2018 “clunk” noise.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Scottundra91, Jan 22, 2018.
  1. May 12, 2018 at 8:36 AM
    #61
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    I have the TRD dual exhaust and it was put on by the dealer and i do not have the issue you are describing. Is the exhaust not hung right so its rattling on start up?
  2. May 12, 2018 at 2:03 PM
    #62
    tlr641
    tlr641 New Member
    Robb
    Oregon
    2018 Tundra Sport
    Trd dual exhaust, bilstein 5100’s, tint
    It only does it after sitting for a hour or more. Does not do it every time, Toyota field tech went over it with the service tech.
    It has no other issues related to the sound, shifts perfect, drives perfect, etc.
    Think if it was not hung right it would be more frequent?
    I don’t know?
  3. May 12, 2018 at 4:49 PM
    #63
    71_340
    71_340 The German
    Hans
    FLW, MO
    I know, it it is probably frustrating but at least it is documented should something go wrong at a later time.
    NCinCO likes this.
  4. May 12, 2018 at 5:17 PM
    #64
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    mine has done it every start up since new, dont know what it did the first 13 miles but from 14 up its done it like clock work.
  5. May 12, 2018 at 5:23 PM
    #65
    UNVMYIS
    UNVMYIS New Member
    Same issue here, Glad to see this thread come up so I can stop worrying about it.
  6. May 20, 2018 at 9:05 PM
    #66
    2018_10dra
    2018_10dra New Member
    2018 Tundra TRD Limited
    Have 2018 TRD Ltd Edition. I heard this clunky noise too every time I pull out of the driveway and out of parking lot and when I drive over a hump. I took it to the dealership and was told nothing to worry about...it's normal :(! WTF! It sounds like there's something loose underneath and it's normal? I was asked to make further observations and let them know if it persist. Not happy!
    lotsip likes this.
  7. May 21, 2018 at 8:04 AM
    #67
    smooosh
    Ongoing project
    Thats a different noise then this post. The clunk in the post is withing the first 10 seconds of when you start rolling and will not happen again until you turn off the truck. Its a test. Yours if it happens when you go over a bump sounds like suspension
  8. May 21, 2018 at 3:42 PM
    #68
    2018_10dra
    It also happens very similar to what others had described here. "I heard this clunky noise too every time I pull out of the driveway and out of parking lot" this is more consistent than the noise I hear when going over the hump.
  9. May 21, 2018 at 3:43 PM
    #69
    smooosh
    Ongoing project
    That is normal. It’s the abs check.
  10. May 21, 2018 at 3:52 PM
    #70
    2018_10dra
  11. Jun 7, 2018 at 11:45 AM
    #71
    IrishGuy
    IrishGuy New Member
    Neal
    2015 Black Tundra SR5 Double Cab
    Thank you all for your posts and input. I just bought a 2015 Tundra with 32,400 miles on it and I have heard the clunk every morning that I put it in gear and start rolling down the road. The clunk usually happens before the locks engage at 15 MPH. Got on here to see what type of issue that it may be. I feel a little more comfortable now.
    FSUTundra likes this.
  12. Jun 29, 2018 at 5:04 PM
    #72
    sh0ck3r
    sh0ck3r New Member
    Hopefully I can add some help from my experience with this issue.
    Keep in mind that most folks here may be hearing the ABS check which ONLY happens when you turn your vehicle on from a “cold” start. Meaning you turned the engine off, removed the key completely and exited the vehicle. At 15 mph the ABS will do a self check one time and that’s it until you turn it off and do the startup process over again. It’s a safety check and nothing you can do about it.
    So...
    2016 Platinum Tundra, bought used with 25,000 mi. Noticed it about a week after I started driving that while taking off from a stop light or as I was braking for a stop and the moment the truck was about to come to a complete stop; clunk. This would only have about 60-70% of the time. After 4 trips to the dealership and a Toyota FST coming to look at it, they were finally able to locate the noise.
    In the engine compartment, on the firewall in front of the passenger side there was a wire harness that sticks out from the firewall and holds a large wire group. When the engine would crank and and twist from the torque, it would cause this wire mount to shift ever so slightly and cause a clunk that turned into Chinese water torture over time whenever I heard it.
    The fix was applying some felt padding and zip ties to stop the piece from moving. To my astonishment it fixed it.
    Now there was a second noise I had to deal with which I initially thought was a clunk but turned out to be a creaking sound from under the hood. Long story short, the air filter box. On a cold morning, accelerating from a stop I would hear a creaking sound, almost a clunk. First thought was suspension but thought about my initial clunk problem. Opened the hood and started grabbing around on more things to make noise. Sure enough, the air box would freak every time I moved it.
    Solution: used some door weather strips laying around the house to prevent the top plastic piece (MAF side) from rubbingbwith the bottom (air filter) side. Problem solved.
    I can understand frustrations as I was so angry that I just about traded it in for something else. Looks like I’ll keep it around for a while after all.
    Pictures added to show the zip tie location and the air box weather stripping.
    I also didn’t proof read this... oh well.
    phabej likes this.
  13. Jul 5, 2018 at 7:40 PM
    #73
    laura
    laura New Member
    Laurs
    2017 Black Tundra CrewMac 4x4
    I have that same awful clunk on my 2017 Tundra. Usually when I reach around 5mph but also when I make a right turn from a dead stop it sounds like awful metal clanking underneath and I loose traction which is scary when you are pulling onto a highway. I've gone to the dealership twice and they haven't been able to duplicate the problem. I'm not gunning it .. just accelerating normally. Tonight when pulling onto the freeway from a stop I lost traction, the awful clanking noise (worse than normal) and then all of a sudden shot across the road. O was on flay, dry road. Very scary. I no longer feel safe in the truck.
  14. Jul 5, 2018 at 8:00 PM
    #74
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    Where exactly did I put the felt padding?
    HecticEnergy likes this.
  15. Jul 5, 2018 at 8:02 PM
    #75
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    Welcome :wave:
    laura[QUOTED] and HecticEnergy like this.
  16. Jul 9, 2018 at 5:03 PM
    #76
    F150 blowz
    F150 blowz New Member
    Michigan
    2023 CM SR 4x4
    I just assumed it was my truck saying hi to me in the morning.
    Silv333 likes this.
  17. Jul 9, 2018 at 9:17 PM
    #77
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I have the same issue and noticed it from day one. I asked the service advisor when I was in getting my alignment (250 miles). They said make an appointment and come back. This thread will save me from doing that (I have 450 miles on my truck now).
  18. Jul 10, 2018 at 7:22 AM
    #78
    laura
    laura New Member
    Laurs
    I called the dealership and they want me to leave the truck with them overnight so they can drive it first in the morning. Because of the awful traction on dry flat roads they are going to check the traction control system and have even mentioned the transmission so we will see what they find. I just want it on record that I have asked for the problem to be looked at more than once since it's a pretty new vehicle and I want to know since I am not a mechanic that it's safe and that everything is operating the way that it's supposed to.
    r1-superstar likes this.
  19. Jul 10, 2018 at 10:54 PM
    #79
    r1-superstar
    DB
    UTAH
    Let us know what you find out.
  20. Aug 24, 2018 at 12:20 PM
    #80
    P-funk
    P-funk New Member
    Parnell
    2018 Tundra CM TRD Off Road
    How do you change the doors to lock at speed?
  21. Aug 24, 2018 at 12:43 PM
    #81
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    Have the clunk, it's at 6 mph.
  22. Aug 24, 2018 at 2:07 PM
    #82
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    It's somewhere in the settings on the main display. For me at least.
  23. Aug 24, 2018 at 2:16 PM
    #83
    P-funk
    P-funk New Member
    Parnell
    Dashboard display or stereo? I checked both but didn’t see it. I’ll check again Thanks
  24. Aug 24, 2018 at 2:17 PM
    #84
    Redbeard321
    The stereo. Its buried in there somewhere.
  25. Aug 24, 2018 at 2:19 PM
    #85
    P-funk
    P-funk New Member
    Parnell
    Thanks again
  26. Aug 24, 2018 at 5:23 PM
    #86
    P-funk
    P-funk New Member
    Parnell
    Well I found it but the clunk happens around 6 mph and the doors lock at 15. I guess I’ll have to get used to the clunk...
  27. Aug 24, 2018 at 9:54 PM
    #87
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Is there a sound/video of this clunk noise..in my 2016 1794 cm, hard for me to explain but sort of a thump feeling on my steering wheel when I break or accelerate, random speeds and happens randomly, I retorqued my wheels, had vehicle on lift and check if wheels were loose, checked brakes and it's all good,..cant seem to figure it out..but drives fine overall just bugs me..
  28. Oct 25, 2018 at 2:15 PM
    #88
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Same.
    Yes - same here.
    -- How is this normal? LOL it's like Chevy Shake is normal or that the injectors making sounds like exhaust leak is normal.. I call BS. Someone didn't do their job correctly when engineering this vehicle.
    200+ miles and it's doing the same thing. Too new for this. ROLLS EYES..
  29. Oct 25, 2018 at 2:22 PM
    #89
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I will try this..
  30. Oct 25, 2018 at 2:32 PM
    #90
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    I probably have a clunk on my 18, but I've never noticed. I might be used to the Tacoma, which seems to make occasional random noises. I used to worry about the Tacoma noises, but only because I had a Land Rover Discovery before it.
