***UPDATE***Tech12volts door and/or dash speaker group buy.-valid through 2/28/19
Discussion in 'Deals & Group Buys' started by Pudge, Jan 30, 2019.
Thread Status:
Not open for further replies.
  1. Mar 26, 2019 at 10:17 AM
    #751
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    Thanks for the response James. I don’t have your amp setup. I have a JL HD600/4. What gain should I set on Front/rear speakers on the DSR1? I tried to set the gains all the way down last week and still hear the noise. Seems like it didn’t make a difference from -3db down to all the way down. Anyway to disable the Bluetooth module? I was thinking that the HU and or DSR1 are not grounded properly to cause the noise; haven’t gotten to test that thought out.
  2. Mar 26, 2019 at 10:21 AM
    #752
    XNeewbie
    XNeewbie Eat-Sleep-Yota
    Charlie
    SC
    2017 Gray Tundra CM SR5 TRD 4x4
    20% Tints - Bull Rings - Rubber Mats - Toyota Center Console Cover - Clazzio Seat Covers - Pop & Lock - Bed LEDs w/ Timer - EvoOne Remote Start - FRAC Harness w/ Front Camera - Handle Bar - TRD Shift Knob - TRD Sway Bar - AJT Fob Cases & Battery Tie Down - Breather Mod w/ Filter - SDHQ Speed Sensor Covers - BORA 1-1/2" Spacers - TRD License Plate Frame - LEDs all Around - Door Sills - Front Seat Bracket Bolt Covers
    Thank you for clarifying. Here’s what I got. Same setting per your instructions. I marked all the dials with a small white dot to know exactly where it’s set.
  3. Mar 26, 2019 at 11:06 AM
    #753
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    He asked that he be emailed, you'll get much more timely answers from him that way too.
    Pudge[OP] likes this.
  4. Mar 29, 2019 at 7:08 AM
    #754
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    Finally installed my amp, along with the new head unit, last night. Only had to text James a few dozen times... thanks @james@tech12volts for all your help!
    It sounds much better than the stock head unit... really wakes up all of the speakers and the sub.
    Migraine, T-Rex266 and Pudge[OP] like this.
  5. Mar 30, 2019 at 4:23 AM
    #755
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    Had my dash and door speakers installed, all wiring soldered, Hush Mat sound deadening for all four doors. I can notice a clearer or crisper sound, and no longer have to turn the volume all the way up with a window open. It is better than the stock speakers. I appreciate James putting together the GB. Also appreciate everyone sharing their install experiences which convinced me hiring a professional was the least expensive option in the long run.
    Norfolk757 and T-Rex266 like this.
  6. Apr 1, 2019 at 6:36 PM
    #756
    19SPORT4x4
    19SPORT4x4 New Member
    2019 Tundra TRD Sport
    Got everything installed over the weekend. Only problem is now when I lock the doors instead of 1 beep I get 2 beeps and the doors try to lock a second time. Anybody have a similar experience or have a clue what went wrong?
  7. Apr 2, 2019 at 2:31 AM
    #757
    Adam New Member
    I don't have a 19, but it may be in your settings found in your radio. Maybe unplugging for so long something reset?
  8. Apr 3, 2019 at 9:38 PM
    #758
    Mkpw24
    Mkpw24 New Member
    Michael
    2018 Black TRD Sport
    For anyone that have the non jbl setup and installed their front and rear speakers, can you show me how you guys wired it? Especially the tweeters. Thanks
  9. Apr 3, 2019 at 10:07 PM
    #759
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Speaker and tweeter red to positive and black to negative. I drilled a hole in the rear door panel for the tweeter. I mounted front tweeter in the 6.5 front speaker adapter. Kinda wish i surface mounted like rears.
  10. Apr 3, 2019 at 10:10 PM
    #760
    Mkpw24
    Mkpw24 New Member
    Michael
    Thanks for the response. So I just tap into the front tweeters to the factory front speaker wire? And I guess same goes for the rear?
  11. Apr 3, 2019 at 10:12 PM
    #761
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Yes. Thats only way since we only have 2 wires. Next question is where you going to mount it? Can do sail panels
  12. Apr 4, 2019 at 7:25 AM
    #762
    Mkpw24
    Mkpw24 New Member
    Michael
    Got the sail panels from James for the front tweeters. Went back and read all 27 pages and found how to wire the rear tweeters. Thanks for all the posts and response!
  13. Apr 4, 2019 at 12:59 PM
    #763
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    Mind reposting the info on the rear? For is lazy folk :D
  14. Apr 4, 2019 at 8:47 PM
    #764
    Mkpw24
    Mkpw24 New Member
    Michael
    Not sure how to quote the post but it is in page 13 post #369
    Migraine likes this.
  15. Apr 6, 2019 at 6:38 PM
    #765
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    Took a trip today to see James @james@tech12volts and have the goods installed by the master! I added two JL 10” subs to the group buys and this system KICKS ASS!!!! I was expecting a big difference but this totally blew me away!! James and his crew are hands down the best. Honest, hard working dudes that are focused on customerservice. They answered all my questions and made sure I was completely satisfied before I drove away.
    A HUGE Thank You to James and crew for the great deal and even better customer service!!
    TXTundra2722 and T-Rex266 like this.
  16. Apr 6, 2019 at 6:48 PM
    #766
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Finally picked up the speakers from my NY mailbox. Blacked the frames and waiting for sound deadening from Amazon.
    Should I make the effort to cut holes in the front nonJBL sails, or do what 8MINT8 did and put them in the frame? I bought the dash speakers too so I’m not sure it’s better to have physical separation between the highs, or to have the Hertz tweeters closer to my ears in the sails?
  17. Apr 6, 2019 at 7:26 PM
    #767
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Flush mount them. If I could redo, I would put them on the front door speaker grill. Highs are reduced being behind the panel. The sail panels are a good choice too. I still feel there is enough mids and highs coming from the dash.
    JoshuaA[QUOTED] likes this.
  18. Apr 6, 2019 at 8:19 PM
    #768
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Finally got around to installing sound deadening, sub, door speakers and tweets. It's sounding much better and I actually felt bass in the back of my seat. I haven't installed the dash speakers yet but right now the dash seems to be overwhelming the new Hertz speakers?
    Any pics of how to remove the dash grilles? TIA
  19. Apr 7, 2019 at 10:00 AM
    #769
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Thank you, I didn't realized they would be that sensitive, guess I'll get a hole saw and do a flush on the sails.
  20. Apr 8, 2019 at 5:44 PM
    #770
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Just did all the dash. First comment true for me. Deadening comes tomorrow, if second comment applies too, I’ll be...
    I don’t think I would notice as much with the stock HU, definitely upgrade that too!
  21. Apr 8, 2019 at 7:27 PM
    #771
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    Trd CAI, Trd Dual Exhaust, ESP Locking storage, Center Console Safe, Trd Rear Sway Bar, BFG Ko2, Pioneer Avic 8400nex, Husky Liners, 19 Trd Headlights, iHacker Harness, Tech12Volts Sub Upgrade
    You will like the door speakers too. Deadoning can suck. I did inner and outer doors with 36sqft of Noico 80mil and needed more for the last door. I had a sheet of Soundskin i got from James for the rear wall i never used so i used it on the outer of the last door. Installing Noico sucks compared to the Soundskin. Make sure to wear gloves and a crappy long sleeve shirt if doing the inner doors. Its its metal slicing heaven in there!
  22. Apr 8, 2019 at 7:37 PM
    #772
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
  23. Apr 9, 2019 at 5:53 AM
    #773
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Thanks Jon, gloves and long sleeve it is, I got Noico 80 too.
    JTL[QUOTED] likes this.
  24. Apr 9, 2019 at 6:47 AM
    #774
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    OEM Sail panels with tweeter holes arrived yesterday (I’m non-JBL). $41 shipped from Roman.
    JTL likes this.
  25. Apr 10, 2019 at 5:54 PM
    #775
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Made my own, Milwaukee burr-free 1.5” hole saw, lined the ring circumference and secured with Noico tar from sound matting. Noico triangle piece was also placed behind the sail.
  26. Apr 10, 2019 at 6:40 PM
    #776
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    Nice work. Looks better than OEM to be honest
  27. Apr 13, 2019 at 10:05 AM
    #777
    bard0117
    bard0117 New Member
    The AMP made an incredible difference, the dash exploded into amazing sounds.
  28. Apr 13, 2019 at 10:42 AM
    #778
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Tough call, if only I wanted to spend the funds towards a proper amp and enclosed sub. The Android HU’s extra punch over stock skewed my desire to push it further. I’m finding lots of brightness and clarity out of my dash, and doors for that matter, at least for my highs/mids standards, not a serious audiophile here. The HU has sub out and maybe a cheap powered 10 behind the rear seats will do, then I think I’m done. No doubt you guys who amp’d it all the right way have incredible sound. That said, maybe I’ll get accustomed to a new normal and crave, just doesn’t seem like it right now.
  29. Apr 21, 2019 at 9:33 PM
    #779
    cjscinta
    cjscinta New Member
    Nashville TN
    So I’m just starting the install process. I’m going to start with the dash speakers because they look the easiest. For the center speaker, should I assume the crossovers, circular plastic parts, and most of the hardware is not required for this installation or does it need to be installed? I didn’t see anyone mention this. A88ADF2A-01D0-420D-A4B9-DE990EF8EC5A.jpg
  30. Apr 21, 2019 at 9:38 PM
    #780
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    the crossovers need to be installed
Thread Status:
