Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Mar 24, 2022 at 5:40 PM
    #3661
    Toyotaonlydriveway
    Toyotaonlydriveway New Member
    Stephany
    2015 Red Tundra Limited
    @Roman Welcome back! I was panicked during COVID when I couldn’t find you. I about pulled my hair out trying to find legitimate Tow mirrors!
    Are y’all still offering the promo code?
  2. Apr 5, 2022 at 7:15 AM
    #3662
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    @Roman
    Welcome back.
    I have 20" Platinum wheels from a 2017 and I'd like to get the black center caps. Is there an OEM black cap available like the one in this picture?
    Thanks
  3. Apr 5, 2022 at 12:18 PM
    #3663
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Toyotoholic[QUOTED] likes this.
  4. Apr 5, 2022 at 12:41 PM
    #3664
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Roman[QUOTED][OP] likes this.
  5. Apr 19, 2022 at 8:34 PM
    #3665
    Fish River Tundra
    Fish River Tundra New Member
    JD
    Nashville
    ‘16 Platinum
    @Roman hi, I’m looking for a 20/21 carplay usb input that fits under the ac controls. Thanks and glad to see you are back on your old stomping grounds
  6. Apr 20, 2022 at 8:50 AM
    #3666
    Roman
    Roman
    Franklin, TN
  7. Apr 20, 2022 at 11:51 AM
    #3667
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    Thank you!
    Roman[OP] likes this.
  8. Apr 22, 2022 at 9:53 AM
    #3668
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    @Roman
    2019 Tundra 4WD 5.7L Flex
    Looking to order the OEM front and rear pads, does the shiim kit for front and rear come with already? or a separate order?
    Any difference between TRD vs OEM?
    TIA!
  9. Apr 22, 2022 at 10:58 AM
    #3669
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    @Roman.. Hey, I'm looking for what I think is called the roof drip molding that runs the length of the cab. I need the driver's side only, and it appears there is a 4/5" piece in the back that is still place. So, I'm assuming I'll need the main full length molding plus the short "cap" or end piece at the front. Vehicle is a 2008 SR5 Crewmax w/sunroof. Let me know if you need pics or anything else.
    Thank you!
  10. Apr 22, 2022 at 12:32 PM
    #3670
    Roman
    Roman
    Franklin, TN
    OEM
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-brake-pads-front-0446502440
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-brake-pads-rear-0446602340
    TRD
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-performance-brake-pads-front-ptr090c111
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-performance-brake-pads-rear-ptr090c110
    The shim kit does not come with the OEM pads, but does come with the TRD pads. The TRD pads tend to brake better and don't fade as quickly as the OEM pads when you're using the brakes quite a bit. Think towing or going downhill a lot. The TRD pads typically don't last as long as the OEM pads, though. It's sort of the same deal with tires. Better performance tires usually don't last as long, and tires that last a good while don't have the best performance.
    Here you go:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-drip-molding-crewmax-755520c060
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-drip-molding-clip-7556102020
    I included the clip in case you need one of those too.
  11. Apr 23, 2022 at 1:41 PM
    #3671
    Pilsbury
    Pilsbury New Member
  12. Apr 23, 2022 at 6:39 PM
    #3672
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Hi @Roman
    I just picked up a 2018 Rav4 Adventure for my daughter. It has some minor rear bumper damage. Can the cracked black protective top cover be replaced on its own? If so could you please provide a link to the part? Does it come with attached clips or are the clips separate?
    Thanks in advance.
  13. Apr 23, 2022 at 8:23 PM
    #3673
    murphysf
    murphysf New Member
    Hello Roman
    The topic is TPMS sensors
    Is it true that
    42607-0C091 is for vehicles with a traditional conventional key
    and
    42607-06030 is for vehicles with a smart key (push button start / keyless entry)
    A separate but related question does the factory steel wheel take a different type of sensor compared to a factory alloy wheel? This question and its answer can be misleading as the 2021 RAV4 LE comes with steel wheels and a conventional key and the 2021 RAV4 XLE comes with alloy wheels and a smart key. So the sensor might be different in the steel vs alloy wheel not due to the wheel but because the alloy wheel came off a vehicle with a smart key which dictates the type of sensor.
    Is this correct?
    Thanks...
  14. Apr 24, 2022 at 12:45 PM
    #3674
    jdeprato
    jdeprato New Member
    2010 Blue Tundra
    4" lift, method rims, 305 70 18 tires, magnaflow exhaust
    I'm picking up a 2017 Tundra Blazing Blue Metallic 1794 and I want to de-chrome the front. From what I can tell I'll have to get the front bumper end caps unpainted and will have to paint them but will I be able to buy the front grille and hood bulge already painted BBM? Can I get this color with the TRD pro grille or is it only the Platinum grille? Or is the later 2020 SR5 also compatible?
  15. Apr 25, 2022 at 9:41 AM
    #3675
    Roman
    Roman
    Franklin, TN
    Looks like that may be the accessory rear bumper protector. It is only held on with adhesive.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-bumper-protector-rear-pu06042016p1
    Yes, the 0C091 is for conventional keys and the 06030 is for smart keys. The difference in steel and alloy wheels is the angle of the sensor stem. This is an older image, but it will show the difference.
    Steel wheels take the 40 degree sensor, and alloy wheels will take the 20 degree. In the case of the Rav4, Toyota lists three different part numbers for TPMS. For a 2020 Tundra, they list four different numbers. Two 20 degree, two 40 degree, and with or without smart key.
    Yes, you will need to paint the front bumpers. The hood bulge is available in Blazing Blue from Toyota. The only grille available with that color surround pre-painted is the Platinum grille. If you want the Pro grille, you will need to have the surround painted.
  16. Apr 25, 2022 at 1:30 PM
    #3676
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    Had a portly friend ride in the truck and he couldn’t support his weight upon dismount and broke my clips. Need a little help @Roman
    SkipperPete likes this.
  17. Apr 25, 2022 at 1:32 PM
    #3677
    Roman
    Roman
    Franklin, TN
    Here you go:
    https://www.jennycraig.com/
  18. Apr 25, 2022 at 1:33 PM
    #3678
    Roman
    Roman
    Franklin, TN
  19. Apr 25, 2022 at 1:33 PM
    #3679
    Fish River Tundra
    JD
    Nashville
    ‘16 Platinum
    :D He could eat poor Jenny as an appetizer haha
    tundra_20, Leo's first and bulldog93 like this.
  20. Apr 25, 2022 at 2:14 PM
    #3680
    Tripleconpanna
    tundra_20 likes this.
  21. Apr 25, 2022 at 3:56 PM
    #3681
    Ashley_1794JC
    Ashley_1794JC New Member
    2019 Black 1794
    Working on a lot RN
    Hi Roman, I just ordered some color matched handles today. I had a local guy who was going to color match the chrome on my 2019 1794 but he seems over priced. I was wanting the color matched pro grill with surround and bulge with paint code 218. I have the sensor also. That part has been very confusing on what to order. Also, is it possible to order the bumper end caps and mirror covers in color match or no?
  22. Apr 25, 2022 at 5:25 PM
    #3682
    3rdTundra
    Central Texas
    Just trying to be helpful in case you did not see it. Did you see the first post in this thread? I think all your answers are there.
  23. Apr 25, 2022 at 6:47 PM
    #3683
    Ashley_1794JC
    2019 Black 1794
    Working on a lot RN
    I think I have everything… pro grill, grill surround, tss sensor, front bumper caps (no chrome on rear bumper), mirror covers. Am I missing anything?
  24. Apr 26, 2022 at 9:47 AM
    #3684
    Roman
    Roman
    Franklin, TN
    If you have fog lights, you will need two clips, part number 75392-0R010.
    Those are the matte black mirror caps in your cart also. You had asked for painted mirror caps, which are available here:
    https://parts.toyotaofcoolsprings.com/p-mirror-caps-mirrorcaps
    Other than that, you're good to go.
  25. Apr 26, 2022 at 12:17 PM
    #3685
    Ashley_1794JC
    2019 Black 1794
    Working on a lot RN
    Thanks Roman!
  26. Apr 26, 2022 at 1:16 PM
    #3686
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Hey @Roman got my truck back from the repair shop and this "shield" is ripped and rubbing the paint on the door when I open it. Do you know what it is? It's behind the front fender and before the front driver door. Looks like they didn't clip it back into place and my door tore it apart from opening and closing.
  27. Apr 27, 2022 at 5:56 AM
    #3687
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Hey @Roman
    Can you give me a link for left and right outer tie rods for a 1999 tacoma 4x4?
  28. Apr 27, 2022 at 8:59 AM
    #3688
    bradywalling80
    bradywalling80 New Member
    Brady
    2012 TRD Tundra Limited
    Just a couple questions for ya @Roman! I have recently bought a 2012 Tundra limited and I was wondering if you know where I can find a passenger side stone guard for the front of the truck bed; a grill shell without an insert (I think this one doesn't actually exist but thought I would ask the guru); and replacement motors/gears for my power-folding tow mirrors.
    Thank you so much man, really appreciate all of the help you give to tundra owners everywhere!
  29. Apr 27, 2022 at 9:50 AM
    #3689
    Roman
    Roman
    Franklin, TN
    Here is the part and the clips that hold it in:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-rear-seal-538280c010
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-door-trim-panel-upper-clip-90467a0016c0 x3
    Here you go:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-steering-tie-rod-end-right-4504639295
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-steering-tie-rod-end-left-4504739175
    Crewmax, right? If so, here's the stone guard:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-stone-guard-662430c010
    The grille shell alone and the gears for the mirrors do not exist by themselves. You would need a complete grille assembly and complete mirror assemblies.
  30. Apr 27, 2022 at 12:09 PM
    #3690
    easleycrawler
    Travis
