Uneven bed.
Discussion in '2.5 Gen Tundras (2014-2021)' started by FordyotaMan68, Mar 10, 2019.
  1. Mar 10, 2019 at 10:11 AM
    FordyotaMan68
    FordyotaMan68 [OP] New Member
    Eric
    2014 Toyota Tundra
    None yet.
    LoL, still here.
    Watt maker and 15whtrd like this.
  2. Mar 10, 2019 at 10:15 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
  3. Mar 10, 2019 at 10:22 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Exactly. The bed appears to be actually twisted; OK at the cab, tilted at the tailgate.
    Edit: If the suspension and frame check out, it might be worth checking if there are shims under the right rear corner of the bed. It's like someone removed the bed, and forgot to re-install shims at the right rear corner. (I'm assuming the beds have shims to compensate for frame errors...haven't gotten under to check out.)
    15whtrd likes this.
  4. Mar 10, 2019 at 10:37 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Oh and did I mention, when I dropped my truck off at the dealership for them to try and repair it. They blessed me with a loner. A 2014 Nissan Mariano. It smelled like a dog in heat, the transmission had a whine out this world it was wrecked on the driver side back panel, and the radio wouldn’t pick up not one station. Good thing though, it had push start so I could leave it running while locked when I stopped for coffee. I didn’t lock it thought.
    YeeYeeTundra, Black Wolf and 15whtrd like this.
  5. Mar 10, 2019 at 10:38 AM
    15whtrd
    15whtrd Mr. Blonde
  6. Mar 10, 2019 at 10:41 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Faht Nocker
    That’s exactly what it is. I can’t get my fingers in the right side of the bumper.
    Faht Nocker and Black Wolf like this.
  7. Mar 10, 2019 at 10:51 AM
    Faht Nocker
    Woody
    Milky Way
    Sounds like (according to the video) 2014 was a bad year for the alignment of the bumper. who knows?
  8. Mar 10, 2019 at 10:54 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    I have no idea of what I’m looking for but I’m going under (truck) in 10 min. Gotta get out of this 6 piece suit.
  9. Mar 10, 2019 at 11:14 AM
    JohnLakeman
    You've sniffed a beatch in heat?!... :eek:
    Notachickmagnet likes this.
  10. Mar 10, 2019 at 11:29 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    You have more than just a bumper alignment issue. That whole side is sagging. Both rear tires are the same size right?
    Brownsfanhere likes this.
  11. Mar 10, 2019 at 11:32 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    So I look under the carriage and I didn’t see any appearent issues with the springs, frame being buckled, freak wields or anything. So I measured middle of rim to fender all the way around
    Front (R) 21 Front (L) 21
    Rear (R) 23 Rear (L) 24
    Definitely the bed.
  12. Mar 10, 2019 at 11:33 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Checking tire size now.
  13. Mar 10, 2019 at 11:36 AM
    JohnLakeman
    Good info. Confirms it's a problem. I would measure ground to the frame on each side, in same location, directly over the rear axle.
    15whtrd likes this.
  14. Mar 10, 2019 at 11:43 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Tires are the same make and size.
    The left has 30lbs of pressure
    The right has 41lbs (problem side)
    I’m sure Jim Taylor for did that to see if that would rectify the situation.
    I guess my next move is to take it to the local Toyota dealership to get an opinion. And here where I live, good service is surly not a virtue. A Technician is just a fancy word for saying I studied at a local vo-technical institution for 2 weeks so I can hook up a machine charge $100 for a diagnosis just to tell you We Can’t Locate The Problem.
    Watt maker likes this.
  15. Mar 10, 2019 at 11:46 AM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    38 3/4 (L)
    38 1/8 (R) problem side
    Wheel well to ground.
  16. Mar 10, 2019 at 11:57 AM
    JohnLakeman
    Do this and eliminate possibility of broken leaf or spring sag on right side.
  17. Mar 10, 2019 at 12:18 PM
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Ok, can any reputable shop help me with this.
    Black Wolf likes this.
  18. Mar 10, 2019 at 12:23 PM
    Sure, but I'm thinking go to a Yota dealership if you have one nearby. Tell them who you bought your Tunny from and show them the sag problem and ask if they can determine the cause and what remedies you might have including dealing with the folks you bought it from.
  19. Mar 10, 2019 at 12:32 PM
    #49
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Thanks will do tomorrow.
  20. Mar 10, 2019 at 2:20 PM
    #50
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    LOL
    What if he got bored and called during service and the Pastor’s cellphone rang.
    Black Wolf and Watt maker like this.
  21. Mar 11, 2019 at 2:27 PM
    #51
    FordyotaMan68
    Eric
    2014 Toyota Tundra
    None yet.
    Well just left Toyota and they said there’s nothing they can do I need to take it to a body shop or something, they don’t have the capabilities to even start a conversation about the “tundra lean.” So I guess it’s on to the next.
    JohnLakeman, 15whtrd and Black Wolf like this.
  22. Mar 11, 2019 at 2:29 PM
    #52
    They didn't even want to look at it?
  23. Mar 11, 2019 at 2:44 PM
    #53
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    I was just going to recommend a LEGIT body shop with a frame machine. Pay them for a 4 Wheel alignment. This is money well spent to preserve the tires anyway. Remember that these guys fix frames for a living. They will find it. Have them do a full write up for the Stealership that sold you the truck. Let them know your attorney buddy has the original and they received a copy. If this doesn't work then just buy two bags of play sand and keep them on the driver's side LOL.
  24. Mar 11, 2019 at 5:44 PM
    #54
    mambo143
    mambo143 New Member
    Phil
    Maine
    If I remember correctly, you bought this from a dealer. You are an honest customer who went into this dealership expecting an honest transaction. Unless you made an “as-is” transaction, IMO The seller is the one who should be scrambling and doing all the work in order to make this right.
  25. Mar 12, 2019 at 3:41 AM
    #55
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
  26. Mar 12, 2019 at 4:59 AM
    #56
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Return the damn thing. You bought it a couple days ago right. Waiting longer is only going to make that process harder.
    Moon Puppy likes this.
  27. Mar 12, 2019 at 8:17 PM
    #57
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I agree return the truck or demand them to fix it. You were sold a defective truck. It's going to drive you mad everytime you look at it. It would me. Let us know the outcome.
  28. Mar 13, 2019 at 8:33 AM
    #58
    mambo143
    mambo143 New Member
    Phil
    Maine
    You have done your due diligence here on the site and with the dealership. Literally put the ball (truck) back in his court. Every moment you wait takes away leverage and makes him think that he can make you go away. I agree with above. This will leave a sour memory and every time something happens with this truck, you will remember. Psychologically, at some point, every deal has it’s breaking point; when walking away actually feels better than the deal.
  29. Mar 13, 2019 at 9:42 AM
    #59
    zebian2
    zebian2 New Member
    Jamy
    I like that
  30. Mar 13, 2019 at 10:34 AM
    #60
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    This would drive me crazy, waiting for outcome :popcorn:
