***UPDATE***Tech12volts door and/or dash speaker group buy.-valid through 2/28/19
Discussion in 'Deals & Group Buys' started by Pudge, Jan 30, 2019.
Thread Status:
Not open for further replies.
  1. Apr 21, 2019 at 9:39 PM
    #781
    cjscinta
    cjscinta New Member
    Nashville TN
    Thanks James
  2. Apr 21, 2019 at 9:44 PM
    #782
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    You definitely want to leave the crossovers inline when you install those center channel tweeters. What do you mean by circular plastic parts? Got any pics?
    When I installed mine I cut about a foot of wire off.... (save that foot of wire with the connectors to use to wire up your alpine corner dash speakers, you can use those connectors as they fit perfect on the infinity speakers, you can see one plug I larger than the other and the infinity connections are like that and that foot of wire gives you enough play to tie into the factory harness wires on the corners).....anyway, I tied both red wires and both black wires together, then simply connected those to positive and negative on the factory harness, leaving the crossovers in place.
  3. Apr 21, 2019 at 9:52 PM
    #783
    cjscinta
    cjscinta New Member
    Nashville TN
    I think those are for a different type of mount installation you think? I’ll install both crossovers when I put the center speaker in. 549BCCE9-672F-4C0D-9DA8-94494471086F.jpg
    Pudge[OP] likes this.
  4. Apr 21, 2019 at 9:57 PM
    #784
    Can you take pix of install? This one is actually harder for me lol. I need like step by step wiring instructions with photos lol
  5. Apr 21, 2019 at 9:59 PM
    #785
    Pudge
    CT
    Yes those just come with the JL tweeters for other mounting options. And yes wire in both crossovers
  6. Apr 21, 2019 at 10:00 PM
    #786
    cjscinta
    cjscinta New Member
    Nashville TN
    I haven’t started yet. I just took them out of the box and pretended I know what I’m talking about.
    T-Rex266[QUOTED] and Pudge[OP] like this.
  7. Apr 21, 2019 at 10:04 PM
    #787
    cjscinta
    cjscinta New Member
    Nashville TN
    Thanks Pudge. Stay tuned. Many questions to follow.....
    I see what you are talking about but cutting a foot off. What’s the best means to connect the crossovers then after I cut it off? Whatever plastic connector I have available?
  8. Apr 22, 2019 at 5:29 AM
    #788
    cjscinta
    cjscinta New Member
    Nashville TN
    Instead of looking at it as one massive project which it is, break it into small parts, one small project at a time, one speaker at a time. All bets are off though once I get to the amp and subwoofer. :) I’m going to need some videos on that I think.
  9. Apr 22, 2019 at 6:10 AM
    #789
    Pudge
    CT
    If you just cut off a foot from the end of the wire, the crossovers should still be connected to the wire. I wouldn't cut them off at all. If your crossovers are near the end of the wire I would just split the difference between the crossover and end of the wires and cut there.
  10. Apr 22, 2019 at 6:19 AM
    #790
    cjscinta
    cjscinta New Member
    Nashville TN
    So you are saying that only one end of the crossover needs to be connected? In other words if I cut the long thicker wires with the connectors off to use on the other speakers the crossover still functions normally?
  11. Apr 22, 2019 at 6:23 AM
    #791
    Pudge
    CT
    The thick wires are what you connect to the trucks factory speaker wires. So you will have the thick wires crimped to factory wires, then then crossovers, then the skinny wires that connect the crossover to the speaker do not cut the skinny wires. You only wanna cut about a foot or so off the very end of the thick wires.
  12. Apr 22, 2019 at 6:26 AM
    #792
    Pudge
    CT
    It's hard to explain. maybe I'll draw a picture lol
  13. Apr 22, 2019 at 6:26 AM
    #793
    cjscinta
    cjscinta New Member
    Nashville TN
    Got it. Thanks.
    Pudge[QUOTED][OP] likes this.
  14. Apr 22, 2019 at 10:59 AM
    #794
    cjscinta
    cjscinta New Member
    Nashville TN
    So for the center dash speaker install, is this how the crossovers should be hooked up?
    If I want to hook into the factory harness which wire is which? (Center speaker only) or which ones do I tie together?5EC9A45E-EC0A-436D-8E2B-C1BB2D6A84BD.jpg
    D3Tundra likes this.
  15. Apr 22, 2019 at 11:03 AM
    #795
    cjscinta
    cjscinta New Member
    Nashville TN
    As far as the corner speakers go, do I really need the self tapping screw in the second hole? I’m afraid I’m going to hit something under my dash. It is pretty secure with just one screw and I figured with the corner speakers being higher range, vibration shouldn’t be a problem you think?
  16. Apr 22, 2019 at 11:11 AM
    #796
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    I have a 2018 SR5 non-JBL and this is how I hooked up the center crossovers.
    1st speaker (red is positive, blk is negative), 2nd speaker (blue is positive, grey is negative). I reduced the wire length on the crossovers and soldered them + to +, - to - from crossover to the factory connector.
  17. Apr 22, 2019 at 11:11 AM
    #797
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    I only used one screw. Haven't had any issues with rattling or the speaker coming loose.
  18. Apr 22, 2019 at 11:19 AM
    #798
    cjscinta
    cjscinta New Member
    Nashville TN
    Thanks. So just tie the positives together and tie the negatives together? Mine is non JBL as well.
  19. Apr 22, 2019 at 11:19 AM
    #799
    cjscinta
    cjscinta New Member
    Nashville TN
    Thanks
  20. Apr 22, 2019 at 11:30 AM
    #800
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    As long as it sits flush, it’ll be ok. I tapped a screw anyway as the holes don’t line up. If it doesn’t sit flush, elevated even a little on one side, it may contact the cover and vibrate.
  21. Apr 22, 2019 at 11:38 AM
    #801
    cjscinta
    cjscinta New Member
    Nashville TN
    Never mind. I get it.
  22. Apr 22, 2019 at 12:18 PM
    #802
    Cmaccullen
    Cmaccullen New Member
    2022 Tundra Limited
    Any chance they will be running this group buy again?
    West Texas Tundra likes this.
  23. Apr 22, 2019 at 7:30 PM
    #803
    cjscinta
    cjscinta New Member
    Nashville TN
    9BD4085C-3E80-4F01-9008-734B05A4C2E5.jpg 3C7EA55C-62A5-4F33-8C67-8971480C3091.jpg Ok. A few more dumb install questions.
    1 Does anyone know how to install the tweeters into the sail panels and in what order?
    2 Do I screw the speakers directly onto the wood brackets or do I need some kind of foam backing before I screw it down to keep it from vibrating?
    831Tun likes this.
  24. Apr 22, 2019 at 7:37 PM
    #804
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That ring in the photo goes over the tweeter and the whole assembly is a push fit into the sail panel. Be very careful not to break the leads on the tweeter, they're very delicate.
    I just screwed the door speaker directly to the wood.
  25. Apr 22, 2019 at 7:51 PM
    #805
    cjscinta
    cjscinta New Member
    Nashville TN
    So on the ring does the lip go in the sail panel first or does it clip in last? Confusing question I know.
  26. Apr 22, 2019 at 8:16 PM
    #806
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I don't remember. If you play with it I think it will become apparent. @BlueBottle had a good photo of it.
  27. Apr 22, 2019 at 8:18 PM
    #807
    cjscinta
    cjscinta New Member
    Nashville TN
    Thanks for your help.
  28. Apr 22, 2019 at 9:22 PM
    #808
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I put the tweeter in then the ring. I think? Just get it in there lol
    831Tun[QUOTED] likes this.
  29. Apr 22, 2019 at 9:27 PM
    #809
    mtlmlta182
    mtlmlta182 Breathe and take it in...
    '18 Cement SR5
    6112/5160 & +2 Shackle. 295/70R18 Falkens, Predator Tube Steps, Debadged, Pro Grille, Blackout, Tech12volts full audio package, DD 8" SS, Clazzio Leather Covers, LED lights
    Has anyone experienced the center tweeters popping/cutting out at high volume? They are the only ones I have installed so far and sound much better, but cut out at around 48-50.
    2018 non JBL and I soldered the crossovers In correctly and then combined the (2) + and - from factory connector together. Should all (4) connections be separate?
  30. Apr 22, 2019 at 9:27 PM
    #810
    Pudge
    CT
    Yes, I put the ring on the tweeter (carefully and forcefully at the same time) then pressed it into the hole. Giggity
    BlueBottle[QUOTED] likes this.
Thread Status:
