Uneven bed.
Discussion in '2.5 Gen Tundras (2014-2021)' started by FordyotaMan68, Mar 10, 2019.
  1. Mar 17, 2019 at 8:04 AM
    #61
    senn4586
    senn4586 New Member
    Orange County
    2014 White Tundra
    Rear LED, inside LED
    Just waiting to see what actually has happened since his last post. :popcorn:
    15whtrd likes this.
  2. Mar 17, 2019 at 8:39 AM
    #62
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    When I installed my leaf springs, the right side of the bed was sagging like yours. I called CB and he said to install a shim on top of the driver coilover. It leveled out all the corners by lifting the right rear to compensate for the lift in the front. It worked and I don't even notice the shim is there. Can use a few washers to see if that fixes the problem.
    15whtrd likes this.
  3. Mar 17, 2019 at 10:20 AM
    #63
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Watt maker likes this.
  4. Mar 17, 2019 at 12:13 PM
    #64
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I know. As soon as I pulled it out, it would’ve been pulled right back in.
  5. Mar 17, 2019 at 3:11 PM
    #65
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    What happened to the OP? Left us hanging.....
  6. Mar 17, 2019 at 6:07 PM
    #66
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Ba ha ha ha! Got me on that one! Ok, not funny.
  7. Apr 1, 2019 at 4:35 PM
    #67
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I saw a black one this afternoon just like this. Probably not AS pronounced but it was very noticeable, he sure did have a lean to the rear right. He had a lift, up front, maybe two inches. Wonder if the front left is too high maybe? Couldn't get a picture.
  8. Jan 11, 2020 at 9:05 AM
    #68
    Steve C.
    Steve C. New Member
    2019 Tundra Platinum
  9. Jan 11, 2020 at 9:22 AM
    #69
    Steve C.
    Steve C. New Member
    I have a 2019 Tundra Platinum and this uneven bed is one of 3 defects that Toyota service folks see and acknowledge but Toyota wont fix under warranty because they call them "normal." Never had a Toyota, but due to their BS and not standing behind their products - it will be the last.
    #1. Bed is visually uneven when view from the rear. Measuring the floor to the fender lip proves 7/8" difference from left to right. Toyota response "Many are uneven so it is not warrantable."
    #2. 20-30 small paint specks that when clean and polished can be seen and even felt with fingernail. Toyota response "Spots are visible but not not out of spec so not warrantable." When I ask what spec is, no one has an answer.
    #3 Grill molding just below the hood pops loose and shows an uneven bulge. You can pop in back down but then pops loose again after first bump in the road. Toyota response "We checked brand new ones in parts inventory and they all do that so we wont replace it under warranty."
    Great company, right???
