Turbo Charging A Tundra!
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Mar 18, 2025 at 7:25 AM
    #1981
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    You could be our guinea pig for the smoothboost controller. You put on the small party pulley and then the controller opens and closes the bypass valve as needed to control to your boost pressure that you set with a dial. I think @helidave was looking into it. I emailed them before and they will gladly make one if one of their existing controllers doesn’t fit it sounded like.
  2. Mar 20, 2025 at 2:49 AM
    #1982
    bflooks
    bflooks [OP] New Member
    Metrowest MA
    Well, today is the day. Truck is headed off 93 miles via flatbed this morning so the engine swap can get underway.
    Plans:
    - engine swap with the XAT Racing basic build + BC springs and retainers
    - Replace every external part not included with the long block, except alternator and power steering pump.
    - Bypass the AEM water/methanol for a while.
    - Have the turbo shipped off to Precision for inspection and rebuild (if required) since we have some downtime.
    - EDIT: add Lexus coils during install
    The inspection and rebuild is due to my OCD. Despite the nastiness coming out of the oil pan (documented pages back around January 16th), it is still free spinning, but I refuse to have a new motor and then a failed turbo causing more downtime. Just proactively dealing with the potential issues now during the engine swap.
    I was going to do the Lexus coils but I'll wait for a 25% off sale. I'm def watching the continued success of them, though.
    reywcms, Mdl, ssmokedz and 6 others like this.
  3. Mar 20, 2025 at 5:13 AM
    #1983
    bflooks
    Metrowest MA
    Maybe I'm holding off on the Lexus coils. The price swing between Lexus branded vs supplier branded is rather dramatic. Just waiting on a response from another member before making the final decision.
    I absolutely just purchased the Lexus coils. lol
  4. Mar 20, 2025 at 7:10 AM
    #1984
    centex
    centex New Member
    Glad to hear you are having the turbo inspected. Cheap insurance for sure.
  5. Mar 20, 2025 at 7:36 AM
    #1985
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    With this fancy engine are you gonna push more than 3psi finally?
    :p
    Saltyhero13, centex, Mdl and 3 others like this.
  6. Mar 20, 2025 at 7:39 AM
    #1986
    bflooks
    Metrowest MA
    Sir. Don't be jealous that my 3 performs just as well as your 7. :)
    To answer your question, maybe. lol I tried it once or twice, but then the alcohol got me in trouble. I'm hopeful now that I'm dry, that maybe it'll be more willing to let me fool around a bit.
    Seriously, I'll probably be around 9-10psi (10-11psi for a SC).
    reywcms, Mdl, Wynnded and 1 other person like this.
  7. Mar 20, 2025 at 7:40 AM
    #1987
    snivilous
    SW UT
    My 4.5s dragy says otherwise :oops:
    reywcms, ZPhilip, ssmokedz and 2 others like this.
  8. Mar 20, 2025 at 7:44 AM
    #1988
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
  9. Mar 20, 2025 at 7:50 AM
    #1989
    bflooks
    Metrowest MA
    That one cuts deep. I thought we were playing lol
    reywcms, ZPhilip, Saltyhero13 and 7 others like this.
  10. Mar 20, 2025 at 7:51 AM
    #1990
    snivilous
    SW UT
    Hahahaha :rofl:
  11. Mar 20, 2025 at 7:58 AM
    #1991
    TurboKits
    TurboKits New Member
    I just heard from ECS, trucks just been unloaded! I should be heading up there in the next week or so to DYNO the Stage 1 on the 2016 TRD Pro. I'll go over everything with them then. Maybe you can make it down too? Meet the guys and see the truck on the DYNO?
  12. Mar 20, 2025 at 8:03 AM
    #1992
    bflooks
    Metrowest MA
    Was there a question in there? :)
    Hit me up with a day/time and I'll be there if I can be. Glad to hear the truck made it safely. Watching it leave on a flatbed was oddly emotional. lol
    TurboKits[QUOTED] likes this.
  13. Mar 20, 2025 at 8:19 AM
    #1993
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Not 15-20?
  14. Mar 20, 2025 at 8:21 AM
    #1994
    bflooks
    Metrowest MA
    lol. damn it. i was just having this entire conversation in a separate chat. let me copy/paste so everyone can understand and manage their expectations.
    Private chat question: What options did you go with and did you lower the compression?
    Response: I went with the XAT Racing baseline "built long block" option with the BC valves upgrade, stock sizing. (https://xatracing.com/XAT-3UR-full-build.html)
    Negative on compression changes. The Manley's come in at 10.00:1 vs the slightly higher stock compression. That should be everything I need/want, especially with them being able to set the ring gaps appropriately for up to 15lbs of boost and the BC rods that come with the build. They didn't seem to think a street vehicle would need more than that.
    Based on the math, 10psi should be about 600WHP. 650WHP (~11.5-12psi) is right up to the edge of the transmission limitations (from what WAT was saying). I need to be realistic since it's still just a DD/tow rig. That reality, plus the fact I wasn't fighting detonation or any other performance related issues (per the logs, anyways) says I should be in a good spot for work, play and reliability, with play being the least of my priorities.
    To continue the scale, the 15lbs of boost would run me to about 750WHP, which is just over the XAT claim of 800+ HP for their engine. I think fastlane was running closer to 16-19psi on his engine build, which I think is essentially the same as what I went with.
    I did add the XAT billet fuel rails, though. Just because. lol
  15. Mar 20, 2025 at 8:31 AM
    #1995
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's all good. Was just piling it on with the others. Keep it within the builds margins...I have no idea what that means.:D
  16. Mar 20, 2025 at 8:31 AM
    #1996
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Another thing to note, is that a restrictive exhaust on a turbo based system slows down the building of boost pressure. In other words, the more restrictive the exhaust the longer it takes for your boost PSI reach its peak :thumbsup:
    We were seeing drops of 2-3 tenths in the 1/4 on turbo buicks just by throwing on a test pipe to by-pass the CATs and mufflers (if they were restrictive also)... Plus the sound of an open exhaust w/20 PSI of boost coming on :hearteyes:
    First video I found w/a quick search... (just the exhaust no boost sound though) :(
    https://youtu.be/ACeu270zrhM
    Mdl and bflooks[QUOTED][OP] like this.
  17. Mar 20, 2025 at 8:36 AM
    #1997
    bflooks
    Metrowest MA
    Oh! Yeah, no. That game is over and done. @snivilous is a meanie and I'm still in the nurses office after he beat me and my pew pew'ter up on the playground. he has single handedly made my increase my goal to 4.49s. :)
  18. Mar 20, 2025 at 8:38 AM
    #1998
    snivilous
    SW UT
    On the one hand I think you should send that bitch to the stratosphere and lower the compression and run as much boost as pump gas can handle (probably 18-20psi). Flip side is, as you said the trans will shit its brains out quickly and that's probably in the 1000hp range. It's kind of funny to compare the Tundra setup to my 2JZ since it's nearly half the displacement at double the boost and similar power, but where as that engine is knock limited the Tundra is trans limited. Kind of sad and ironic that the big engine that can make a lot of horsetorques is mated to something that can't handle the horsetorques.
  19. Mar 20, 2025 at 8:48 AM
    #1999
    bflooks
    Metrowest MA
    Oh how I would love to send this thing full rip after I get it back. Maybe someday when there is a better transmission option that is sort of affordable. Maybe.
    Did I mention tow/camping season is quickly approaching? I need to stay focused on actually having a truck I can drive. lol
  20. Mar 20, 2025 at 9:16 AM
    #2000
    centex
    centex New Member
    All this racing talk is making me itchy to get back home and get to upping the boost.
    Saltyhero13, Jego, Mdl and 2 others like this.
  21. Mar 20, 2025 at 9:17 AM
    #2001
    bflooks
    Metrowest MA
    tell the family it's been nice but that you've got a bunch of strangers waiting on you, so you need to cut the trip short. :rofl:
    ZPhilip, Saltyhero13 and M3Tundra-JK like this.
  22. Mar 20, 2025 at 9:23 AM
    #2002
    snivilous
    SW UT
    How are you guys controlling boost anyway?
    Saltyhero13 likes this.
  23. Mar 20, 2025 at 9:23 AM
    #2003
    TurboKits
    A few quick videos we took while installing the kit on the 2016 TRD Pro. One of the hot side piping clearances, BEFORE any heat wrapping. We know the heat wrapping makes it look super tight, but it is actually not so and with the wrapping on top, it's even better.
    https://www.youtube.com/shorts/9gNnoyIkyN4
    We also created a video for the vacuum routing to the wastegate and the rest of the connections. This should really help clear things up! Enjoy!
    https://youtu.be/2J_GPAsdeh4
    ZPhilip, Jego, Tripleconpanna and 3 others like this.
  24. Mar 20, 2025 at 9:30 AM
    #2004
    TurboKits
    Your timing is impeccable... I just uploaded those videos a few minutes ago!!
  25. Mar 20, 2025 at 9:33 AM
    #2005
    centex
    centex New Member
    We are doing a 500 mile portion as I type today and then the final 200 mile tomorrow.
  26. Mar 20, 2025 at 9:44 AM
    #2006
    bflooks
    Metrowest MA
    safe travels and enjoy!
  27. Mar 20, 2025 at 10:02 AM
    #2007
    centex
    centex New Member
    Fun facts, was driving this morning and it was 0* outside. IAT’s were at 7* doing 70mph. Coolant was at 188* and trans was at 163*.
    Jego, Mdl and TurboKits like this.
  28. Mar 20, 2025 at 11:02 AM
    #2008
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I just ordered the Improved Racing 145 thermostat. I was running a 160. I noticed running the Dex3 when it was below 110deg F it had confused shifting 3-4. Once above that it was fine. I never had that issue with Toyota WS when it was cold. My ambient temps have been 44-50 deg F. The Dex3 is pretty thick at the cooler temp. Just a FYI if considering a different fluid.
    The temps with 160 thermostat were 160-185F driving around. Doing WOT pulls it would get up to 200F (TC) but come back down to 185F. I'll see how the 145 t-stat does. Although I'm not towing...
  29. Mar 20, 2025 at 1:45 PM
    #2009
    bflooks
    Metrowest MA
    You sneaky bastard! What is this "single turbo" clarification all about in these video titles? HHHHHMMMmmmmmm? :monocle:
  30. Mar 20, 2025 at 2:01 PM
    #2010
    TurboKits
    Purely because we would constantly be asked and with the battery, fuse box, ABS, master cyl, etc... It would be very tough to get a turbo into the other side and make it a twin!
    M3Tundra-JK and Mdl like this.
