Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Mar 23, 2019 at 6:25 PM
    #1651
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Check the first post in this thread :)
    Roman[OP] likes this.
  2. Mar 23, 2019 at 7:13 PM
    #1652
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    FORUM20 gets 20% off shipping.
    Roman[OP] and xando[QUOTED] like this.
  3. Mar 23, 2019 at 8:55 PM
    #1653
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Any chance you have replacement black rings for around the climate control knobs and the vents? 2019 SR5 TRD Sport
  4. Mar 25, 2019 at 9:21 AM
    #1654
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
  5. Mar 25, 2019 at 9:22 AM
    #1655
    Roman
    Roman
    Franklin, TN
    That is correct. Pay no mind to the diagram images.
  6. Mar 25, 2019 at 10:33 AM
    #1656
    csuviper
    Broomfield, CO
    Assuming i have to buy the whole vent assembly for more money than i want to.
  7. Mar 25, 2019 at 1:38 PM
    #1657
    dragon_coma
    dragon_coma New Member
    Sky
    2008 CrewMax 4x2 5.7L
    @Roman is this the right part to the master window control assembly in the diver-side door?
    84820-0C020
    For a 2008 Tundra CM.
    IDEALLY, I’d like to get only the plastic housing for this switch assembly since all the switches work fine but the unit is falling down into the door due to a busted plastic screw hole on the housing.
    @Yzed608 @xando do you know what this rubber piece actually does? I’ve been without my passenger side since a car wash took it, and the AZ heat is slowly liquified the driver side. I can’t actually see its purpose...
  8. Mar 25, 2019 at 1:58 PM
    #1658
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    @Roman can you confirm if this is the correct part number for the Inferno door edge guards for a crewmax?
    PT936-34171-04
    and is this also for all 4 doors?
  9. Mar 25, 2019 at 3:51 PM
    #1659
    Yzed608
    Yzed608 New Member
    Wisconsin
    To me it just looks like it stops water from being able to rest against the top of the windshield seal.
  10. Mar 26, 2019 at 10:00 AM
    #1660
    Roman
    Roman
    Franklin, TN
  11. Mar 26, 2019 at 10:02 AM
    #1661
    Roman
    Roman
    Franklin, TN
    That is the correct part number. Unfortunately, the only way to get the housing is to order the whole switch.
  12. Mar 26, 2019 at 10:03 AM
    #1662
    Roman
    Roman
    Franklin, TN
    Yep, that is the right part number. It does include all four doors.
    silverhack[QUOTED] likes this.
  13. Mar 26, 2019 at 10:46 AM
    #1663
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    @Roman,
    I noticed the info about not able to use a 2019 TRD pro grille on a 2018+ Tundra is gone from the original post. Has something changed where the pro grille is compatible with a 2018+ Tundra?
  14. Mar 26, 2019 at 10:53 AM
    #1664
    silverhack
    Sacramento, CA
    Forgot to use the promo code, so enjoy the extra $1.80 ! Maybe you can retire early
  15. Mar 26, 2019 at 11:49 AM
    #1665
    Roman
    Roman
    Franklin, TN
    The 2019 Pro grille has always been compatible. Using the older model Pro grille on the new models with TSS is where the difficulty lies. There's nowhere to mount the sensor on the older model grilles.
  16. Mar 26, 2019 at 11:51 AM
    #1666
    Roman
    Roman
    Franklin, TN
    Next time I buy a beer, I'm going to think "silverhack bought me a third of this beer. Here's to silverhack.", and raise you a toast.
    :D
    wipfel, sundance, dragon_coma and 2 others like this.
  17. Mar 26, 2019 at 12:25 PM
    #1667
    ITOWJKS
    ITOWJKS New Member
    2018 Tundra Limited Cavalry Blue
    @Roman, cavalry blue grille still on back order?
  18. Mar 26, 2019 at 12:41 PM
    #1668
    Roman
    Roman
    Franklin, TN
    As of right now, there is showing to be one at my distribution center and two others available elsewhere in the country. So, it is not technically on back order now but once one is ordered it will be after that.
    ITOWJKS[QUOTED] likes this.
  19. Mar 26, 2019 at 1:48 PM
    #1669
    ITOWJKS
    ITOWJKS New Member
    @Roman, just placed the order along with a few other “goodies”... quick, call your distribution center!!!
    Please double check the grille and hood bulge ordered part numbers are correct for Cavalry Blue!
    BTW, order number 42624 - Angel Berrios
    Thanks!
    Roman[QUOTED][OP] likes this.
  20. Mar 27, 2019 at 12:00 AM
    #1670
    epicxcrider
    epicxcrider New Member
    Eastside Seattle
    Looks like I missed this one, any way to get a ping as they become available?
  21. Mar 27, 2019 at 8:00 AM
    #1671
    Roman
    Roman
    Franklin, TN
    Honestly, I would go ahead and place an order. That ensures you will get one of the first ones once they become available, even before they start becoming readily available.
  22. Mar 27, 2019 at 10:35 AM
    #1672
    clarkrw3
    clarkrw3 New Member
    Rob
    Tempe, AZ
    2016 Inferno Limited
    No more Inferno door handles or mirrors correct?
  23. Mar 27, 2019 at 12:56 PM
    #1673
    Roman
    Roman
    Franklin, TN
    No more door handles, unless you have them painted locally. The mirror caps are still available.
  24. Mar 27, 2019 at 12:59 PM
    #1674
    clarkrw3
    clarkrw3 New Member
    Rob
    Tempe, AZ
    They aren't showing on the website do I need to call you directly for the mirror caps?
  25. Mar 27, 2019 at 1:03 PM
    #1675
    Roman
    Roman
    Franklin, TN
  26. Mar 27, 2019 at 1:10 PM
    #1676
    damonhimself
    damonhimself New Member
    Damon
    2018 Tundra TRD Off Road
    Thanks for all that info; I am little lost in that much info. If I wanted to get rid of the chrome parts of my 2018 TRD Off Road grill and swap them out to magnetic gray, what all do I need to order?
    Do I just need this? 53101-06340-B1 or 53101-0C040-B1 or am I missing something?
  27. Mar 27, 2019 at 1:14 PM
    #1677
    clarkrw3
    clarkrw3 New Member
    Rob
    Tempe, AZ
  28. Mar 27, 2019 at 1:19 PM
    #1678
    Roman
    Roman
    Franklin, TN
    You would have to choose which MGM grille you want to go with, grab the hood bulge in MGM, and that's it.
  29. Mar 27, 2019 at 7:50 PM
    #1679
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Looking for replacement felt inserts (gray) for passenger front and passenger rear inside door handles (2010 crew max)...thanks
  30. Mar 28, 2019 at 7:16 AM
    #1680
    Roman
    Roman
    Franklin, TN
    Jrharvey02[QUOTED] likes this.
