Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Jan 4, 2020 at 7:16 AM
    #2341
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    Hello @Roman!!
    I hope you had a good time during the holidays and wish you an awesome 2020!
    Can you please provide me the part number for this rubber piece where the tailgate door rests when closed?
    Thanks in advance!
    Have a good one!
  2. Jan 4, 2020 at 2:28 PM
    #2342
    Jeff Engelbrecht
    Jeff Engelbrecht New Member
    @Roman can you verify my parts lists for my 2014 Toyota Sequoia Platinum - Magnetic Gray
    1. (Qty 1 - pair) Mirror Caps (Magnetic Gray) - mirror-caps - https://parts.toyotaofcoolsprings.com/p-mirrorcaps-mirrorcaps
    2. (Qty 1 - ea) Handle Cover (Magnetic Gray) w/ keyhole - 69217-0C050-B2 - https://parts.toyotaofcoolsprings.com/oem-parts/toyota-handle-cover-w-keyhole-magnetic-gray-1g3-692170c050b2?c=Zz1ib2R5JnM9bG9jay1hbmQtaGFyZHdhcmUmbD0yJm49U2VhcmNoIFJlc3VsdHMmYT10b3lvdGEmbz1zZXF1b2lhJnk9MjAxNCZ0PXBsYXRpbnVtJmU9NS03bC12OC1nYXM=
    3. (Qty 4 - ea) Handle Cover (Magnetic Gray) w/o keyhole - 69217-0C060-B2 - https://parts.toyotaofcoolsprings.c...pYSZ5PTIwMTQmdD1wbGF0aW51bSZlPTUtN2wtdjgtZ2Fz
    The diagrams of the handle covers only depict the key hole piece vice the entire handle. I'm looking for a color matching set.
  3. Jan 4, 2020 at 3:39 PM
    #2343
    19greysport
    19greysport New Member
    2019 crewmax sport
    Napa has them. Aftermarket and seem better then factory. Just installed one on Friday for perfect.
  4. Jan 5, 2020 at 6:50 PM
    #2344
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    So I’ve been trying to find the OEM tailgate lock. I want plug and play. But reviews are saying they show up as pop and lock. Is there and OEM kit that’s completely plug and play?
  5. Jan 5, 2020 at 7:32 PM
    #2345
    ElNopal
    Willis TX
    19 Cavalry Blue CM
  6. Jan 5, 2020 at 7:51 PM
    #2346
    Predator Tundra
    Fallon, NV
    2020 Platinum
    I saw that one. That’s one of the ones I read somewhere that showed up as a pop and lock and you had to splice wires. Granted it wasn’t ordered from them but that was the part number I have written down. I may order it just to see and if it’s not plug and play just return it.
  7. Jan 6, 2020 at 8:40 AM
    #2347
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Go with the cheaper one. ;)
    Here you go:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-rear-cross-sill-cushion-9054111015
    Mirror caps are good. For an easier way to order the door handles, just use the part number in this link and select Yes, you do have a Crewmax. It will send you all four door handles with the corresponding lock covers:
    https://parts.toyotaofcoolsprings.com/p-door-handles-doorhandles
    BrandonL812 likes this.
  8. Jan 6, 2020 at 8:41 AM
    #2348
    Good morning, Roman. Is there an OEM locking fuel door or fuel cap option? I've seen aftermarket, but would like OEM if possible.
  9. Jan 6, 2020 at 8:45 AM
    #2349
    Roman
    Roman
    Franklin, TN
    No sir. Toyota doesn't make one, and I've heard the aftermarket caps are bad about leaking and tripping your CEL.
    GODZILLA[QUOTED] likes this.
  10. Jan 6, 2020 at 8:49 AM
    #2350
    Thank you. I guess I'll look at a fuel door. Only ones I've found have the stupid silver bolt in look. :(
    Roman[QUOTED][OP] likes this.
  11. Jan 6, 2020 at 10:29 AM
    #2351
    rollingTide29
    rollingTide29 New Member
    Chase
    Murfreesboro, TN
    2019 MGM TRD Sport Crewmax
    Roman,
    Looking for an exhaust bolt for a 2019 crewmax. For some reason I am missing one if the long bolts that holds the exhaust to the headers.
  12. Jan 6, 2020 at 11:30 AM
    #2352
    mahmer09
    mahmer09 SR5 4x4
    Hello @Roman
    Ordered a cement grill and bulge on 12/31 and the order is still showing up as new. Are there any issues supplying those grills or do orders just take some time? Sorry for being impatient, the chrome blinds me every time I look at my truck. Thanks!
  13. Jan 6, 2020 at 12:16 PM
    #2353
    Roman
    Roman
    Franklin, TN
    Sure thing. You talking about one of the studs between the header and mid pipe? If so, here's a link to it and the nut, just in case:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-exhaust-manifold-stud-90126a0011
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-exhaust-pipe-nut-9008017187
    I know how that goes. Grab some shades. :cool:
    Seriously, though the holiday did slow us down a bit. Toyota was closed for New Years Eve and New Years day. We weren't able to put an order in until the 2nd, which arrived on the third and over the weekend. My guys are back there playing catch up now. I want them to get a move on it, but at the same time, it takes a while to unbox, inspect, repackage, and add packaging to every single order, and I don't want them to rush through that because that's how stuff gets broken.
    SIMPLYTHETRUTH and AZBoatHauler like this.
  14. Jan 6, 2020 at 1:03 PM
    #2354
    mahmer09
    mahmer09 SR5 4x4
    OK, totally! Just wanted to make sure everything was good. I can wait, no problem. Thanks for getting back to me!
    Roman[QUOTED][OP] and GODZILLA like this.
  15. Jan 8, 2020 at 7:10 AM
    #2355
    Roman
    Roman
    Franklin, TN
    Sure, shoot me your VIN if you don't mind. I just want to make sure I get you the correct ones. Tons of options on mirrors.
  16. Jan 8, 2020 at 6:25 PM
    #2356
    SoCalRandy
    SoCalRandy New Member
    Randy
    San Diego, California
    2020 MGM Limited Crewmax 4x4
    Does anyone have a link for the center console wireless charger? The search function on the Cool Springs site returns several hundred results, none of which are what I’m looking for.
  17. Jan 9, 2020 at 1:02 PM
    #2357
    Roman
    Roman
    Franklin, TN
    It's an aftermarket part only available to dealerships in the GST and SET regions. Since we are in neither of those regions, we can not order it.
  18. Jan 9, 2020 at 1:11 PM
    #2358
    gr8fasushi
    gr8fasushi 22 Tundra Limited TRD Off Road
    @Roman do you have the Tss emblem and sensor for a 2019 tundra? Wondering the cost.
  19. Jan 9, 2020 at 1:51 PM
    #2359
    Roman
    Roman
    Franklin, TN
    gr8fasushi[QUOTED] likes this.
  20. Jan 9, 2020 at 7:31 PM
    #2360
    SoCalRandy
    Randy
    Well, that’s a bummer, thanks for getting back to me.
  21. Jan 10, 2020 at 1:33 PM
    #2361
    sigh824
    sigh824 New Member
    Thanks Roman! Just ordered the black shift knob! Hopefully fast delivery! :fingerscrossed::yes::bananadance:
    Roman[OP] likes this.
  22. Jan 11, 2020 at 9:56 AM
    #2362
    bocabasser
    bocabasser New Member
    2019 cm limited
    6 inch ready lift w/coilovers 20x10 fuel couplers with 35 ridge grapps
  23. Jan 11, 2020 at 9:58 AM
    #2363
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    @Roman do you have the mirror caps in the inferno color? Wasn’t listed on the site
  24. Jan 11, 2020 at 10:00 AM
    #2364
    sigh824
    sigh824 New Member
  25. Jan 11, 2020 at 10:07 AM
    #2365
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yep I can read, just making sure before I buy a set off ebay
    sask3m likes this.
  26. Jan 12, 2020 at 11:48 AM
    #2366
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    Is there an updated forum code? Tried using the one posted but doesnt work Thanks
  27. Jan 12, 2020 at 11:54 AM
    #2367
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    FORUM20 .. I entered it yesterday and did as it was supposed to .. takes 20% off ‘shipping’ cost .. not ‘parts’ cost
    GODZILLA likes this.
  28. Jan 12, 2020 at 1:26 PM
    #2368
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    Thanks. I got it. Minor misspelling. Lol.
    Doylfish likes this.
  29. Jan 13, 2020 at 4:34 AM
    #2369
    coTony
    Tony
    Montrose, CO
    What is the part name in the door sill that has to be removed anytime you need to access the kick panel?
  30. Jan 13, 2020 at 7:52 AM
    #2370
    Roman
    Roman
    Franklin, TN
