***UPDATE***Tech12volts door and/or dash speaker group buy.-valid through 2/28/19
Discussion in 'Deals & Group Buys' started by Pudge, Jan 30, 2019.
Thread Status:
Not open for further replies.
  1. Mar 20, 2019 at 9:26 AM
    #721
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    How did he recommend wiring the amp to the factory harness? Will this work?
    https://autoharnesshouse.com/41112.html
  2. Mar 20, 2019 at 9:58 AM
    #722
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    He recommends just cutting the harness or tapping into the wires you need to use.
    You could strip and solder and shrink wrap them. Or maybe even use posi taps if you want wanna cut it.
    Idk if that harness in pic will fit. I think it's different JBL vs non jbl
  3. Mar 20, 2019 at 7:22 PM
    #723
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  4. Mar 20, 2019 at 7:47 PM
    #724
    jack_yaj
    jack_yaj New Member
    Jack
    2019 Midnight Black Limited DC TRD Off-Road
    James is the master!!! He's slow playing us all. Hahaha. :spending:
  5. Mar 20, 2019 at 8:52 PM
    #725
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    Another group buy for it?
  6. Mar 20, 2019 at 9:21 PM
    #726
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    ^ My thoughts exactly. Mine arrived today. Woo hoo.
    It’s a big box. This is going to take some time. Going to be so much better though.
  7. Mar 20, 2019 at 9:27 PM
    #727
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    So what is everyone doing with the side dash speakers on a JBL system. Are you using the capacitors that come with them? I have heard both use them and don't use them. I have done the center and read doors so far and some sound deadening.
    TIA, Mike
  8. Mar 21, 2019 at 1:05 PM
    #728
    bard0117
    bard0117 New Member
    It's really not hard at all! First install I've done in my life, and it was easy because of all the pictures and directions I found on these threads. Seriously, someone made a comment about using leather cleaner to get the power wire through the grommet and it worked like a charm!
    First install of my life, and I did the complete package. Amp, doors, dash, DSR1, and sub.
  9. Mar 24, 2019 at 9:26 AM
    #729
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    @ James.. I want to know too. Just install the speaker and forgot to use the capacitor.
  10. Mar 24, 2019 at 9:44 AM
    #730
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    I’m also getting a pop from the dash speakers so I’ll probably remove th capacitor and see how it goes.
  11. Mar 24, 2019 at 9:46 AM
    #731
    silverhack
    Sacramento, CA
    How is everyone getting the dash side speaker bolts installed? It seems like the holes in the new speaker are too far apart and do not line up with both bolts. I only got one in on each side.
  12. Mar 24, 2019 at 11:30 AM
    #732
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Does anyone know where I can buy or part number to this little clip on the door panel.
  13. Mar 24, 2019 at 11:30 AM
    #733
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    @Roman
    Roman likes this.
  14. Mar 24, 2019 at 11:45 AM
    #734
    Lol I think I need a couple too
  15. Mar 24, 2019 at 11:46 AM
    #735
    Only thing left for me is dash speakers and corner speakers and I have no idea what to do, what I’m doing. :help:
    Migraine and RangerBP like this.
  16. Mar 24, 2019 at 1:42 PM
    #736
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    I only put in 1 also. The grill was hitting the 3.5 replacements so I had to redo and pull speaker in more.
    Stock wiring for 3.5 side
    Red + red to speaker red
    Black + black to speaker black
    Harness wires with solid line is black, no line is red
    Stock wiring for center 3.5.
    I forgot what colors but both middle went to one side and outside wires went to other side. If you want to post pic of oem center, i will remember.
    I used the capacitor wires that came from center speakers for the outside. I was getting bass out of them and was no bueno. I also went back to put the oem center back in to add midrange in the front. Plenty of highs with door and dash side infinity 3.5
    T-Rex266[QUOTED] likes this.
  17. Mar 24, 2019 at 5:18 PM
    #737
    TundraDrew
    TundraDrew New Member
    Drew
    Hahira, GA
    2020 White Tundra 1794 4x4
    Bakflip Revolver X4, Nitto Ridge Grappler 275-60R20
    I think my definition of "not hard" is different from your's. Well, it wasn't all that difficult, but my install took me about 16 hours over the course of a week and probably 30 emails to James! Granted, I did everything you did + sound deadening, but still. Sound deadening probably added about 8 hours.
    My only issue now to figure out is if the small amount of white noise I hear is normal or not. I can only hear it when the truck is off and music is turn all the way down, so I think my OCD is kicking in.
    My thoughts after install: as much as I love to DIY, the $650 I was quoted for install/sound deadening would've been worth it. That being said, I can put that $ into the next mod :)
  18. Mar 24, 2019 at 8:38 PM
    #738
    XNeewbie
    XNeewbie Eat-Sleep-Yota
    Charlie
    SC
    2017 Gray Tundra CM SR5 TRD 4x4
    20% Tints - Bull Rings - Rubber Mats - Toyota Center Console Cover - Clazzio Seat Covers - Pop & Lock - Bed LEDs w/ Timer - EvoOne Remote Start - FRAC Harness w/ Front Camera - Handle Bar - TRD Shift Knob - TRD Sway Bar - AJT Fob Cases & Battery Tie Down - Breather Mod w/ Filter - SDHQ Speed Sensor Covers - BORA 1-1/2" Spacers - TRD License Plate Frame - LEDs all Around - Door Sills - Front Seat Bracket Bolt Covers
    After installing the amp & setting it according to instructions I'm getting noise also but only when I have the volume turned all the way down. Does anyone else have this issue or fix?
  19. Mar 24, 2019 at 9:01 PM
    #739
    fishing guy
    fishing guy New Member
    Billy
    2017 White Platinum 4x4 Tundra
    N/A
    I had this too!!! To fix it, its some setting in your Maestro set up....at least for me that was the fix.
  20. Mar 24, 2019 at 9:09 PM
    #740
    XNeewbie
    Charlie
    SC
    Mine is Non-JBL so I don't have the DSR1. Just the amp and speakers from James. Not sure if it makes a difference.
  21. Mar 25, 2019 at 2:00 PM
    #741
    bard0117
    bard0117 New Member
    Sound deadening is my next step, hope its not that bad haha
  22. Mar 25, 2019 at 2:02 PM
    #742
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Check all your grounds and make sure power isn't ran with your audio cables.
  23. Mar 25, 2019 at 2:41 PM
    #743
    TundraDrew
    Drew
    Hahira, GA
    I used JL audio's tuning guide/audio files (using JL RD 900/5 amp) and adjusted the gain down, which helped kill most of the static. If you don' have an amp that shows clipping, look up ********* tuning instructions. I still have a little static, but I can't hear it at all with the engine running or audio playing so I'm ok with it.
  24. Mar 25, 2019 at 7:18 PM
    #744
    XNeewbie
    Charlie
    SC
    Double checked my ground and its solid. Ran the power wire on the passenger side. No aftermarket RCA wires. All factory wires. Wouldn't think it would cause an issue since many members ran it the same way. Thanks for the info though.
  25. Mar 25, 2019 at 7:19 PM
    #745
    XNeewbie
    Charlie
    SC
    I'll definitely try this next. Thanks for the heads up
  26. Mar 25, 2019 at 8:03 PM
    #746
    speckmon
    Thornton, CO
    is your gain turned up too high?
  27. Mar 25, 2019 at 8:21 PM
    #747
    XNeewbie
    Charlie
    SC
    Got it set exactly like this
  28. Mar 25, 2019 at 9:20 PM
    #748
    MGMTundra251
    I have static noise at zero volume and when I disconnect the rca cables from the amp, the noise goes away. That tells me that noise is coming from either the HU or the DSR1. Tried to lower the gain on the DSR1 (currently at -3.0 dB) but noise is still there. Other people with DSR1 have the same noise?
  29. Mar 26, 2019 at 2:56 AM
    #749
    Adam New Member
    I had to turn my front and rear gain down to the 11 oclock position for the hiss from the tweeters. No big deal (Factory JBL system). Didn't get rid of completely when I am sitting there with the truck not running, but when it is started, you cant hear it.
  30. Mar 26, 2019 at 10:09 AM
    #750
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    the his is from the bluetooth module in the radio . Some have it worse than others . adjusting the gains where its barely audible with volume all the way down is the best we have done with the factory head unit . The problem is TOYOTA made the radio where the bluetooth module is always on no matter what source you are on . If you need help getting rid of it shoot me an email with your settings pictured on the amp to tech12volt@gmail.com and I will tell you what you need to adjust . This is with both jbl and non jbl head units. If you were to stick you ear up to a factory system tweeter you can hear the noise with all factory components and you just amplified that noise by 10
Thread Status:
