Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. Apr 10, 2021 at 7:57 PM
    #541
    MoonRock2021
    MoonRock2021 New Member
    2021 TRD Pro Crewmax Lunar Rock 2021 4Runner Nightshade
    I'll be getting some 4" too for the ones that bought both plates.
  2. Apr 10, 2021 at 8:24 PM
    #542
    paulbk
    paulbk New Member
    @MoonRock2021
    I posted in the other thread..... but....
    I have the DE front plate and am awaiting delivery of my Valhalla rear plate.
    I’d like to use security bolts for my entire application. Will this work? I’m not versed enough to know if this is applicable...
    Maybe @Tundra234 has some insight? He seems to be very knowledgeable on these cat shield threads :thumbsup:
    MoonRock2021 likes this.
  3. Apr 10, 2021 at 8:40 PM
    #543
    CmdrD8TA
    CmdrD8TA New Member
    Columbus, OH
    2011 Tundra 5.7L 4x4
    Ah ok, thx.
    It sounds like I need:
    • front shield: 2 x 2" bolts and 2 x 4" bolts
    • rear shield: 2 x 4" bolts
    I'm confused after looking at Tyler's latest pics (post #473) while his truck was recently on a lift. Aren't the rear shields supported by a bracket on each side? And doesn't each bracket require 2 bolts? If so, I'm also gonna need security bolts for that missing one.
    Just want to ensure I'm getting all the bolts I need to make this hell for a determined thief.
  4. Apr 10, 2021 at 9:01 PM
    #544
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    If this is for the 2" bolts I'm in. Already have some 4" in hand.
    MoonRock2021[QUOTED] likes this.
  5. Apr 10, 2021 at 9:01 PM
    #545
    MoonRock2021
    I don't think they make them that big but Tyler sends these in his kit.
  6. Apr 10, 2021 at 11:10 PM
    #546
    MoonRock2021
    @Tundra234 @Safar85 @Classy63
    Can you guys confirm this looks correct on where each bolts go on Front and Back Cat Shields? Where would the 3/8 x 16 x 2" go or are they not needed at all?
  7. Apr 11, 2021 at 3:37 AM
    #547
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Your depiction for the 3/8 x 4" screwd is correct based on what I did. The 3/4 x 2" is a substitute size when they are out of 1.75". I dont feel the 1.75" security bolts are necessary, but I am a fan of overkill if you want to spend money and be extra sure.
    I would like to clarify that if you have a TRD front skid plate, and want to use Tyler's provided hardware, you WILL have to bore out the holes where it mates to the crossmember with Tyler's plates. Using the 3/8 x 4" bolts is the perfect solution here because you dont have to drill out holes in the trd skid, AND you get security bolts.
  8. Apr 11, 2021 at 3:52 AM
    #548
    CmdrD8TA
    CmdrD8TA New Member
    Columbus, OH
    Looking at Tyler's bolt specs at the bottom of post #1 and his clarification in post #73 (while referencing someone's pic that shows some of the bolts in post #97), I misunderstood the bolts that are needed for both plates. My apologies for that error in post #549.
    Tyler posted that the front plate needs:
    • two: 5/8 x 4 (front)
    • two: 3/8 x 4 (rear)
    and the rear plate needs (with some visual reference from the 2nd pic in post #146):
    • two: 1/2 x 1.75 (support bracket to rear plate)
    • two: 3/4 x 1.75 (support bracket to frame)
    With regard to the front plate:
    @Tundra234 said he successfully used 3/8-16 x 2" SCREWD bolts in post #327 but looking at his pics in post #357 I think he's using it on a different front shield. I think he successfully used 3/8-16 x 4" SCREWD bolts for the rear Valhalla shield from post #410. While it would be nice to hear from someone who can confirm that it also works for the forward position of the front plate (maybe @Tundra234 does in post #504?), I'm assuming it will when using washers/nuts that I'll have to buy on my own. It's the 5/8's spec from Tyler that's bugging me but not enough to shy away from @MoonRock2021 's group buy.
    With regard to the rear plate:
    The only additional bolts needed are for the support brackets. Looking at the 2nd pic in post #97 suggests that 3/8-16 x 2" SCREWD bolts could be used for both positions on the bracket when used with appropriate washers/nuts that I'll also have to buy on my own. Again, while it would be nice to hear from someone who can confirm fitment here I'm still willing to take a chance and assume this will work.
    @MoonRock2021: Since I bought Tyler's front and rear plates (unless I hear differently from someone who can confirm that my assumptions are incorrect) for a stock non-TRD 4x4 I'd want to ensure I'm getting at least:
    • four: 3/8-16 x 4" SCREWD bolts
    • four: 3/8-16 x 2" SCREWD bolts
    • along with the #37 security bit
    I think this was what you initially suggested in post #503 but I got confused with subsequent posts.
    Hope this helps. If not, maybe I shouldn't be part of the group buy, haha. Ideally though, @Classy63 can do a bulk buy of these sizes, confirm fitment and sell it on his website so there's no confusion/hesitation - I'd be 100% behind that and will race to order it.
    MoonRock2021[QUOTED] and Safar85 like this.
  9. Apr 11, 2021 at 5:27 AM
    #549
    I see where the confusion is with mine. I have the DE front plate and it attaches at each corner. It uses a steel tab with a welded nut and slides inside the crossmember. That is where the 1.5 or 2 inch bolts would fit. Tyler's plates are cut to attach at the same point or pretty close to where it mates up to the engine skid plate in which the 4 inch would be used as it passes through both plates and the crossmember with washers and nuts on top.
  10. Apr 11, 2021 at 5:30 AM
    #550
    I have the DE plate as well. The 3/8 16 x 2 is what is needed for that plate and the 4 inch is what you need for the front side of the rear plate.
  11. Apr 11, 2021 at 9:48 AM
    #551
    MoonRock2021
    Ok so it is safe to say we was correct the first time with this set up.
    • four: 3/8-16 x 4" SCREWD bolts (for crossmember) $25 Set
    • four: 3/8-16 x 2" SCREWD bolts (for the brackets) $20 Set
    • #37 security bit ($20 each)
    1. Me (Front & Back Cat +Bit) $65 x
    2. @DaddyPete (Front & Back Cat+Bit) $65 x
    3. @CmdrD8TA (Front & Back Cat+Bit) $65 x
    4. @Pencilbreak (Front & Back Cat+Bit) $65 x
    5. @paulbk (Front & Back Cat+Bit) $65 x
    6. @OnespeedTRD (2" Only+Bit) $40 x
    7. @PNWTundra2021 (4" Only+Bit) $45 x
    Please send me your emails to send invoice. These have been ordered and being delivered to me Wednesday. I will ship to you all Thursday.
  12. Apr 11, 2021 at 10:08 AM
    #552
    Just sent you a PM.
  13. Apr 11, 2021 at 10:42 AM
    #553
    paulbk
    paulbk New Member
    PM’d.
  14. Apr 11, 2021 at 7:09 PM
    #554
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    Ordered front and rear steel powder coat.
    Classy63[OP] likes this.
  15. Apr 11, 2021 at 7:22 PM
    #555
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Do you know if the front cat plate work with C4 sliders?
  16. Apr 11, 2021 at 8:00 PM
    #556
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    Front cat plate is not in the way of any sliders, only the rear cat plate
    Hightide likes this.
  17. Apr 11, 2021 at 8:13 PM
    #557
    Hightide
    Abalama
    Magic School Bus
    What needs to be done to make the rear work?
  18. Apr 12, 2021 at 2:10 AM
    #558
    Classy63
    Tyler
    Cypress Texas
    I just looked at the C4 sliders instructions video and it will bolt up for the rear too, just might need a spacer to compensate for the bracket bolting on top of the slider
  19. Apr 12, 2021 at 5:18 AM
    #559
    Hightide
    Abalama
    Magic School Bus
    Got it.
    Thanks!
    I’ll get my ducks in a row to order.:thumbsup:
    Classy63[QUOTED][OP] likes this.
  20. Apr 12, 2021 at 10:28 AM
    #560
    Classy63
    Tyler
    Cypress Texas
    15 orders are being picked up this afternoon by fed ex, I will be shipping more out tomorrow. I am trying my best to catch up
  21. Apr 12, 2021 at 12:17 PM
    #561
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’m very pleased with my plates. I jumped on this early and shipping was daily quick. This is a great product and Tyler is doing a great job. That being said, being inundated with work is not the worst problem to have. Have patience those of you waiting, it’s worth it and this guy will deliver.
  22. Apr 12, 2021 at 12:26 PM
    #562
    PNWTundra2021
    PNWTundra2021 New Member
    Craig
    Puyallup, WA
    2021 Tundra TRD Offroad
    Limited Faux Pro
    Just ordered mine this weekend. Thanks Tyler for coming up with a great solution for this problem!
  23. Apr 14, 2021 at 6:16 AM
    #563
    TRDProMTB
    TRDProMTB New Member
    2021 Tundra TRD Pro & 2025 Tundra 1794 Hybrid TRD OR
    I got my plates a couple of weeks ago and finally got them installed at my dealership on a 21 TRD Pro. Printed out pictures from this thread as well as the install instructions from the website. Took them less than 30 min with no issues, but they said they did drop the front TRD skid plate.
    I’m usually very hesitant to buy things from online forum members but Tyler was great to deal with and produces a great product with the customer service to match it. I’m super pleased with how everything turned out.
  24. Apr 14, 2021 at 6:29 PM
    #564
    MoonRock2021
    Bolts were received today and packaged. I will be shipping out in the morning guys. 173932392_2527480177547769_1364944744436_e156151cd4c8946689e259ee7053ad8f86d02a6e.jpg
    PNWTundra2021, CmdrD8TA and biebs96 like this.
  25. Apr 14, 2021 at 6:33 PM
    #565
    OnespeedTRD
    Don
    San Diego
    Nice! You should ask Screw'd for a distributorship status!
    Thanks again for doing this for the group!
  26. Apr 14, 2021 at 6:36 PM
    #566
    MoonRock2021
    If I was doing for profit it would be good but these are just so expensive.
  27. Apr 14, 2021 at 6:40 PM
    #567
    Nice......glad the code worked for you. Gotta love the secret squirrel lol :spy:
  28. Apr 14, 2021 at 6:42 PM
    #568
    MoonRock2021
    Thanks again. Now I have a code for the next group that does this..
  29. Apr 14, 2021 at 6:42 PM
    #569
    No problem at all! :thumbsup:
  30. Apr 15, 2021 at 1:43 PM
    #570
    Phantom Lord
    Phantom Lord New Member
    Byron
    2017 MGM CM Limited
    My plates arrived today, they look great and went on nicely.
    I was planning on ordering security bolts but after installing them I don't feel the security bolts are worth the money. A thief would need 3 different size sockets, plus wrenches to match. My guess is they would try cutting the bolts or plates before attempting to unbolt them. I feel comfortable sticking with the stock hardware.
Thread Status:
