***UPDATE***Tech12volts door and/or dash speaker group buy.-valid through 2/28/19
Discussion in 'Deals & Group Buys' started by Pudge, Jan 30, 2019.
Thread Status:
Not open for further replies.
  1. Feb 26, 2019 at 7:10 AM
    #541
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    I have a double cab truck. Not a crew max so that won’t work for me :(
  2. Feb 26, 2019 at 7:12 AM
    #542
    tubal
    tubal New Member
    SLC, UT
    Sorry, missed that. :(
  3. Feb 26, 2019 at 7:15 AM
    #543
    GiantsFanDan
    No problem
  4. Feb 26, 2019 at 7:21 AM
    #544
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    What is the AMP suggestion for NON-JBL guys with this kit?
    I am trying to understand difference between group buy speakers and amp vs OEM Audio (no-sub).
    Obviously price would be lower on 12volts but will it clean-up factory HU signal enough?
  5. Feb 26, 2019 at 7:38 AM
    #545
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I can run sub on stock amp non-JBL?
  6. Feb 26, 2019 at 7:44 AM
    #546
    GiantsFanDan
    Cemented and JoshuaA[QUOTED] like this.
  7. Feb 26, 2019 at 7:54 AM
    #547
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Dammit, don't temp me! I'm not ready to buy more lol
    Gonna wait to see if I need more oomph, I don't usually drive around thumping. I think I've lost some hearing from my clubbing days.
  8. Feb 26, 2019 at 8:17 AM
    #548
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    An amp is going to make a huge improvement to any upgrades speakers.
    GiantsFanDan likes this.
  9. Feb 26, 2019 at 8:29 AM
    #549
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Agree, no doubt. When I was stock HU, I would have just gone ahead and got an amp, but the Tesla android HU I installed last fall really woke up my stock speakers, so much so that I was hesitant pulling the trigger here. I might be happy with just more soundstage clarity after I install dash and doors.
  10. Feb 26, 2019 at 10:45 AM
    #550
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
    Same advice he gave me. I’m non-JBL, ordered amp, rack, and wiring and no DSR1 needed. James also confirmed the JBL replacement sub he had on group buy before will work great with that amp so I plan to add it. Bummer you can’t fit something behind seats in DC.
    GiantsFanDan[QUOTED] likes this.
  11. Feb 26, 2019 at 2:00 PM
    #551
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    Sent in a web order to James for the doors, and dash kit plus 5 rolls of Sound Skins.
    phogallen and Cfincke like this.
  12. Feb 26, 2019 at 5:25 PM
    #552
    GiantsFanDan
    I'll have to rethink my recovery storage if I do anything sub wise. Then I have to buy a new DuHa storage box that will work for a double cab with a sub.
    Cemented[QUOTED] likes this.
  13. Feb 26, 2019 at 6:08 PM
    #553
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    This is the route I chose to go. Went with sub first, hertz mids and tweeters and just purchased the Phoenix HU. Figure if it still doesn’t cut it then amp it is:)
  14. Feb 26, 2019 at 6:42 PM
    #554
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I really want a new head unit. I have a 5 channel amp, I just can't bring myself to buy the dsr1 for my OEM JBL headunit because I really dislike it. I'd rather get a aftermarket. But dont wanna/can not spend over 400 on one and all the harnesses required for it.
  15. Feb 26, 2019 at 6:45 PM
    #555
    ARES35
    Mile high
    Yes sir that was the only part not allowing me to pull the trigger on the amp was additional DSR1. Found the new designed Tesla with coupon code for $550. Just couldn’t beat that deal
    Pudge[QUOTED][OP] likes this.
  16. Feb 26, 2019 at 6:55 PM
    #556
    Pudge
    CT
    Does it work with steering wheel controls? Bluetooth? Pandora on the headunit? Android audio? Do you have to plug your phone into it to use all the features? I really havent heard much about the new design, I read the original being a nightmare to be honest
  17. Feb 26, 2019 at 7:08 PM
    #557
    ARES35
    Mile high
    I believe you can utilize Bluetooth via phone for connection. From what I’ve gathered once your phone is paired you can download any android app. Also believe all OE controls still work. I’m no pro though.
  18. Feb 26, 2019 at 7:12 PM
    #558
    CrewMaxT
    CrewMaxT New Member
    Alberta
    2018 CrewMax SR5
    Ordered doors and dash. Canadian currency conversion added $120 but still worth it IMO. I wonder how many kits he sold, I’m sure it’s over 24.
  19. Feb 26, 2019 at 7:16 PM
    #559
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    I know you got DuHa but if you have an OEM setup it is easy cut and with my swing case all good.
  20. Feb 26, 2019 at 7:21 PM
    #560
    TomC843
    Tom
    Charleston, SC
    When I saw DuHa the first time online I look every which way, even broke out the tape measure. I could not make the DuHa for factory sub work. JRT sub lot bigger than OEM option sub.
  21. Feb 26, 2019 at 7:49 PM
    #561
    jack_yaj
    jack_yaj New Member
    Jack
    2019 Midnight Black Limited DC TRD Off-Road
    Killer box. Where did you get it?
  22. Feb 28, 2019 at 8:06 AM
    #562
    Speakers should be sent out tomorrow :woot:
    Pudge[OP], D3Tundra and GiantsFanDan like this.
  23. Feb 28, 2019 at 11:50 AM
    #563
    Pudge
    CT
    I should be able to get the last of mine installed today
    Migraine and T-Rex266[QUOTED] like this.
  24. Feb 28, 2019 at 12:24 PM
    #564
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I ordered the doors , dash and sail panels. I think I have a good installer to do the job. Looked to order the amp, but missed out. The price is back to $449
    Pudge[OP] likes this.
  25. Feb 28, 2019 at 12:33 PM
    #565
    Pudge
    CT
    Shoot him an email on that price. Should still be on sale
  26. Feb 28, 2019 at 2:02 PM
    #566
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    Trd CAI, Trd Dual Exhaust, ESP Locking storage, Center Console Safe, Trd Rear Sway Bar, BFG Ko2, Pioneer Avic 8400nex, Husky Liners, 19 Trd Headlights, iHacker Harness, Tech12Volts Sub Upgrade
    Ordered the speakers to complete the trifecta! Waiting 20190228_150139.jpg at my front door for the amp
    JoshuaA, Pudge[OP] and Migraine like this.
  27. Feb 28, 2019 at 3:04 PM
    #567
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    OK i'm in. bought all 4 doors and the dash as well. now i've gotta get an amp and head unit. thanks for the refund, Uncle Donny, i mean Sam.
    jack_yaj, Pudge[OP] and T-Rex266 like this.
  28. Feb 28, 2019 at 4:59 PM
    #568
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    How does it sound now after you install the dash and door speaker?
  29. Feb 28, 2019 at 6:16 PM
    #569
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Finally got mine today, after UPS messed things up with the shipment, now I have another project to work on. Thank you @james@tech12volts for picking up the slack after UPS dropped the ball. Did you ever find out what happened to that first shipment?
  30. Feb 28, 2019 at 6:20 PM
    #570
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Haven’t installed yet. Will install this weekend and report then.
    831Tun and Pudge[OP] like this.
Thread Status:
