Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. May 9, 2019 at 6:45 PM
    #1801
    gdog_Tundra
    gdog_Tundra New Member
    VA
    2016 Limited CrewMax
    3 inch ToyTec coilovers, Dakar Leaf pack, Dirty Deeds 8 inch stainless exhaust, LED DRL headlights
  2. May 10, 2019 at 1:22 AM
    #1802
    KauaiTundra
    KauaiTundra New Member
    Brad
    I just got my first tundra. Not feeling the chrome. Do you sell the parts in cavalry blue. I’m goin for the look on the bottom picture. Please let me know
    Thank you @Roman
    Jus a FYI. The picture shown are ones I found online. 802C3BDA-F223-440C-B5B5-927D5C211668.jpg
    SheDevil likes this.
  3. May 10, 2019 at 12:34 PM
    #1803
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    They are different.
  4. May 10, 2019 at 12:37 PM
    #1804
    Roman
    Roman
    Franklin, TN
    We sure do. Hood bulge and grille are listed in the OP.
  5. May 10, 2019 at 12:45 PM
    #1805
    KauaiTundra
    Brad
    I found the grille. Is the hood bulge included in that or is that separate? And as far as front bumper caps, I think I read you don’t sell them painted and that I’d have to get a local paint shop to paint? Apologize for the questions as i am fairly new to this thread.
    Edit: I found the hood bulge
  6. May 10, 2019 at 8:17 PM
    #1806
    KauaiTundra
    Brad
    Order #46738
    I order the grill and hood bulge in cavalry blue. And I found some front bumper end caps elsewhere in cavalry blue so I order the seals and clips mentioned in the OP. Can you check if everything in my order was correct
    Thanks again @Roman
  7. May 11, 2019 at 10:51 AM
    #1807
    skatebass1958
    skatebass1958 New Member
    Felix Javier
    2017 Tundra SR5 Xp
    Removed mudflaps
    Will a 2017 sr5 chrome grille fit and work on a 2018 truck with the tss sensor? I understand that the sensor is in the emblem, will the 2018 emblem fit the 2017 chrome grille?
    Thanks
  8. May 11, 2019 at 7:51 PM
    #1808
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Are you certain the rear leaf springs are different? When I search the parts catalog, the rear leaf springs have the same part number for the TRD Pro and the CM Platinum.
  9. May 12, 2019 at 9:23 AM
    #1809
    Yzed608
    Yzed608 New Member
    Wisconsin
  10. May 12, 2019 at 9:51 AM
    #1810
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    @Roman Can you check on 75708-33070 and 75707-33070. Are they really $445 per trim piece?
  11. May 13, 2019 at 7:53 AM
    #1811
    Ibanez6224
    Ibanez6224 New Member
    2019 TRD OR
    Hey @Roman so I got the mirror caps in, but they are the wrong color. See below. I'm assuming I can return these and get the cavalry blue color right? I ordered the two SKU's that I confirmed, but maybe they picked the wrong ones. The packing slip confirms the SKU's that the part numbers that I listed out in an earlier post in this thread.
  12. May 13, 2019 at 11:28 AM
    #1812
    Roman
    Roman
    Franklin, TN
    You sure that is the correct order #? I'm showing 46738 was a set of mudguards for a Tacoma.
  13. May 13, 2019 at 11:30 AM
    #1813
    Ibanez6224
    2019 TRD OR
    Sorry, that auto populated on the form for some reason. It was order number 46521
  14. May 13, 2019 at 11:30 AM
    #1814
    Roman
    Roman
    Franklin, TN
    No, the sensor will not fit into the older model grille. You'd have to come up with a way to mount it.
  15. May 13, 2019 at 11:36 AM
    #1815
    Roman
    Roman
    Franklin, TN
    I can get you the Toyota parts for it, but you'd probably want some nice stainless bolts from a bolt shop. The bad thing is the catalog does not give me their actual sizes.
    Yep, that is correct. It has to do with the XSE being a two tone or something like that. That's the only difference in the description for those parts.
    Those were definitely the right part numbers. I've ran into Toyota boxing these up incorrectly in the past. Part number should end in J1 for paint code 8W2. Shoot me your order number, and I'll get another set ordered in for you.
  16. May 13, 2019 at 11:37 AM
    #1816
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    I didn’t read through all 63 pages but you may want to add the part # for the 2019 TRD Pro shock package and rear ABS sensor bracket. I get a lot of messages asking for them.
    Shocks
    Ptr61-34190
    Bracket
    Ptr61-34190SB
  17. May 13, 2019 at 11:38 AM
    #1817
    Ibanez6224
    2019 TRD OR
    @Roman it's order number 46521. Thanks so much for the help, really appreciate it!
  18. May 13, 2019 at 11:47 AM
    #1818
    Roman
    Roman
    Franklin, TN
    I don't have the TRD Pro suspension listed because Toyota has not yet released the kit for sale. They are currently only supplying replacement parts for Pros.
    ryanwgregg likes this.
  19. May 13, 2019 at 11:48 AM
    #1819
    Roman
    Roman
    Franklin, TN
    No problem at all. I'll shoot you a return label, and get some more coming your way ASAP.
  20. May 13, 2019 at 11:59 AM
    #1820
    Ibanez6224
    2019 TRD OR
    Thanks, I'll drop it in the mail today.
  21. May 13, 2019 at 12:35 PM
    #1821
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    I just installed the kit 2 weeks ago on my 2013 Crewmax SR5. I’ve also met a guy at Home Depot that recently installed them on his 15 SR5.
    Wynnded, georgiey22 and Toyotoholic like this.
  22. May 13, 2019 at 12:55 PM
    #1822
    Roman
    Roman
    Franklin, TN
    If those were purchased new from a dealership for a non TRD Pro Tundra, then the dealership did so against Toyota's manual allocation rules, and that's a good way to get in big trouble. This MAC report is from this week:
    All of those parts are service replacements only. I highlighted the Tundra Pro suspension parts.
  23. May 13, 2019 at 12:59 PM
    #1823
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    I was unaware of that policy and they didn’t say anything about it. I just gave them a part number and they ordered it. I hope they don’t get in trouble!
  24. May 13, 2019 at 1:04 PM
    #1824
    Roman
    Roman
    Franklin, TN
    There are ways around it. They can supply Toyota with a VIN from a Pro and order the parts one at a time to not raise suspicion, but I'm not about to do that. I love you guys, but I also like my job. :D
  25. May 13, 2019 at 1:07 PM
    #1825
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    No worries I don’t blame you! I was just trying to help! Thanks for the info!
    ryanwgregg and Roman[QUOTED][OP] like this.
  26. May 13, 2019 at 1:52 PM
    #1826
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
  27. May 13, 2019 at 1:55 PM
    #1827
    KauaiTundra
    Brad
    Sorry wrong order number. It’s 46783. Thank you. Just got an email saying a part was on backorder.
    Roman[QUOTED][OP] likes this.
  28. May 14, 2019 at 1:03 PM
    #1828
    KauaiTundra
    Brad
    DE5046B5-A4F0-4C91-8A03-CA6FADF159F1.jpgDo you sell these clips @Roman
    It’s in the front driver side fender well
  29. May 14, 2019 at 1:20 PM
    #1829
    Roman
    Roman
    Franklin, TN
    KauaiTundra[QUOTED] likes this.
  30. May 14, 2019 at 1:22 PM
    #1830
    KauaiTundra
    Brad
