Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. May 9, 2022 at 5:37 PM
    #3721
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
  2. May 10, 2022 at 9:55 AM
    #3722
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Yes.
    BrandonL812[QUOTED] likes this.
  3. May 12, 2022 at 7:07 AM
    #3723
    Whittle
    Whittle New Member
    2021 Magnetic Gray Tundra TRD Pro
    Roman[QUOTED][OP] likes this.
  4. May 13, 2022 at 4:10 PM
    #3724
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    @Roman... Ughhh! It looks like I'll now be needing rear brakes as well.... So this is for my '08 Tundra SR5 4WD crewmax. I just need OE pads, shims/hardware for basic brake service (no rotors or calipers). Thank you!
  5. May 14, 2022 at 3:13 PM
    #3725
    Yzed608
    Yzed608 New Member
    Wisconsin
  6. May 17, 2022 at 7:02 AM
    #3726
    Toney198
    Toney198 New Member
    2014 1794 4X4
  7. May 17, 2022 at 12:34 PM
    #3727
    Roman
    Roman
    Franklin, TN
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-brake-pads-rear-044660c010
    https://parts.toyotaofcoolsprings.c...it-anti-squeal-for-rear-disc-brake-049460c010
    https://parts.toyotaofcoolsprings.c...sc-brake-anti-rattle-clip-set-rear-049480c020
    That is definitely the one.
    Responded to your PM.
  8. May 17, 2022 at 4:09 PM
    #3728
    Yzed608
    Yzed608 New Member
    Wisconsin
    Ok, thanks for the info. I guess it is a much better deal to get the full kit.
    Roman[OP] likes this.
  9. May 17, 2022 at 5:37 PM
    #3729
    Tripleconpanna
  10. May 18, 2022 at 12:32 PM
    #3730
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    Thanks @Roman for the upgrade. The OEM black exhaust tip looks good.
  11. May 18, 2022 at 12:46 PM
    #3731
    Roman
    Roman
    Franklin, TN
    Yep, those are definitely it.
  12. May 18, 2022 at 2:14 PM
    #3732
    Tripleconpanna
    Ok, thanks Roman... Just wanted to make sure before I order.
  13. May 19, 2022 at 6:09 AM
    #3733
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    @Roman
    Need a link for lower control arms, left and right for 99 tacoma 4wd.
  14. May 19, 2022 at 9:29 AM
    #3734
    Roman
    Roman
    Franklin, TN
  15. May 19, 2022 at 9:36 AM
    #3735
    ffdawson
    ffdawson #DBB
    NorCal
    Sandra, Sandy for short
    Rad ass parts, big tires.
    Just placed an order for some chrome delete items! Thanks @Roman for such an awesome detailed thread!
  16. May 19, 2022 at 9:54 AM
    #3736
    easleycrawler
    Travis
  17. May 19, 2022 at 10:13 AM
    #3737
    Roman
    Roman
    Franklin, TN
    Yep, sure do.
    easleycrawler[QUOTED] likes this.
  18. May 19, 2022 at 10:33 AM
    #3738
    easleycrawler
    Travis
    Thanks.
  19. May 19, 2022 at 12:57 PM
    #3739
    happyb
    happyb New Member
    hey roman do you have the part number for a 2018-up nightshade grille with a super white surround.
  20. May 19, 2022 at 1:05 PM
    #3740
    Roman
    Roman
    Franklin, TN
    Voda48, marc32 and RainMan_PNW like this.
  21. May 19, 2022 at 3:47 PM
    #3741
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Just a quick clarification to anyone else looking for an OEM exhaust clamp: that part number (90080-46263) is not correct for the OEM exhaust clamp. The parts diagram shows it as correct, but the "this fits" section specifies it fits only earlier Tundras with the V6. I ordered one based on this, but it is most definitely too small comparing it with the stock clamp that came off my 5.7 Tundra. Just a heads up.
  22. May 21, 2022 at 8:28 AM
    #3742
    gringer
    gringer New Member
    2011 Tundra Base 4x4
    I need to change the brakes on my 2011 Base (4.6L, dbl cab, 4x4).
    It'll be my first brake job (first set went over 100k miles).
    I've gathered from prior posts these are the parts I need:
    Front:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-disc-brake-rotor-front-435120c020
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-brake-pads-front-044650c020
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-shim-kit-anti-squeal-front-049450c040
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-disc-brake-anti-rattle-clip-set-049470c030
    Rear:
    Some (probably dumb) questions:
    1) Do the pads, shim, and clip sets cover both wheels, or only one?
    2) What are the chances the rear rotors are still good? Should I go ahead and replace them too?
    3) Any other parts I'm missing or should pre-emptively replace while I've got the wheels off?
    Thanks!
  23. May 21, 2022 at 8:54 AM
    #3743
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I’m no expert, but at 100k and no prior change, I would do the rear rotors while you have everything opened up.
    At a minimum you’ll want to turn/true/surface the rotors, but it’s easier to swap them while you’re in there and then take the old ones to be done after you’re all wrapped up.
  24. May 22, 2022 at 7:09 AM
    #3744
    gringer
    gringer New Member
  25. May 23, 2022 at 12:01 PM
    #3745
    Roman
    Roman
    Franklin, TN
    1. A quantity of 1 covers both wheels.
    2. Pretty good, actually. Only way to know is to measure and see if there is enough material left on them. IF you're getting a vibration from the rear when braking, then have them turned. If not, just leave them be.
    3. Nope, looks like you've got it covered.
    bulldog93 likes this.
  26. May 23, 2022 at 4:43 PM
    #3746
    fulanoderock
    fulanoderock New Member
    Ventura County
    2018 Toyota Tundra TRD Sport
    Hello. I have a 2018 TRD sport that came with the 20'' limited wheels. I just bought these BBS wheels on craigslist:
    Do I need new lug nuts or can I transfer the ones from the 20'' stock limited wheels?
    bulldog93 and dherring256 like this.
  27. May 23, 2022 at 4:44 PM
    #3747
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    Interesting…. I’m in the same boat - just bought the exact same wheels and didn’t think about lug nuts at all. I’m kinda paranoid now lol
  28. May 23, 2022 at 4:48 PM
    #3748
    fulanoderock
    Ventura County
    haha yea, this popped into my head last night after picking them up and I began investigating this morning. I couldn't find an exact answer throughout all the search results on here, so I figured I ask before I head to the tire shop.
    dherring256[QUOTED] likes this.
  29. May 23, 2022 at 5:04 PM
    #3749
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    Stock wheel nuts for any of the aluminum alloys will work. Wheel nuts for steel wheels won't.
  30. May 23, 2022 at 5:08 PM
    #3750
    fulanoderock
    Ventura County
    Thanks buddy!
    dherring256 likes this.
