Uneven bed.
Discussion in '2.5 Gen Tundras (2014-2021)' started by FordyotaMan68, Mar 10, 2019.
  1. Mar 10, 2019 at 7:31 AM
    FordyotaMan68
    FordyotaMan68 [OP] New Member
    Eric
    2014 Toyota Tundra
    None yet.
    I just bought a used 2014 tundra and after I cut the check and got it parked in the garage I noticed that the right side of my bed was lower than the left. I took it back to Jim Taylor of Ruston,La where I purchased it form and the claimed they did not notice it. They took it to their body shop and said that there was nothing they could do to it to straighten it. Well when I picked the truck up the bed was leaning worse than it was before. There was nothing on the car fax that said it was wrecked or anything. No mods have been done to my truck can anyone help please. I love the truck by the way, except the gas mileage. Help!!
  2. Mar 10, 2019 at 7:33 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Welcome from CO. Pics would help a bit.
  3. Mar 10, 2019 at 7:54 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Ok on it. I guess I’m doing this right.
    TokerJoker likes this.
  4. Mar 10, 2019 at 7:58 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Wow...
    Are the rear shocks the same settings, a lift missing?
    15whtrd and TokerJoker like this.
  5. Mar 10, 2019 at 7:58 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    wow that is bad! how did you not see that when buying the truck? ive seen beds a little cocked, kind of a normal thing, but this is crazy. No way i could live with that.
    Rider0120, TokerJoker and Watt maker like this.
  6. Mar 10, 2019 at 8:00 AM
    Aurora CO
    Whoa! Get underneath and check your passenger leaf spring compared to the drivers side. Check the shock mounts too. Eyeball the frame for any obvious issues. Might just want to get the frame checked by a decent body shop if nothing obvious with the rear suspension.
  7. Mar 10, 2019 at 8:07 AM
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    That is really bad! I agree with the others check suspension. Also check the tires to make sure they are the same size.
  8. Mar 10, 2019 at 8:08 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    Every truck I've had has had a slight lean one way of the other. My current Tundra is the first one that I've had that's perfect straight and level.
    But I'm talking about a small difference. What you have is pretty extreme IMO. I would definitely have that checked out ASAP. Hopefully it came with some type of warranty or maybe even a return policy? It's probably fixable but I'd tell them I want to return it unless they can fix it PDQ
    Max Power and Black Wolf like this.
  9. Mar 10, 2019 at 8:09 AM
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    Measure the rear bumper. It almost looks like the bumper may be cocked.
  10. Mar 10, 2019 at 8:09 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Everything seems even everywhere else no gaps at the back of the truck cab. The gram doesn’t seem to be altered front doesn’t have any apparent lean. Help!!
  11. Mar 10, 2019 at 8:11 AM
    WHITEOUT
    WHITEOUT New Member
    2016 Tundra TRD 4x4
    K&N Cold air intake Roll-up bed cover 2.5-1 ToyTec spacer lift 20x9 Maverick D539's wrapped in 33" AMP terrain pro's Westin HDX matte black drop steps TAC Bully Bar Upgraded front grille (chrome to Black honey comb style)
    My old 2003 Tundra had that. It ended up being the leaf springs on the passenger side.
    15whtrd and Black Wolf like this.
  12. Mar 10, 2019 at 8:12 AM
    B737
    Jersey Shore
    The gaps at the bumper are way off. I would return it to dealer, tell them to give it back when its fixed.
  13. Mar 10, 2019 at 8:14 AM
    Aurora CO
    Get a tape measure and check the center distance of both leafs to bottom of the frame.
  14. Mar 10, 2019 at 8:18 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I would bring this back. “Nothing they can do” means the dealer is not owning the problem.
    I am sure a decent mechanic can determine whether the lean is suspension related, that will be easy to locate. Worst case is the frame.
    Most beds are basically a box bolted to the frame. There are shims and spacers. In your case the alignment at your bumper looks even. Not so good...
    Also check for a broken leaf on your spring. It could be hidden behind a clamp
    You could also have someone drive it and follow to check the way it moves. In some cases you can detect a bent frame by the way the car “crabs” down the road.
    It’s also silly to mention, but check the tire air pressure and compare tire size all around.
    Most states have return laws on new/used car sales that allow you to change your mind no questions asked.
    JohnLakeman and 15whtrd like this.
  15. Mar 10, 2019 at 8:19 AM
    Finch, 15whtrd, Black Wolf and 3 others like this.
  16. Mar 10, 2019 at 8:21 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    I looked at your pics again and I think above post is right about the gap difference.
  17. Mar 10, 2019 at 8:21 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Ok. Thanks working on all suggestions.
  18. Mar 10, 2019 at 8:31 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Oh and the way they had it parked and if your standing right behind it it’s unnoticialbe. But it’s more noticeable now since they try to do something to it.
  19. Mar 10, 2019 at 8:34 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Check the gap between the bumper and the body. Your right side looks pushed in. But it also looks like there may be something else going on. The top of the tailgate doesn’t look parallel to the front of the bed.
    15whtrd likes this.
  20. Mar 10, 2019 at 8:36 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    That ain’t right
  21. Mar 10, 2019 at 8:40 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Hate that for you! Get a second opinion from someone it cannot hurt at all
  22. Mar 10, 2019 at 9:01 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    How long ago did you buy it? I’d take it back and buy another. You know damn well they knew about it.
    Watt maker likes this.
  23. Mar 10, 2019 at 9:16 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Could we see some better pictures in the highlighted areas please 4085D7BE-FEEE-4E8E-BAD7-8CDA45086643.jpg
  24. Mar 10, 2019 at 9:17 AM
    Omohundro
    Jody
    McMinnville TN
    What I’m really getting at is the tail gate gap to the bumper step pad even?
  25. Mar 10, 2019 at 9:23 AM
    Aurora CO
    Was there a Carfax report? A nice talk with previous owner if possible could shed a lot of light as to what may have happened. I'm really sensing something very shady going on.
  26. Mar 10, 2019 at 9:34 AM
    Omohundro
    Jody
    McMinnville TN
    Do not count on Carfax. The idea is great but most repaired accidents are not reported.
  27. Mar 10, 2019 at 9:42 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    I’m going to check on it when I get out of church.
    specter208 likes this.
  28. Mar 10, 2019 at 9:44 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    I tried to call the previous owner when I first noticed it, didn’t get an answer. I’m so sure they knew, they offered me a years worth of oil changes. I’m not done with them though. Consulting with a lawyer that goes to my church.
  29. Mar 10, 2019 at 9:53 AM
    15whtrd
    15whtrd Mr. Blonde
    Your right side of the bumper looks like someone tried to adjust it and pushed it down which created a warp in the plastic. I think adjusting the bumper is covering up something else that is going on. The bumper mount directly to the frame. The bed mounts to body mounts and then the frame. What are the measurements from the top of the bed to the ground on the left and right corners? Also check ride height from center of the wheel to fender lip all the way around (all four corners). As everyone mentioned, check the suspension. Also another thing to check would be the body mounts from the bed to the frame and make sure they are all the same. Maybe one rotted out or is missing.
    You have to think of the entire truck instead of focus on just one corner. A slight difference in the front can make a slight difference in the opposite corner. Could even be a frozen rear shackle causing it to bind up.
    Toyotoholic and Black Wolf like this.
  30. Mar 10, 2019 at 9:54 AM
    15whtrd
    15whtrd Mr. Blonde
    This is my church. Very nice truck. Go with God
