Updated Rago dash mount
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra234, Jan 6, 2023.
  1. Feb 2, 2023 at 8:17 AM
    #121
    Tundra234 [OP] New Member
    Just passing on that ICS is backordered on their arms. They said about 4 weeks right now.
    Shadowfax1 and bulldog93 like this.
  2. Feb 2, 2023 at 9:37 AM
    #122
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    There are a ton of other manufacturers. Amazon has quite a few RAM knock offs. The tackform are all aluminum if that's what you want, are highly reviewed and cheaper than the ICS
  3. Feb 2, 2023 at 9:45 AM
    #123
    Thanks. I have been meaning to look at the tackforms.
  4. Feb 5, 2023 at 10:13 AM
    #124
  5. Feb 5, 2023 at 7:10 PM
    #125
    raketemensch
    raketemensch New Member
    NEVADA
    not sure if Melissa reads this forum but I really don't like the updated plate. I've bought tons of stuff from Rago in the past, but I just couldn't get into this design. Simplifying the logo and maximizing utility should be an update, not the reverse.
    ASV_Tundra and Wallygator like this.
  6. Feb 6, 2023 at 8:17 AM
    #126
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I'm not sure where you guys are going at it with the plate.
    If we compare side by side the two, the major differences are the logo and you lose 2 slits. How much more adjustment do you need from the extra 2 slits where now sits the logo?
    I'm sure the revamping is due to R&D and that those extra 2 slits really did not make any difference in adjustments.
    bulldog93 and shawn3210 like this.
  7. Feb 6, 2023 at 10:48 AM
    #127
    tonynw318
    tonynw318 New Member
    Tony
    Oregon coast
    2020 silver sky SR5 crewmax
    I can't remember the exact dimension, but long enough to get my phone to the front of the dash where I can touch it.
    bulldog93 likes this.
  8. Feb 8, 2023 at 5:19 PM
    #128
    @Marvthehamster what did you ever come up with on the led? I powered mine up today. The blue isn't bad on the dash, but I did see the reflection on the windshield. Also reading through the thread, the "universal bolt pattern" is what the AMPS identification is. I just mentioned it for others when they are adding the plate and ordering mounts. Now if I can just get my tiny arms in that are backorder.
  9. Feb 9, 2023 at 10:33 AM
    #129
    Marvthehamster
    Marvthehamster New Member
    Tom
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI Armor, OTT Tune
    I actually haven't done anything with that LED yet. It does emit light up through/around the cutout for the usb plug but it's fairly minimal. I don't drive at night very often, but it's a total non issue during the day. I'll probably be out driving at night this weekend and will know better if I need to disable it.
    Tundra234[QUOTED][OP] likes this.
  10. Feb 9, 2023 at 2:07 PM
    #130
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Hey, I thought I saw a hardware list that someone included w/their post for some longer hardware pieces when pairing the Rago w/an ICS backplate, but I'm not finding it...
    Was I smokin' dope on that, or does anyone else remember seeing that somewhere??
  11. Feb 9, 2023 at 2:17 PM
    #131
    I don't recall anything like that myself.
  12. Feb 9, 2023 at 3:06 PM
    #132
    Marvthehamster
    Tom
    CO
    2018 CM
    I believe somewhere someone mentioned the necessity (or perhaps just advisability) of longer screws than what Rago provides. I installed my ICS plate and Rago mount with the standard Rago screws no problem. There weren't any extra threads showing once I tightened everything down but the lock nuts were fully engaged on the screws.
  13. Feb 9, 2023 at 3:31 PM
    #133
    Tripleconpanna
    Ok, perfect; that's really all I need!!!! I'm going to be doing the front camera at the same time and needed to make a stop at the hardware store to piece a couple of things together, but just wanted to do everything in one trip.
    Thank you :hattip:
  14. Feb 9, 2023 at 4:42 PM
    #134
    My install was the same. The bolts that came with it were fine. I drilled in the circled area for the USB power to feed through instead of drilling through the ICS plate. Another note....use one of the attachment screws to run through each hole to clean up the threads a little.
  15. Feb 9, 2023 at 6:00 PM
    #135
    Tripleconpanna
    Make sense.... thanks!!!
    I do like the idea of the cable running from behind the plate (closer to the windshield) better than the examples I've seen such as off to the side or forward of the plate. Good call!
  16. Feb 10, 2023 at 12:32 PM
    #136
    Tripleconpanna
    Last question... I noticed that you and tundra234 both went with 4 mounting screws to secure the rago mount to the ICS plate. It looks like he used the holes in the ICS plate and drilled into the Rago and it looks like you used the original Rago holes and drilled into the ICS....
    I'd prefer to not drill the Rago plate and just tap the ICS as you did, but I saw a couple of posts in the original Rago thread where guys drilled both and ran 6 mounting screws to secure the unit (adding 2 at the bottom of the mount) which leads to my question. Are you finding the plate provides sufficient support to remain stable and minimize vibration w/just the 4 bolts or have you found reason to think that by adding 2 more bolts to the lower part of the plate it would be more secure or have less vibration???
    I tend to think that the 4 will be enough and that the attachments, arms, etc. will be a source of vibration long before the connection between the mount and plate using the 4 bolts :notsure:
  17. Feb 10, 2023 at 12:34 PM
    #137
    I drilled the ICS plate.
    Wallygator likes this.
  18. Feb 10, 2023 at 2:08 PM
    #138
    Tripleconpanna
    That's weird, because in yours it looks like you've got 2 bolts going through the bottom (tapered) part of the mount. My Rago mount does not have any holes there.... Anyhow, my concern was the bottom part of the plate only having the one center hole and nothing on the lower half toward the outside of plate (where you have what looks like hexhead screws sticking up) :notsure:
  19. Feb 10, 2023 at 3:01 PM
    #139
    I forgot and I should have mentioned...this is a generic photo to show where I ran the power.
  20. Feb 10, 2023 at 3:27 PM
    #140
    Tripleconpanna
    That makes more sense... thanks!!!!
  21. Feb 10, 2023 at 3:36 PM
    #141
    Marvthehamster
    Tom
    CO
    2018 CM
    I think 6 bolts is total overkill. 4 is plenty. There’s a bit of inherent wobble no matter how many plates or bolts you use due to the fact that the dash is like 3/16” thick plastic. I honestly wonder just how much stability the ICS plate provides over the fender washers that Rago provides.
    I’m still really liking the whole system, though. I got some short, black usb cables for charging phones. This keeps things pretty neat on the dash.
  22. Feb 10, 2023 at 5:18 PM
    #142
    Tripleconpanna
    Copy that :thumbsup:
    Thanks for the feedback and have a great weekend!!!!
  23. Feb 10, 2023 at 7:21 PM
    #143
    Marvthehamster
    Tom
    CO
    2018 CM
    Stubby arms. I like the length. I think these are 12” USB’s, just long enough to plug into the phone when it’s in the mount and not kink the hell out of the cord.
    Wallygator and Tripleconpanna like this.
  24. Feb 20, 2023 at 5:17 AM
    #144
    Naut18
    Naut18 New Member
    2016 Tundra TSS
    I wasn't paying attention and ended up with the "Rago" version as well. I don't advertise for folks so this was not an option. The R on the version I thought I was going to get was enough and though I could live with it...."Rago" is out of the question.
    See image for what I came up with. It's a 2 inch wide piece of stainless trim from Amazon. We'll see if I can stand it or if I quit noticing all together. I think it matches the dash trim fairly well. I should have wiped the finger prints off for the pic but that's OK.
    Kwe1982 and Wallygator like this.
  25. Feb 20, 2023 at 5:23 AM
    #145
    Not bad at all. Now just make it black.
  26. Feb 20, 2023 at 6:14 AM
    #146
    Naut18
    Naut18 New Member
    2016 Tundra TSS
    Yeah....that was my initial plan but thought I'd let the stainless ride for a bit.
    It's definitely better than reading "Rago" every 30 seconds which I know my brain/eyes would do.
  27. Feb 20, 2023 at 6:27 AM
    #147
    I bet it will be a short ride once the sun hits it.
  28. Feb 20, 2023 at 6:31 AM
    #148
    Naut18
    Naut18 New Member
    2016 Tundra TSS
    I think you're right.
  29. Feb 20, 2023 at 10:22 AM
    #149
    shawn474
    MoCo, Maryland
    I don't see the point of hiding the logo - we advertise every single day for products that we purchase. We purchase them for a reason - usually because they are what we like, are functional, high quality ,etc.....In this case, the rago dash mount is high quality, very functional and you wouldn't have bought it if you didn't like it. This is like pulling off the nike swooshes on your sneakers. If you "don't want to advertise" for companies, why buy it in the first place. If the answer is similar to any of the ones listed, why have an aversion to supporting a vendor that makes a quality product? to each his own, but doesn't make sense to me to spend time, money and effort to cover up something like this
    Tundra234[OP] and bulldog93 like this.
  30. Feb 20, 2023 at 10:51 AM
    #150
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
