Ultimate OEM Toyota Parts Thread for 3rd gens (2022+)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2022.
  1. May 18, 2022 at 12:50 PM
    #241
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I had to track down a VIN from a truck that had the set up. It looks like those are correct for a Crewmax. I need to update the OP with those too.
    Yes, we can order them. Though it may be a while before they arrive. I've got a lot of them on order now. It's looking like they will be coming in middle of next month or so.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tun-step-sub-assembly-bac-pts3034000st
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tun-bracket-step-sup-pts3034000bk
    MMTundra likes this.
  2. May 18, 2022 at 1:02 PM
    #242
    SlimSeville
    SlimSeville New Member
    2022 Tundra SR5 XP
    Thank you! Ordering now.
  3. May 19, 2022 at 8:08 AM
    #243
    TheBandit181
    TheBandit181 New Member
    Todd
    North of Pittsburgh, PA
    I recently reserved a 2022 SR which, of course, does not include the side deck rails. I would like to add these but all the deck rail kits that I have found seem to support 2007-2021. I haven't found a kit for 2022.
    Are they the same? If not, is there a kit specifically for the 2022?
  4. May 19, 2022 at 9:34 AM
    #244
    Roman
    Roman
    Franklin, TN
    According to the catalog, they are not the same as the previous model. They have different part numbers. Also, Toyota is not currently offering the deck rails in an accessory kit like the previous model. Unless that changes, these can only be bought as replacement parts and are all sold individually. Looks to be around $365 for all three and the hardware.
  5. May 20, 2022 at 10:07 AM
    #245
    Dave55
    Dave55 New Member
    Does anyone know where to get a hood protector (bug shield) for the 22 Tundra?
  6. May 20, 2022 at 6:15 PM
    #246
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    @Roman
    I don't know if this is in your realm. Are there part numbers for the 22 TRD Pro fox shocks?
    Also any part number for the TRD pro light bar switch?
  7. May 21, 2022 at 4:54 PM
    #247
    TheBandit181
    Todd
    SR has the header rail. What is the price for just the sides and side hardware?
  8. May 22, 2022 at 10:10 AM
    #248
    WarEagle1794Tundra
    WarEagle1794Tundra New Member
    Justin
    2022 Black Tundra 1794
    Advanced Package
    Hey @Roman — I have a 22 Tundra Hybrid 1794 edition coming in next week. I asked my dealer if I could go ahead and order the TRD off-road grill and off road black wheels with center caps and lug nuts and they are struggling to get me back part numbers and quotes. Do you mind sending me the links for those so I can either order through you or send them to my dealer to help them?
  9. May 22, 2022 at 2:20 PM
    #249
    TSS Army Green
    TSS Army Green New Member
    @Roman Do you know the part number for this button clip that is on the door panel?
  10. May 22, 2022 at 2:28 PM
    #250
    tunfundra
    tunfundra Better red than dead
    2022 Limited DC TRD OR SS-Red
    I broke one while installing my new handles... I think this is it: 67601L
    Part Number: 90467A0016B2
    Going to swing by my dealer and see if they have any...
  11. May 22, 2022 at 2:57 PM
    #251
    TSS Army Green
    Thanks for the lead
  12. May 22, 2022 at 6:05 PM
    #252
    MMTundra
    MMTundra New Member
    2022 Army Green TRD OR Ltd
    Well, they work, but ran into one snag - the seam at the rear doors where the lower window seal piece meets the vertical trim piece is pretty gaping. Not sure if I did something wrong or not - it does come with a little trim piece that looks like it’s supposed to cover this gap… but, the little trim piece doesn’t fit all that well and it doesn’t snap in or anything, it’s almost like it needs to be glued - anyone have experience/luck with this? Posted photos of chrome before, black after, with close up of the gap I’m referring to.F47A2480-E311-46EB-86A3-4C8DB54BE5AC.jpgD21AE229-AC3D-4DC9-8512-24D398EDCE00.jpg 8FB7CC53-29D8-4689-8018-D9E2AD141606.jpg
  13. May 22, 2022 at 8:01 PM
    #253
    jdub22
    jdub22 New Member
    Looks so much better though. Thinking about doing this but that gap is concerning
  14. May 22, 2022 at 8:20 PM
    #254
    MMTundra
    MMTundra New Member
    Agree it looks better but also agree the gap is concerning! Hoping someone has some insight on this - the little 1/4” trim pieces I mentioned looked promising but they clearly don’t just snap into the gap and I’m not about to glue them as they don’t really line up… the chrome takeoffs look like they connect a little different to the vertical piece to prevent this gap.
  15. May 22, 2022 at 9:20 PM
    #255
    Swarley
    Swarley New Member
    One of those things that I probably wouldn’t have noticed but once I see it can’t be unseen. :(
  16. May 23, 2022 at 7:33 AM
    #256
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    How difficult was the install? Timeline?
  17. May 23, 2022 at 8:58 AM
    #257
    tunfundra
    Handles are not a hard install... kudos to the Toyota engineers on that one.
    Used the papadave418 video. Slightly different for DC vs CM on rear doors... only two screws not three.
    Took me two hours. The fiddly little connectors take some time, but really it wasn't very challenging. Get the proper tools from Harbor Freight or Amazon... you will need them.
    When you pull off the door panel, some of the little white clips go flying so keep an eye out for those. Easy to put back in place.
    I set up a folding table within arms reach to set parts and tools on. Also, a headlamp was help.
    Took a while to get the driver's door handle in correctly as the key lock is sort of in the way. Need to carefully partially push in, bring it back against the key lock, and then press in fully and push forward. You will hear a satisfying snap when it is in correctly.
  18. May 23, 2022 at 10:59 AM
    #258
    Roman
    Roman
    Franklin, TN
    No shocks yet, but the part number they are showing for the switch is 84163-YY010. I don't think this will be the actual part number once Toyota releases it, though. It's more like a place holder, similar to how they do the VINs on vehicles in allocation.
    Crewmax? If so:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-rail-side-panel-top-653350c080
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-screw-hexalobular-90148a0006 x10
    What??? You mean a Toyota parts department is struggling with part numbers? :D
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-sub-assembly-rad-531010c500
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tun-alloy-wh-flt-black-pt94634221f2
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-wheel-cap-pt28089210f2
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-wheel-locks-alloy-black-pvd-pt0760c20002
    You'll need 5 sets of lug nuts, because as of right now, they are only showing available in a set of 5.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-door-trim-panel-upper-clip-90467a0016c3
    CarlsSenior303 likes this.
  19. May 25, 2022 at 9:48 AM
    #259
    wayoflife
    wayoflife Exploring Cascadia and beyond
    Seattle-ish, WA, USA
    '22 1794 6.5' TRD Offroad Blueprint/Cream
    Westcott 3/1 Method 705 18x9 18mm Maxxis RAZR 295/70R18
  20. May 25, 2022 at 12:02 PM
    #260
    Roman
    Roman
    Franklin, TN
    wayoflife[QUOTED] likes this.
  21. May 25, 2022 at 2:36 PM
    #261
    CarlsSenior303
    CarlsSenior303 New Member
    Carl
    2022 Tundra Limited TRD Offroad Army Green (hopefully)
    Hey @Roman ! Do you know the part number for the 18" TRD Pro wheels that come stock on the 2022 TRD Pro model?
  22. May 26, 2022 at 9:38 AM
    #262
    Monsterson
    Monsterson New Member
  23. May 26, 2022 at 5:46 PM
    #263
    MMTundra
    MMTundra New Member
    I have this posted in a different thread too but upon a closer look, those 1/4” trim pieces actually appear to have snapped off of the lower rear window moldings - this must have happened in shipping, or possibly when I took them out of the plastic wrap? In any case, I’m just going to try to glue them on or something… or, maybe go back to where I got the parts to see if they can get a replacement.
  24. May 27, 2022 at 11:55 AM
    #264
    Roman
    Roman
    Franklin, TN
    Still haven't found a part number for them yet. Toyota hasn't updated their accessory catalog with the info yet. It's a good looking wheel. We had a Lunar Rock Pro come in the other day. :D
    I still believe they should work. The stud is the same size, it's just making sure a socket will fit into the wheel.
  25. May 30, 2022 at 5:47 PM
    #265
    gnortiz22
    gnortiz22 New Member
    Hi @Roman,
    Do you have the part number for the rear right bumper in Midnight Black? The part that is the absolute right back corner of the truck. I have a Limited CrewMax with the PVM Package if that makes a difference.
    Thank you
  26. May 31, 2022 at 5:00 AM
    #266
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    @Roman I have a question that maybe you can explain a bit. I've looked at a few Toyota parts web sites (including yours) looking for some info on the alarm/VIP system as the catalytic converter thieves have been doing their thing in my area as of late. Most of the sites list the VIP system but then does not fit my 22 Tundra. I park in my garage, so the factory alarm seems to suit my needs here as I would need it when I'm parked and away from the vehicle in a store or wherever.. Is this something that the dealer just has to turn on, or is there a glass sensor and a hood sensor for all this, or are they already on the vehicle? I was wondering how much the part(s) are so when I ask the local dealer for an install I won't pass out over sticker shock.
    Right now it seems I only have the engine immobilizer.
    Thanks
  27. May 31, 2022 at 7:22 AM
    #267
    TheBandit181
    Todd
    I am looking into adding an aftermarket inverter using an OEM power outlet in the bed. Is there a part number(s) for the socket that plugs into the outlet?
    I already have 855300C081 which is the outlet, but still need a pigtail harness to plug into the back of it. Is there a repair wire/socket?
  28. May 31, 2022 at 8:59 AM
    #268
    CarlsSenior303
    Carl
  29. May 31, 2022 at 12:34 PM
    #269
    Roman
    Roman
    Franklin, TN
    I'd need the VIN to figure it out. I've got three different options with no descriptions. Also, it does not come painted as a replacement part.
    There isn't a listing for the '22 Tundra on the VIP system, but if you are worried about converter thieves, it isn't really going to help much. You would need an alarm with some kind of proximity/motion sensor.
    Looks like it is a part of this harness:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-wire-frame-no-3-821690c160
  30. Jun 3, 2022 at 7:48 PM
    #270
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    @Roman do you know if the black tailgate handle is the same black as the replacement door handles? Not the flat black, but the gloss black...
    Still seems like Lunar Rock handles aren't a thing, so if I replace my chrome tailgate handle i'd like the black door handles to match that if possible.
    Thanks!
