***UPDATE***Tech12volts door and/or dash speaker group buy.-valid through 2/28/19
Discussion in 'Deals & Group Buys' started by Pudge, Jan 30, 2019.
Thread Status:
Not open for further replies.
  1. Apr 27, 2019 at 11:17 AM
    #841
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    I clipped the wire at the terminal, stripped the wire and crimped on the spade connectors and plugged those into the new speaker
  2. Apr 27, 2019 at 11:26 AM
    #842
    I need photos with instructions lol
    Migraine likes this.
  3. Apr 27, 2019 at 11:45 AM
    #843
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Sorry, I didn't take any photos, but it's only two wires, the one going to the terminal with a capacitor is positive
  4. Apr 28, 2019 at 8:02 AM
    #844
    Mkpw24
    Mkpw24 New Member
    Michael
    Does anyone know why my audio fades in and out after the upgraded speakers and sub? It randomly does it for like 1 to 2 seconds then goes back to normal, but there are times it happens more on certain songs. Just wondering if anyone have the same issue and had resolved it? I have the group buy hertz front and back speakers, stadium 5 channel amp and 10tw1 installed on 2018 tundra crewmax NON JBL.
  5. Apr 28, 2019 at 8:55 AM
    #845
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    What do you mean by fades in and out
  6. Apr 28, 2019 at 9:49 AM
    #846
    Mkpw24
    Mkpw24 New Member
    Michael
    A song would be playing then all of a sudden volume/sound cuts off for 1-2 seconds then resume back to normal volume. Happens random, but there are times it usually happen more on certain songs. All connections are secured. Did notice it happening more on songs with heavier base.
  7. Apr 29, 2019 at 12:24 AM
    #847
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    did you just upgrade or did you upgrade amp also ? sounds like your prompts are turned down so low that its muting the speakers but you can't hear the prompts
    Pudge[OP] likes this.
  8. Apr 29, 2019 at 6:19 AM
    #848
    Mkpw24
    Mkpw24 New Member
    Michael
    Yeah I got the speakers, stadium 5 channel amp and sub upgrade on a non jbl system. Did the install as per instructions and with your assistance during the install. What are the prompts you mention?
  9. Apr 29, 2019 at 8:31 PM
    #849
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I think maybe he is referring to normally audible prompts from your phone or audio source. Like say a text message, or email, or navigation instruction
  10. Apr 29, 2019 at 10:07 PM
    #850
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    Yes how do you fix that!!! Jesus don’t think I’m ever ready for when those come through
  11. Apr 30, 2019 at 7:35 PM
    #851
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Mine is doing the same...there is "muted" audio coming from the dash speakers when it happens, no prompts on truck screens or bluetooth-connected phone that would be causing it and all connections are secure as well.
  12. Apr 30, 2019 at 7:37 PM
    #852
    Pudge
    CT
    That's weird. I never had issues when I replaced my speakers and sub. Still no issues with kenwood headunit, maestro, and JL amp
  13. May 4, 2019 at 11:54 AM
    #853
    armyoffoo
    armyoffoo Member
    Cypress, TX
    It seems that the amp is cutting out for some reason, when it happens the dash and center speakers still play sound, but all speakers going through the amp cut out for about 2-3 seconds. I tested this by removing the power lead for the amp and I still get sound out of the dash and center speakers, so these must still be powered by the HU.
    No loose connections, and it happens when parked as well as moving.
    Happens during all types of music, but completely random.
    Happens couple of time within the first minute or two of starting up the truck.
    Phone prompts such as txt msg and email are loud and clear, no messages on phone or truck console / radio screens when sound cuts out.
  14. May 17, 2019 at 6:28 PM
    #854
    Ronlara26
    Ronlara26 New Member
    Ronnie
    2010 tundra crew max
    Question for you guys. Just Installed the door speakers. Front woofers and tweeters work. But the rear woofers work and the rear tweeters don't? Any suggestions
  15. May 17, 2019 at 7:38 PM
    #855
    Pudge
    CT
    Idk about your 2010 but in 3rd gens you need to put a jumper wire on the rear tweeters to get the speakers to work back there. Any pics of your back door speakers/wires? @Ronlara26
    cjscinta likes this.
  16. May 17, 2019 at 7:46 PM
    #856
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    I have my Kenwood installed to finish off the system but when there is no music playing but the volume is turned up there is a noticeable “hiss”. Not as noticeable when driving but very when just the engine isn’t running. It gets a little more pronounced when you turn up amp gain or enable sound enhancement features on the head unit like loudness or stage EQ. Any ideas?
  17. May 17, 2019 at 8:02 PM
    #857
    Pudge
    CT
    Any particular source input worse than others? I have read some tunes kenwood have some bluetooth hiss, unfortunately I'm not sure of how to fix that. If it goes away or is quieter when using a wired connection or listening to the radio its likely the BT connection.
    Another possibility is interference in the RCA cable. Make sure its nor crossing over or too close to your 12V power wire, or running along any power wire.
    I have some hiss when running pandora via BT but only noticable when no music is playing.
  18. May 17, 2019 at 8:07 PM
    #858
    Ronlara26
    Ronnie
    Not my pic, but I kind a have it wired like this. Just spliced into the actual Toyota harness.
  19. May 17, 2019 at 8:10 PM
    #859
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Maybe your Amp rear filter is set to LPF and filtering out the highs?
  20. May 17, 2019 at 8:13 PM
    #860
    Ronlara26
    Ronnie
    Haven't installed the amp yet, could that be the reason?
  21. May 17, 2019 at 8:21 PM
    #861
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I'm not sure if you have a stock amp, like mine. My truck is Non-JBL and I still had a stock amp under the passenger seat. If the tweeters are hooked up to the same wire as the woofer, you should be getting something...it might not be much or it might be filtered out somehow.
  22. May 17, 2019 at 8:24 PM
    #862
    Pudge
    CT
    Did your truck have rear factory tweeters? If so those wires need to be jumped or left connected at the plug, just yank the tweeter off the plug
  23. May 17, 2019 at 8:28 PM
    #863
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    My power wire is running into the cabin on the drivers side and when I installed the head unit I ran the RCA cables above the glove box and down along under the rocker panel cover and under the passenger seat where the amp is. So it’s nowhere near the power wire by design. I seems to be there on any source...usb, satellite, radio, or car play (don’t really use BT for audio, just phone) It doesn’t seem to degrade the music quality but I know it’s there and it bugs me! Lol
  24. May 18, 2019 at 5:00 AM
    #864
    Ronlara26
    Ronnie
    Non-JBL system with no previous amp. I'm hoping when I install the 5 channel it will fix it.
    No rear factory tweeters. The rear woofers are working so in theory the tweeters should be working.
    Pudge[QUOTED][OP] likes this.
  25. May 19, 2019 at 10:32 AM
    #865
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    I did more trouble shooting and have narrowed it down to turning on the loudness setting of the radio. Which is too bad because it sound better with it on but it’s 100% what’s causing the hiss.
  26. May 19, 2019 at 1:10 PM
    #866
    Pudge
    CT
    My hiss is bothering me more now that you've mentioned it lol. Maybe I'll turn down the loudness too and see if it helps
    Tundyfundy and DCB500[QUOTED] like this.
  27. May 22, 2019 at 2:30 PM
    #867
    BigGreek
    BigGreek New Member
    Evan
    2016 Tundra Platinum
    Finally got the whole system installed and it does sound fantastic! Richer sound and bass.
    I love it! Thank you @james@tech12volts and Tundras.com
    Pudge[OP] and T-Rex266 like this.
  28. May 22, 2019 at 2:40 PM
    #868
    mtlmlta182
    mtlmlta182 Breathe and take it in...
    '18 Cement SR5
    6112/5160 & +2 Shackle. 295/70R18 Falkens, Predator Tube Steps, Debadged, Pro Grille, Blackout, Tech12volts full audio package, DD 8" SS, Clazzio Leather Covers, LED lights
    Do you have the sub/amp combo as well or just the door/dash?
  29. May 22, 2019 at 2:54 PM
    #869
    BigGreek
    BigGreek New Member
    Evan
    Sub and amp as well!
  30. May 22, 2019 at 9:44 PM
    #870
    BigGreek
    BigGreek New Member
    Evan
    I forgot to thank you as well @Pudge
Thread Status:
