Turbo Charging A Tundra!
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Feb 23, 2025 at 8:47 AM
    #1801
    centex
    centex New Member
    There’s 2hrs of my day wasted. Now for clean up and on to install.
  2. Feb 23, 2025 at 9:41 AM
    #1802
    centex
    centex New Member
  3. Feb 23, 2025 at 11:19 AM
    #1803
    bflooks
    bflooks [OP] New Member
    Metrowest MA
    Get another row or two of tape on that inner fender to cover the turbine housing footprint. Looking good, though!!
    HulkSmurf14 and Jego like this.
  4. Feb 23, 2025 at 12:20 PM
    #1804
    centex
    centex New Member
    What about the rear o2 sensors? Is there an extension harness or something to connect those up?
    Also,
  5. Feb 23, 2025 at 12:34 PM
    #1805
    bflooks
    Metrowest MA
    Tape that fender. :)
    Rear O2s fit. The drivers side bracket gets bent down a bit (harness may also get clipped on the backside of the bracket) to get enough slack to cross under the transmission. You'll see what I mean. No extension harness.
  6. Feb 23, 2025 at 12:41 PM
    #1806
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    :yay:
    bflooks[OP] likes this.
  7. Feb 23, 2025 at 1:27 PM
    #1807
    centex
    centex New Member
    Now to find slack for the MAF harness.
    M3Tundra-JK, Gaston, AZTundra and 2 others like this.
  8. Feb 23, 2025 at 1:33 PM
    #1808
    bflooks
    Metrowest MA
    Oh no!!! Did it not get out in the instructions? You need to pull the MAF wires out of the engine harness, back to about the rear coil, and then re tape the harness that runs along the block. That opens up the slack required to get to the new MAF location Not hard, but OMG I hope it was in the instructions. I was upset when I needed to cut that tape open.
  9. Feb 23, 2025 at 1:58 PM
    #1809
    centex
    centex New Member
    What are these?
  10. Feb 23, 2025 at 1:58 PM
    #1810
    centex
    centex New Member
    I’d have to check but I don’t remember that.
  11. Feb 23, 2025 at 2:11 PM
    #1811
    bflooks
    Metrowest MA
    That sucks about the tape needing to get cut back, but that's what you need to do for the MAF part of that, then rewrap/close the cut.
    Those Snow parts are the 1-way check valve for the water/meth system. Goes inline before the nozzle, arrow towards the nozzle.
    Mdl likes this.
  12. Feb 23, 2025 at 2:16 PM
    #1812
    bflooks
    Metrowest MA
    IIRC, you can see the MAF offshoot behind the rubber line. That's how far back it needs to go.
    Jego likes this.
  13. Feb 23, 2025 at 2:28 PM
    #1813
    centex
    centex New Member
    It wasn’t bad. Cut about 4” back and that was enough.
    I’ve hit a stopping point for the day. Been cranking non stop since 930 with no food or breaks. Oops. I’m also out of vac line and need a bolt and two nuts for the drilled out exhaust manifold and to replace another nut that was threading iffy.
    But it’s 99.5% done. Grab the hardware and finish that up quick tomorrow.
  14. Feb 23, 2025 at 2:32 PM
    #1814
    bflooks
    Metrowest MA
    Nicely done and congrats!
  15. Feb 23, 2025 at 2:39 PM
    #1815
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Wow looks great! Congrats. How many hours you spent so far?
  16. Feb 23, 2025 at 2:45 PM
    #1816
    centex
    centex New Member
    Roughly 21ish. You could knock two off due to the bolt but I counted it. I’ve still gotta do the map, boost sensor, blow off valve, and meth vac lines. Load the tune, prime the oil system, and see what happens.
    Oh and of course I dropped one of the springs for the turbo blanket in to the abyss of the truck so awesome.
    Jego likes this.
  17. Feb 23, 2025 at 4:36 PM
    #1817
    centex
    centex New Member
    What’s this pipe and should there be a hose coming off the blow off valve discharge port?
    Black@Blue19 likes this.
  18. Feb 23, 2025 at 4:39 PM
    #1818
    bflooks
    Metrowest MA
    That is the recirculation pipe if you plan to send the waste gate through the exhaust.
  19. Feb 23, 2025 at 4:41 PM
    #1819
    bflooks
    Metrowest MA
    Blow off valve does not require a pipe coming off of it. That's totally optional. Just turn it so it is facing downwards to avoid any dust or water to accumulate.
    Edit: there will be a vacuum line coming off the top/back of the blow off valve.
    centex likes this.
  20. Feb 23, 2025 at 5:08 PM
    #1820
    centex
    centex New Member
    That’s what I suspected. Guess this is the part you hand to the exhaust shop and say “make this work?”
    bflooks[QUOTED][OP] likes this.
  21. Feb 23, 2025 at 5:09 PM
    #1821
    centex
    centex New Member
    Assumed but wanted to check.
  22. Feb 23, 2025 at 5:14 PM
    #1822
    bflooks
    Metrowest MA
    Yes. I believe it is still meant to be a slip joint into the down pipe #2, but may need the WG flange welded on.
  23. Feb 23, 2025 at 5:49 PM
    #1823
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I don't see it but where are you planning to strap the turbo on it?
    Jego[QUOTED] likes this.
  24. Feb 23, 2025 at 6:08 PM
    #1824
    centex
    centex New Member
    Once my body recovers from this ordeal, I may try and weld it up. Gonna irritate Jesse doing it with flux core wire and messing up his pretty stainless but I don’t think he’ll make me return the system over it.
    bflooks[QUOTED][OP] and Jego like this.
  25. Feb 23, 2025 at 6:46 PM
    #1825
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Can't wait to have that kit fully installed on my Tundra.
    I feel like :ballchain:
    centex likes this.
  26. Feb 23, 2025 at 7:11 PM
    #1826
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    I am in the same boat. But in my case I have to mod the whole crossover pipe to make it fit. I am planing to use SS flux core wire too but to be honest this is the first time I am going to try it. Let's see. Upgraded my welding machine recently from Craftman 90 amp. to Lincoln Elec. 140amp.
  27. Feb 23, 2025 at 7:32 PM
    #1827
    centex
    centex New Member
    I’m running a Hobart 140. Thing makes my previous Lincoln 90 look like a soldering iron. Used it on level 4 today on the stud and had the stud sparking it was so white hot. Not that it made a damn bit of difference trying to extract the stupid thing but it gets hot quick.
    Jego likes this.
  28. Feb 24, 2025 at 6:09 AM
    #1828
    TurboKits
    TurboKits New Member
    Dude!!!! Amazing progress this weekend. Hit me up if you have any questions or need to go over any part! Also, did you get the basemap I sent last week?
    HulkSmurf14 likes this.
  29. Feb 24, 2025 at 6:31 AM
    #1829
    centex
    centex New Member
    Yes I did. Haven't loaded it yet.
    I gotta say, the kit fits fantastic. Aside from needing to move things farther out of the way than I had them moved, everything drops right in and fits together great. I did have to struggle a bit to get the up-pipe to the crossover pipe put together but that's to be expected. I don't see how in the world anyone could do this with the trans cooler lines in place. Those things would have caused a HUGE pain in the rear trying to snake everything and get stuff tightened. Y'all did a good job cramming 10lbs of stuff in a 5lb bag.
    TurboKits, bflooks[OP] and Jego like this.
  30. Feb 24, 2025 at 9:43 AM
    #1830
    TurboKits
    Thanks!! Yeah, I'd say 70% of the install is the prep-work! Happy to see it coming together :)
