #4325
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've seen some of the other stuff that they do which is pretty tempting. The illuminated emblems and badges, but they're not my style. Pretty neat looking though.
  6. Aug 19, 2020 at 12:11 PM
    #4326
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    We are working on the feature files for 19s. it will be released this month with all the rest.
  7. Aug 19, 2020 at 12:16 PM
    #4327
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Hello, will my ECU need to be updated before I can flash with vF? Other people answered but I want check with you for sure. And if it does and Toyota won't say it. Would there be any problem with me using a paid subscription of TIS and flashing updated firmware?
  8. Aug 19, 2020 at 12:41 PM
    #4328
    coTony
    Tony
    Montrose, CO
    The functionality is the same as push and hold the buttons except you do not have to. For instance if I have my switched turned on and start the truck it goes through the 7-10 second routine of press hold, release, press and hold for you. Once that completes (by the time your seat belt gets put on) and your good to go.
    if I have the switch off and I am driving and want it on, just like pressing the buttons manually you will need to come to a stop. So I will press it and when convenient to stop (stop light or sign), just pause long enough for the cycle to complete and your done.
    When off road I have the switch on all the time and turn it off before getting back on the highway.
    Wynnded[QUOTED] likes this.
  9. Aug 19, 2020 at 4:36 PM
    #4329
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Okay, got it. Thanks for the explanation.
    HulkSmurf14 likes this.
  10. Aug 19, 2020 at 8:37 PM
    #4330
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Just pull your ABS fuse for some good old school fun. That’s what I do when I hit dirt now - pull ABS1 and enjoy the analog truck.
    Ready to go home? Pop the fuse back in and cycle the ignition.
    The only problem with this is ATrac doesn’t work with the fuse out, so if you use that to climb or get through cross-axle obstacles, you have to pop the fuse back in. I’ve debated just putting the fuse on a momentary switch (it only takes a momentary interruption to fail the abs test at any time), but didn’t want the liability of tampering with a safety device should something happen on the street. Even if it’s in the ‘safe’ state by default, I don’t want to give insurance any reasons to deny something.
    JBSTOY and HulkSmurf14 like this.
  11. Aug 20, 2020 at 6:18 AM
    #4331
    JBSTOY
    JBSTOY Was tired, so I woke up.
    Jack
    Unknown Origen
    2008 Toyota Tundra SR5 4x4 5.7litres of goodness
    Bilstein 6112s Front Bilstein Rear Fuel Rims
  12. Aug 20, 2020 at 8:30 AM
    #4332
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    stupid ? alert! where is this list of ECU's located?
    i don't see it in the 1st post nor in any of the FAQ's areas on the OVtune website. help an old guy out here....:anonymous:
  13. Aug 20, 2020 at 12:12 PM
    #4333
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Jbtaco2002[QUOTED] likes this.
  14. Aug 20, 2020 at 2:40 PM
    #4334
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Doesn't that disable 4wd?
    KevinK[QUOTED] likes this.
  15. Aug 20, 2020 at 3:19 PM
    #4335
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It may not if the vehicle is already in 4WD prior to pulling the fuse. An experiment would be needed.
    KevinK and HulkSmurf14 like this.
  16. Aug 21, 2020 at 10:20 AM
    #4336
    Jbtaco2002
    San Diego
    nothing cool
  17. Aug 21, 2020 at 11:30 AM
    #4337
    snivilous
    SW UT
    Assuming it's anything like an abs wire being blown, the truck will be more or less stuck in whatever the transfercase was in before hand (it won't automatically shift the tcase). With that said you can sometimes trick it to shift through low range/4wd even if the abs is blown by restarting the truck and then trying to shift it, it's not quite the end of the world if you lose and abs sensor like the forum thinks.
    KevinK likes this.
  18. Aug 21, 2020 at 3:43 PM
    #4338
    KevinK
    Tundras to Sedona
    no effect on 4WD functionally other than ATrac won’t work. You can shift 2/4hi/4lo just like normal.
    We covered this a couple years ago Alex. LoL.
    Post 66
    https://www.tundras.com/threads/high-speed-off-road-brake-failures-aka-ice-mode.23287/page-3
  19. Aug 22, 2020 at 6:58 PM
    #4339
    Emptypockets
    Emptypockets New Member
    2012 CM Platinum
    The last time I researched OV they were selling a dongle and providing tunes as they were developed. I was very interested but had other upgrades to complete first. Now when I go to the website I don’t see a dongle anymore just software for 1200 bucks. I have a 2012 Platinum that needs some serious help and I really liked the transmission stuff they had. Can someone bring me up to speed?
  20. Aug 22, 2020 at 7:24 PM
    #4340
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    In nut shell? $370 for the VF tune software + $250 for additional tune pack for the Tundra. Sounds like All ECU’s should be supported by the end of the month?
    shellshock likes this.
  21. Aug 22, 2020 at 7:26 PM
    #4341
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    You buy the vF kit plus tundra tune pack. $620
  22. Aug 22, 2020 at 7:55 PM
    #4342
    Emptypockets
    2012 CM Platinum
    Thanks for the reply. One more question. What exactly does all ecu’s mean? Is that just for certain years? I have 2012.
  23. Aug 22, 2020 at 10:44 PM
    #4343
    MTRock
    MTRock 1889
    Montana
    Last I read was 2007-2019 by the end of the month...However OV was having some difficulty with the early ones? 2007-9? I’m sure he’ll chime in.. @OVTune
    mzim likes this.
  24. Aug 24, 2020 at 11:35 AM
    #4344
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    Has anyone had a problem where the orange dongle will not connect to the truck? I removed and reinstalled the drivers. The computer hasn't changed, but I flashed the registry key again, just to check. I'm using p5flash 1.2.2.
    None of the buttons: Identify, Read, Flash it, ETC are lighting up to allow me to press them.
  25. Aug 24, 2020 at 11:36 AM
    #4345
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Email us your system ID, sounds like it changed
  26. Aug 24, 2020 at 11:37 AM
    #4346
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    That was quick. I'll send it to you now.
    EDIT
    Order 4982 and email sent.
    EDIT #2
    Looking back through my email string, it did change. Any idea why it would? Windows updates?
  27. Aug 24, 2020 at 1:19 PM
    #4347
    shellshock
    Iowa
    2019 TRD PRO
    Windows updates. I don’t know that anyone has figured out exactly which one does it but it’s happened to a few people.
    Cuban11182[QUOTED] likes this.
  28. Aug 24, 2020 at 1:24 PM
    #4348
    Cuban11182
    Hope Mills, NC
    2018 Tundra Limited
    Okay, well at least it's not just me, lol.
    shellshock[QUOTED] likes this.
  29. Aug 24, 2020 at 2:01 PM
    #4349
    Rocklobster
    Rocklobster New Member
    Chad
    2018 Tundra Crew SR5 TRD
    If you would, please check. I did not find any emails in my spam folder. I am still waiting for the tune/calib file.
  30. Aug 25, 2020 at 2:20 AM
    #4350
    Fisherrrrrr
    Fisherrrrrr Not a New Member
    Doha
    2013 Tundra TRD S/C 4x4 Platinum
    Hello,
    Did anyone came across detonation issues with base tune file for S/C Tundra. The pinging was loud at RPMs above 4.5k. I reset all the fuel trims and alcohol density (yes, she's FFV) but the results are still the same. Initial run was with 91 octane fuel so I tried 95 octane (Middle Eastern fuel grades) and the pinging went away when pulling in 2nd gear but is back in 3rd gear around the same rpm range; this time much less noticeable but definitely can be heard. City driving is fine though, I love the gear shift. Truck is so much more responsive with that torque management setup :thumbsup:.
    The truck is stock except the S/C and TRD cat-back exhaust mods. Can outside temperature be the cause here? It gets really hot here. Intake at idle during daytime sees an upwards of 150F, although not sure how accurate the temperature sensor is :notsure:.
    I hope @OVTune got my logs sent to zendesk a week ago, very anxious for now as there is no way of knowing if Matt actually received it :goingcrazy:.
    Order #5865 Ticked ID #13228
Thread Status:
