Undiagnosable Clunking
Discussion in '2.5 Gen Tundras (2014-2021)' started by SR5camper, Mar 1, 2021.
  1. Mar 2, 2021 at 5:08 PM
    #61
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Have you checked the CV axle nut? I know you said everything was checked but since this started after the regear it is a possibility. Any change in braking noticed? Loose CV nuts will cause a “air in lines” feel to brake pedal.
    HulkSmurf14 likes this.
  2. Mar 2, 2021 at 9:07 PM
    #62
    SR5camper
    SR5camper [OP] New Member
    AZ / TX
    2015 SR5
    Interesting, I'm almost certain that my harness is perfectly snug since I just installed an ARB compressors using that utilizing that brscket but I'll check again. Thanks for the link!
  3. Mar 2, 2021 at 9:07 PM
    #63
    SR5camper
    AZ / TX
    2015 SR5
    All the hardware is definitely there. Just installed an ARB compressor using that bracket.
    Dalandshark[QUOTED] likes this.
  4. Mar 2, 2021 at 9:10 PM
    #64
    SR5camper
    AZ / TX
    2015 SR5
    I don't think I've checked that one any further than visually. Braking is just like the day I bought it so nothing abnormal there. But worth a shot to check again.
  5. Mar 4, 2021 at 4:02 PM
    #65
    okietundra18
    okietundra18 New Member
    Green Country
    2018 Ltd OR
    This! This is the way! I had a similar annoying clunk, this was it! Thank you! Great forum
    MJoeP[QUOTED] likes this.
  6. Mar 4, 2021 at 4:31 PM
    #66
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Bolts that hold front diff to frame?
    landphil and AZBoatHauler like this.
  7. Mar 5, 2021 at 4:03 PM
    #67
    SR5camper
    AZ / TX
    2015 SR5
    I'll be checking it this evening so fingers crossed
    okietundra18[QUOTED] likes this.
  8. Mar 5, 2021 at 4:04 PM
    #68
    SR5camper
    AZ / TX
    2015 SR5
    Checked multiple times. Nice and snug
  9. Mar 5, 2021 at 6:50 PM
    #69
    ZPhilip
    Philip
    West Chester, PA
    Checked all 4 cam bolts torqued to spec?
  10. Mar 6, 2021 at 7:03 AM
    #70
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Nobody has mentioned transfer case bolts...
  11. Mar 6, 2021 at 7:35 AM
    #71
    jwatt
    jwatt I heart men
    Jack
    Oregon
    That s how the 4 wheel shop finally found the noise in my lift. It was loose uca bolt. A mechanic took it for a 10 minute test drive and never heard anything, but when he pulled into the shop, and hit the brakes the other mechanic heard it. He started rocking it back and forth, and you could really hear it.
  12. Mar 6, 2021 at 7:47 AM
    #72
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Just got my 2021 Tundra and I've noticed a very slight clunk that is felt in the steering wheel on suspension cycling.
    When she goes in for her first check up, I'll make note.
    I checked the engine compartment / suspension by eyeball to see if anything was obvious but nada.
  13. Mar 10, 2021 at 8:26 PM
    #73
    ZPhilip
    Philip
    West Chester, PA
    Any progress or resolution?
    Jbehredt and LarryDangerfield like this.
  14. Mar 11, 2021 at 4:45 PM
    #74
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Inquiring minds need to know!
  15. Mar 13, 2021 at 7:44 PM
    #75
    SR5camper
    AZ / TX
    2015 SR5
    If by cam bolts you mean the LCA bolts then yes
    Bigstick likes this.
  16. Mar 13, 2021 at 7:45 PM
    #76
    SR5camper
    AZ / TX
    2015 SR5
    They've been checked
  17. Mar 13, 2021 at 7:46 PM
    #77
    SR5camper
    AZ / TX
    2015 SR5
    Nope, just more wasted time replacing parts and fiddling with things...
  18. Mar 13, 2021 at 7:47 PM
    #78
    SR5camper
    AZ / TX
    2015 SR5
    Updated!
  19. Mar 13, 2021 at 7:52 PM
    #79
    SR5camper
    AZ / TX
    2015 SR5
    UPDATE: Two ideas provided in this thread have been tried.
    AC compressor bushings have been replaced, new ones didn't really do any better than the old ones. Thing still moves around more than I would like but it's not causing the clunking.
    Wire harness on passenger side firewall has been tinkered with. There was little slop to be taken up to begin with so no difference was made.
    Back to the drawing board
  20. Mar 13, 2021 at 8:45 PM
    #80
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    This may be really obvious so sorry if it's already been done but doesn't look like it's been mentioned, are your Balljoints all in good shape? Got a similar sound to this in my old Yukon from a broken ball joint. Also what about u joint play??
  21. Mar 13, 2021 at 9:17 PM
    #81
    SR5camper
    AZ / TX
    2015 SR5
    Yeah, already addressed in the original post
  22. Mar 13, 2021 at 9:27 PM
    #82
    Wahayes
    Will
    2017 tundra limited
    Darn ok sorry I read through all of it but by the time I got to the end of the thread I couldn't remember
    SR5camper[QUOTED][OP] likes this.
  23. Mar 13, 2021 at 10:23 PM
    #83
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    I gotta say... one clean looking truck
    SR5camper[OP] likes this.
  24. Mar 14, 2021 at 5:54 AM
    #84
    Jbehredt
    Westminster, CO
    Had my wife and a buddy listen with headphones. Wife says it’s a water bottle in your door pockets. She knows because her 4Runner made the same sound the other day. Buddy says it sounds like ever Ford he’s ever been in. Sorry not much help but we’re not giving up!
  25. Mar 14, 2021 at 6:21 AM
    #85
    Jbehredt
    Westminster, CO
    Anything felt in the steering wheel? Maybe a steering shaft. The intermediate shaft that passes through the firewall has been known to cause clunking. My Silverado made a similar noise and it was a worn plastic bearing where it passed through. Common on that truck. Not so much on the tundra but also not unheard of.
  26. Mar 14, 2021 at 8:57 AM
    #86
    SR5camper
    AZ / TX
    2015 SR5
    Well I appreciate the input but definitely not a water bottle. I'm a stickler about loose things in the cab for that exact reason haha
    I would expect this with a Ford or GM, but being a Toyota I won't accept this as an answer!
  27. Mar 14, 2021 at 8:58 AM
    #87
    SR5camper
    AZ / TX
    2015 SR5
    No definitive correlation, but steering was my initial suspicion. I've checked the steering shaft for slop in the u-joint and slop in the shift itself and it's solid.
  28. Mar 14, 2021 at 9:07 AM
    #88
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I had a clunking sound coming from under the rear of my tundra, went on for awhile before I went over a speed bump, heard the clunk and threw it in park to check under the truck for the dozenth time. The problem finally showed itself to be a broken leaf within my leaf pack and it finally slid away from the cracked portion and was just dangling (pinched in place by the other leafs, if you will), if it hadn’t slid apart, I would have never been able to get close to the hairline crack to diagnose it... always figured it was the 400lb topper on the rear for 7 years that’s weakened the already inferior leafs...Good luck.
  29. Mar 14, 2021 at 9:41 AM
    #89
    SR5camper
    AZ / TX
    2015 SR5
    Just warrantied out my icon leafs last month and installed a new pack so they are good. But I have lost count of how many times I've jumped out of the truck to check something
    Jrharvey02[QUOTED] likes this.
  30. Mar 14, 2021 at 11:30 AM
    #90
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    Are you in 4wd in the video?
    To me it kind of sounds like it's coming from your diff, especially since you recently just regeared.
