Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. May 23, 2021 at 6:32 PM
    #871
    Yes, he is only doing Tundras at the moment.
    Brownsfanhere[QUOTED] likes this.
  2. May 23, 2021 at 8:35 PM
    #872
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Excellent write-up and pics! Thanks for doing that. I intend to install mine with the TRD Pro skid plate, so I realize my install will be a bit different for the front plate, but your write-up is very helpful.
  3. May 23, 2021 at 10:19 PM
    #873
    RobertD
    Robert
    DFW, Texas
  4. May 24, 2021 at 7:38 AM
    #874
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    So a few fixes, first you should have spacers installed for 4wd. Second the little black transfer case skid needs to be removed. Otherwise it looks good. With the supplied hardware, the 5/8’s bolts holt the front plate up pretty well, although, on the clear coated plates, I have had issues with the plates wanting to slide out
    equin likes this.
  5. May 24, 2021 at 8:32 AM
    #875
    CmdrD8TA
    CmdrD8TA New Member
    Columbus, OH
    2011 Tundra 5.7L 4x4
    What are the spacers used for? Drainage? I saw it in your install guide but couldn't figure out why "one spacer" would be mentioned if there are 2 rear bolts for the front plate.
    I didn't notice the transfer case skid so I will look at that later this week, hopefully under a lift and can take better pictures while I'm at it. I don't remember seeing any interference with the rear plate though.
  6. May 24, 2021 at 8:41 AM
    #876
    Classy63
    Tyler
    Cypress Texas
    I can guarantee your rear cat plate is laying on that skid plate and you will probably have some noises
  7. May 24, 2021 at 9:01 AM
    #877
    CmdrD8TA
    CmdrD8TA New Member
    Columbus, OH
    Now you're teasing me to get under the truck today.
    Also need more background on the use/purpose of the spacers.
  8. May 24, 2021 at 9:19 AM
    #878
    Classy63
    Tyler
    Cypress Texas
    It is only there for the 4x4 vehicles to space the rear plate to clear the transfer case
    equin, CmdrD8TA and RobertD like this.
  9. May 24, 2021 at 9:24 AM
    #879
    CmdrD8TA
    CmdrD8TA New Member
    Columbus, OH
    I'll look this afternoon, install a spacers for each rear bolt on the front plate regardless of what I see, update the install guide and report back.
    RobertD likes this.
  10. May 24, 2021 at 9:44 AM
    #880
    Classy63
    Tyler
    Cypress Texas
    I would really appreciate that
  11. May 24, 2021 at 11:02 AM
    #881
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    So which one is the better to go with? Steel is obviously heavier and I would assume harder to get past, but is also cheaper. Aluminum is lighter, easier to install and costs more? I'm lost as to which one to go with.
    Then the "front" covers the first two cats and the "rear" cover the 2nd set, right?
    farm&forest likes this.
  12. May 24, 2021 at 1:49 PM
    #882
    CmdrD8TA
    CmdrD8TA New Member
    Columbus, OH
    Install guide updated, same link:
    https://drive.google.com/file/d/1Q44OiLgkD9ia0CHAjS420XsJkm5M_FTW/view?usp=sharing
    Yes, the black factory transfer case skid was pressing against the rear plate (pic below). Didn't notice that until you mentioned it here and I think it was talked in prior pages of this thread but it was so long ago when I've read that. I now have that removed and sitting in a storage parts box.
    equin likes this.
  13. May 24, 2021 at 1:54 PM
    #883
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Tyler, what spacers exactly are you talking about? I dont recall getting any when i order the plates. Are these only necessary if you keep the transfer case skid from the factory in place? I removed mine when i did the install and did not use spacers, i dont notice any noises at all.....
  14. May 24, 2021 at 2:21 PM
    #884
    CmdrD8TA
    CmdrD8TA New Member
    Columbus, OH
    Based on post #404 I believe you ordered both the front and rear plates for your 4x4 so unless steel plates don't need a spacer maybe this wasn't thought of until a month later. I suspect it isn't a big deal not having the spacers installed as I can imagine there being enough clearance with the black factory transfer case skid removed.
    I specifically call out the use of the spacers in my install guide above if you're wondering what it looks like. You can always check above your rear plate to confirm it's not in contact with the transfer case to be sure.
  15. May 24, 2021 at 2:27 PM
    #885
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Just looked at your write up and I did not get those spacers. Doesnt seem like it matters though as I have not noticed any sounds. I will have to check the clearance now though as I am curious.
  16. May 24, 2021 at 3:27 PM
    #886
    Classy63
    Tyler
    Cypress Texas
    You should have gotten some square spacers with holes in them, if you didn’t and you are having issues with contact with the transfer case, let me know. I can send out new spacers
  17. May 24, 2021 at 3:38 PM
    #887
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    I only got the 4 large, square plates that go on top of the crossmembers to hold the plates in. I didnt get the 2 smaller sized square spacers like in the writeup above. Could you send them to me sometime soon when you have a chance? I am going to be likely taking off at least the rear plate to install cali raised sliders in the next month or so, i can pop them in then....
  18. May 24, 2021 at 3:41 PM
    #888
    Classy63
    Tyler
    Cypress Texas
    The square spacers in this picture are the ones I am talking about, I think you do have them from your description
    Brownsfanhere likes this.
  19. May 24, 2021 at 3:49 PM
    #889
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    I just have the regular sr5 front skid plate. When changing my oil,would have to drop the Valhalla front and rear as well ? Sorry, for the dumb question. Can’t tell in the pictures and I’m pretty sure gonna order both. Planning on keeping my truck for a long time. Peace of mind type mod.
  20. May 24, 2021 at 4:10 PM
    #890
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    The Valhalla plates are well behind the regular SR5 skid plate. Here is a picture from @paulbk in his post. The regular skid is shown at the far left of the image. In any case, for the OEM, non-TRD skid there is a gap.
    Tundra805, equin and Brownsfanhere like this.
  21. May 24, 2021 at 4:11 PM
    #891
    Brownsfanhere
    2015 Crew Max
    Thank you 3rdTundra. Placing my order this weekend then.
  22. May 24, 2021 at 4:16 PM
    #892
    CmdrD8TA
    CmdrD8TA New Member
    Columbus, OH
    You'll be able to change the oil since that isn't close to being covered by the cat plates. On my stock 2011 4x4 I have to remove the front skid plate to change the oil which is quite a bit forward of the cat plates. If I ever get on my truck on a lift I can take a nice undercarriage photo that should help show coverage.
  23. May 24, 2021 at 4:21 PM
    #893
    CmdrD8TA
    CmdrD8TA New Member
    Columbus, OH
    Here's a quick underside pic showing the oil drain plug in front of the front cat plate (bottom of the pic) and behind the front skid (top of the pic). The factory front skid is what needs to be removed to get to the oil filter.
    AggiePhil, equin and Brownsfanhere like this.
  24. May 24, 2021 at 4:26 PM
    #894
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Oh, ok, well i used these not in between the skid and the crossmember, but on the top of the crossmember, thought it was for strength/retention.
  25. May 24, 2021 at 4:46 PM
    #895
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    Just ordered the front aluminum skid. What are the odds it will arrive and in good condition.....Nothing I have ordered of any weight or value has arrived via UPS or Fedex in good condition. Even today, rear bumper is lost. Last week the front bumper arrived damaged. 13 for 13 via shipping companies.
  26. May 24, 2021 at 5:01 PM
    #896
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Tyler goes full retard on packaging so I think you should be fine. Mine was steel and while the box was beat up, no issues with product.
    Bammer and pearlpower[QUOTED] like this.
  27. May 24, 2021 at 5:23 PM
    #897
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    @Classy63 I just ordered a set of front and rear plates. Looking forward to getting them. :thumbsup:
    Classy63[OP] likes this.
  28. May 24, 2021 at 5:40 PM
    #898
    3rdTundra
    Central Texas
    Wow. Tyler is getting a lot of business. He is going to need two assistants!
  29. May 24, 2021 at 5:45 PM
    #899
    AT x AT
    Jimmy
    Mods, what mods?
    Anybody interested in a group buy for the security torx screws from Screwd?
    (5) 1.5" 3/8-16 Button Head
    (5) 4" 3/8-16 Button Head
    (5) #37 bit
    Based on my address, tax is $23.68 and shipping is $6.41 (I'm actually local to them in Arizona)
    Total for me is $333.83.
    Subtract out shipping to me, the new total is 327.42. Divide by 5 (including me) that is $65.48. I don't know how much shipping is from me to you, but @MoonRock2021 was able to get them shipped for $65.00.
    @MoonRock2021 how were you able to get the math worked out to $65 shipped? Inquiring mind wants to know.
  30. May 24, 2021 at 5:50 PM
    #900
    Classy63
    Tyler
    Cypress Texas
    I need to find a way to do way more faster... I just don’t know the answer.
Thread Status:
