Value of this tundra? 2010 5.7 RC LB
Discussion in 'General Tundra Discussion' started by bugtussell, Dec 19, 2020.
  1. Dec 21, 2020 at 7:00 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    I already have 2 pickup trucks lol. Just the other one doesnt run.
    I can probably dump my car and maybe my dirtbike...
    bugtussell[OP] likes this.
  2. Dec 23, 2020 at 5:31 PM
    bugtussell
    bugtussell [OP] New Member
    Brayden
    06 Tundra 4.0 V6
    ezdog likes this.
  3. Dec 23, 2020 at 5:53 PM
    NWPirate
    Zach
    WA
    Love the look of this truck.
    The bumper and the hitch look pretty rusted. Also it looks like it might be a flex-fuel by the badge on the tailgate, if that matters to you.
    Flex-fuel from the rust belt, I would pass.
    If you go, don't fall in love and feel obligated to bring a subpar truck home.
    Good luck!
  4. Dec 23, 2020 at 6:18 PM
    bugtussell
    Brayden
    06 Tundra 4.0 V6
  5. Dec 28, 2020 at 12:36 AM
    bugtussell
    Brayden
    06 Tundra 4.0 V6
    Todays the day!! Wish me luck
    Sumo91 likes this.
  6. Dec 28, 2020 at 3:31 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Good luck!!! Hope you love it and it works out!
  7. Dec 28, 2020 at 3:56 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Good luck. Hope it's better than you expect. Daft trip home.
  8. Dec 29, 2020 at 1:20 PM
    bugtussell
    Brayden
    06 Tundra 4.0 V6
    So after a #1000 mile 15 hour drive, (Nebraska to Georgia) I am very happy with the truck. Except for one very annoying problem. When i pump gas into it, the gas doesn't go into tank fast enough so it causes the pump to cut off cause it thinks its full. You wait a few seconds like 3 than pump for about 4 then it cuts off again (not exaggerating) and this is from gallon one with fuel light on had to fill up four times yesterday, the last three times all did this pump on off cycle no matter which pump
    Truck is cut off btw. Anything i should look into that might cause this to occur? Its some kind of issue with venting I would assume
  9. Dec 29, 2020 at 1:24 PM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    roll over valve I would assume. I could be wrong though.
  10. Dec 29, 2020 at 4:08 PM
    Half Assed
    Heartland Florida
    I had that problem on a GM truck. The vent solenoid was stuck. I removed and cleaned it and then it worked again.
    If its been on dirt roads they can seize up.
