Typical transmission temps?
Discussion in '2.5 Gen Tundras (2014-2021)' started by trails-end, Aug 2, 2021.
  1. May 25, 2023 at 6:53 AM
    #211
    WiscoWalleye
    WiscoWalleye New Member
    I bought a used 2020 tundra with 47,000 miles. The previous owner towed with it, I owned it for 2 weeks and the transmission went out. Toyota replaced it under the powertrain warranty. These things do fail if they aren’t taken care of properly. I’ll definitely be changing the fluid every 40-60 thousand miles or whatever the book says. I guess it’s more of a refresh than a change since you are only getting about 4qts in and out.
    Terndrerrr likes this.
  2. May 25, 2023 at 7:59 PM
    #212
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    Toyota service manual doesn’t talk about changing the fluid.
  3. May 25, 2023 at 9:28 PM
    #213
    WiscoWalleye
    Actually it does if you read it…..
    Henry1jg and Cpl_Punishment like this.
  4. May 25, 2023 at 9:32 PM
    #214
    NoMoreGreen
    Robert
    2020 Tundra
    fair. I forgot about the special operating conditions. It’s not in the normal vehicles operations portion.
    the dealer tries to tell me every visit I need every special operations service. My tundra has towed two trailers in its 52k life so I guess that makes it special operating conditions.
    toyota intended for the majority of these transmissions to go their entire lives without having fluid changed. Ford does the same thing. I had a 2014 f150 before this tundra and the manual never called for a fluid change under normal conditions.
  5. Aug 25, 2023 at 8:13 PM
    #215
    Desert4673
    Desert4673 New Member
    Just another datapoint : I have the 2020 with engine / transmission / cat skidplate I live in Vegas and I got up to 240 towing (3500lbs tall trailer) in 110F and 224F in S4 ( about 65 mph). two weeks later on same stretch of freeway I was around 220F without the trailer in 102F weather (about 70-75mph).
    once weather cools down a bit I will drain the transmission fluid at about 57,000miles.
  6. Aug 25, 2023 at 8:26 PM
    #216
    WiscoWalleye
    I bit the bullet and installed a transmission cooler. Much better on the temps now. Attached is a photo after the cooler. The same trip on the way to install it I was getting 210 degrees with converter spiking as high as 230 it was 85 degrees outside. After the cooler install the converter has yet to spike above 210 and usually stays well below 200 degrees.
    Terndrerrr, bflooks and Desert4673 like this.
  7. Aug 25, 2023 at 10:18 PM
    #217
    Chip_Tundra
    Chip_Tundra New Member
    Pinned thermostat and cooler installed. Here are the transmission temps in 100+ degree weather in the southwest.
    Top pic was after stop and go traffic, 2nd is cruising on the freeway.
    Without the transmission cooler, I've seen temps as high as 240 deg.
  8. Mar 14, 2024 at 6:07 PM
    #218
    Captain papa
    Captain papa New Member
    Well it has been over 5 years since the 2019 Tundras came out without the air to fluid transmission cooler. A lot of debate at the time of whether the higher operating transmission temps would cause any transmission failures. There should by now be some fairly high mileage Tundras without the coolers out there. Any reports with failures? Any high mileage ones out there that have survived without the cooler someone wants to brag about?
  9. Mar 14, 2024 at 6:41 PM
    #219
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    You’ve also got the Sequoias that went this same direction that have to be getting some miles. Unless you are towing very heavy most people don’t need one
  10. Mar 14, 2024 at 6:57 PM
    #220
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    @WiscoWalleye reported the failure of a 2020 transmission, post #211 just above.
    Here are a few others I found. Worth reading these threads if interested:
  11. Mar 14, 2024 at 7:26 PM
    #221
    d33pt
    d33pt New Member
    What determines if a truck gets a cooler from the factory? I thought it was only the 2019+ that did not get them, but my 2015 doesn't have a cooler.
  12. Mar 14, 2024 at 7:36 PM
    #222
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Does your truck have the tow package?, that could be the reason.
    ATV25 likes this.
  13. Mar 14, 2024 at 7:37 PM
    #223
    d33pt
    d33pt New Member
    It has a tow hitch and trailer plug. That's not the tow package?
  14. Mar 14, 2024 at 7:42 PM
    #224
    TILLY
    Massachusetts
    I would think so if its factory, there's no auxiliary cooler in the front behind your grille?
  15. Mar 14, 2024 at 7:43 PM
    #225
    d33pt
    d33pt New Member
    No, only the power steering cooler on the bottom.
  16. Mar 14, 2024 at 7:45 PM
    #226
    TILLY
    Massachusetts
    Very strange, did you buy it new?
  17. Mar 14, 2024 at 7:55 PM
    #227
    d33pt
    d33pt New Member
    No, i just got it. That's why I thought it was strange. I also had a 2013 before, with tow hitch and trailer wiring. No trans cooler either.
  18. Mar 14, 2024 at 8:01 PM
    #228
    TILLY
    Massachusetts
    I always thought if you had the tow package you got the cooler, but I guess I'm wrong. Maybe others here with a similar truck to yours can chime in and clear this up.
  19. Mar 14, 2024 at 8:33 PM
    #229
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I dont think 5 years is nearly enough time to tell. I have a 2019 and only have
    Look under your truck at the transmission and see if you have lines running to the front The cooler is part of the AC condenser and not a separate radiator.
  20. Mar 14, 2024 at 9:21 PM
    #230
    WiscoWalleye
    Yes mine failed at 45,500 miles. Previous owner towed a heavy ice castle with it in the winter and job trailers. Nothing that the truck shouldn’t be able to tow on a regular basis. My transmission was fully replaced under warranty fluid was all burnt and contaminated. Anyone that uses their truck as a truck not a city boy waste of space look at me bro machine will risk blowing their transmission without a cooler.
    Chip_Tundra likes this.
  21. Mar 14, 2024 at 11:06 PM
    #231
    d33pt
    d33pt New Member
    Oh i was looking for something like this. Aren't the lines from the transmission running to the radiator? That's how my tacoma is, so I assumed this was the same. I never actually followed the lines. I will check next time I get under.
  22. Mar 15, 2024 at 4:21 AM
    #232
    bflooks
    bflooks New Member
    Metrowest MA
    Someone correct me if I'm wrong, but the 2/2.5 Gen Tundra has had multiple iterations of the cooler.
    1) separate standalone unit (similar to photo directly above only from the factory) 2008-2013?
    2) integrated into the radiator 2014(?)-2018
    3) none existent and people are adding an aftermarket external back to it (see photo directly above for an example of a GCS version). 2019-2021
    Just because you don't see it may not mean you don't have it in #2.
    ATV25 likes this.
  23. Mar 15, 2024 at 7:18 AM
    #233
    clownkillerloaf
    clownkillerloaf New Member
    Logan
    '21 SR 5.7
    4.6?
    AZBoatHauler likes this.
  24. Mar 15, 2024 at 7:29 AM
    #234
    Joe333x
    Joe333x Member
    Boston
    Correct The cooler before 2014 was a standalone radiator after 2014 it was integrated into the AC condenser and then in 2019 it was eliminated.
  25. Mar 15, 2024 at 7:39 AM
    #235
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    You're mostly correct except for #2 - it was was actually Integrated into the AC condenser not the radiator.
    And technically for #3 they had an "integrated cooler" whereby the ATF is cooled/warmed (depending on who you ask) by the engine coolant in a small puck like unit right beside the transmission.
  26. Mar 15, 2024 at 8:34 AM
    #236
    Joe333x
    Joe333x Member
    Boston
    That puck actually always existed in the previous models that came with a cooler as well which is why most refer to it as to warmer since it's largest function is too warm the fluid on a cold day using the warm fluid from the radiator. Does provide a small cooling factor when the ATF fluid is hotter than the coolant but it's so small that it doesn't make a big enough difference when the ATF gets very hot. If you look at my read out here in this type of situation the coolant is actually still going to raise the temperature of the transmission fluid because my coolant temperature is higher whereas with an external radiator the outside air temperature will always be cooler than the fluid temperature going to the radiator after the thermostat opens.
  27. Mar 15, 2024 at 8:41 AM
    #237
    AZBoatHauler
    So.Arizona
    We’re all friends.
    Joe333x and bflooks[QUOTED] like this.
  28. Mar 28, 2024 at 1:10 PM
    #238
    NoMoreGreen
    Robert
    2020 Tundra
    I regularly see temps in the 250s in texas, not towing, just driving.
    I think im gonna get a cooler installed here soon.... Toyota says temps are not an issue until 300? I think. Not sure how much I trust that. I did get my transmission fluid changed at 50K
    Joe333x likes this.
  29. Mar 28, 2024 at 3:20 PM
    #239
    SD Surfer
    Bruce
    So Cal
    It's unfortunate that we don't know how the previous owner towed these things.... Tow/Haul and S4 per the manual, or just put it in D and go.
    On another note, what's an Ice Castle?! Is that like an ice fishing house but bigger and for a King? (I'm a city boy, I don't know about this stuff) :rolleyes:
  30. Apr 8, 2024 at 8:33 PM
    #240
    WiscoWalleye
    :rofl::rofl::rofl:
    Yeah it would be nice to know how it was towed. An ice castle is essentially a camper that you tow out onto the lake and it lowers down into the ice and then has holes in the floor that you drill holes in the ice and fish out of. Essentially it’s like a $70k super fancy ice shack. This one in particular was like 26’ long I think. Not my thing. I use a tent and stay mobile. But some people like to set up and drink themselves silly in comfort :rofl:
    SD Surfer[QUOTED] likes this.
