Turbo Charging A Tundra!
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Feb 3, 2025 at 5:55 PM
    #1621
    centex
    centex New Member
    I read through the instructions today and started putting puzzle pieces together. I’m gonna work on wrapping the piping this week and get the meth tank mounted and possibly lines run. The big fun stuff is still a few weeks out when I get some weekend time to do it but I can work on chipping away at everything else in the meantime time.
  2. Feb 3, 2025 at 6:04 PM
    #1622
    bflooks
    bflooks [OP] New Member
    Metrowest MA
    M3Tundra-JK[QUOTED] likes this.
  3. Feb 3, 2025 at 7:32 PM
    #1623
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
  4. Feb 3, 2025 at 8:48 PM
    #1624
    centex
    centex New Member
    So when should injectors and plugs go in? I could do them now or during or after.
  5. Feb 4, 2025 at 6:10 AM
    #1625
    TurboKits
    TurboKits New Member
    We added the Wholesale Auto Extreme Duty VB to our site and are set up with the US distributor to be able to help get these into Tundra owners hands! https://www.turbokits.com/2007-2021-tundra-5-7l-6at-extreme-heavy-duty-valve-body-upgrade.html
  6. Feb 4, 2025 at 6:12 AM
    #1626
    TurboKits
    Yeah, per our email conversation. You can install the full front mount intercooler and piping and water meth and prep the areas for the hot side piping, gauge install, etc without taking the truck off the road for more than a days worth of work. And you can pretty much stop at any step and get back on the road if needed.
    e30cabrio and Jego like this.
  7. Feb 4, 2025 at 6:13 AM
    #1627
    TurboKits
    The injectors would require a retune, which would be best to be linked to the high flow MAF scaling, so there isn't an extra tuning step. The spark plugs can go in anytime.
    e30cabrio and Mdl like this.
  8. Feb 4, 2025 at 6:30 AM
    #1628
    centex
    centex New Member
    That was kinda my thinking. The 1 step colder plugs wouldn't be a real issue but the injectors and scaling would be.
    TurboKits likes this.
  9. Feb 4, 2025 at 6:59 AM
    #1629
    bflooks
    Metrowest MA
    Well this is certainly something. :) Congrats!!!!
    EDIT: Oh! Per WATs website regarding the Extreme VB Upgrade:
    "We are talking about engine power or torque that is greater than 50% than what came out of the factory. A word of warning though, the Heavy Duty Extreme Valve Body can be quite thumpy in the gear changes at low throttle. ie. if you are driving in heavy traffic at 10 to 30km/h. This is a result of the increase to the pressures for the clutch packs so that there is much greater clamping ability during the gear change."
    Based on the calculator, this is 5-20mph. I suspect it can be overcome by utilizing S1/S2 instead of Drive and letting it try to shift itself up to 3rd or 4th. Probably better for the brakes, too.
    e30cabrio, Jego and TurboKits[QUOTED] like this.
  10. Feb 4, 2025 at 9:21 AM
    #1630
    centex
    centex New Member
    When you scan the QR code for the instructions and it comes back not found.
  11. Feb 4, 2025 at 9:32 AM
    #1631
    TurboKits
  12. Feb 4, 2025 at 10:21 AM
    #1632
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    Shifting would be equivalent to what some IPT VB upgrades experience.
  13. Feb 4, 2025 at 10:23 AM
    #1633
    centex
    centex New Member
    Ya I should have read your directions a little more thoroughly. Mounted the tank on the passenger side of the bed instead of driver. Oops. I’ve got nutserts so no biggie.
    I did start pulling cable and vac hose for the meth system. Was hoping to get it pretty much wrapped today but the previous owner jacked with the mid pipe so there’s a cat where the pump should be. Oh well.
    e30cabrio, Black@Blue19, Jego and 2 others like this.
  14. Feb 4, 2025 at 10:36 AM
    #1634
    TurboKits
    looking clean so far. My OCD is pleased with the wire run!
    e30cabrio, HulkSmurf14 and Jego like this.
  15. Feb 4, 2025 at 10:38 AM
    #1635
    centex
    centex New Member
    Note to self. Don’t show Jesse pictures of the finished wiring for fear of triggering him.
  16. Feb 4, 2025 at 10:38 AM
    #1636
    bflooks
    Metrowest MA
    That's funny! I look at the wires and I'm crying on the inside because my brain doesn't work like that anymore. lol
    Jego likes this.
  17. Feb 4, 2025 at 10:41 AM
    #1637
    TurboKits
  18. Feb 4, 2025 at 12:22 PM
    #1638
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    I started with the water/meth kit install too. I have a 42 min. video about it but still in progress. Here are some photos of the actual view.
    Added a filter below the tank.
    This is how it looks behind the bed panel. The wire harness comes from the top and the water /meth hose is the one going out from the rubber grommet.
    I had 2 20ft hose here is the union.
    Hose not visible behind the mud guard. Harness already relocated on this pic.
    Solenoid installed using a custom mount.
    Solenoid mounted in the front passanger side.
    This is the relays box.
    Installed the controller here but I don't like it anymore. I will change it from here.
    Status LED installed in gauge mount.
    One of theses switches will be used to have an easy way to turn it on/off
    Hope this help!
  19. Feb 4, 2025 at 12:49 PM
    #1639
    TurboKits
    Whoa, that's coming out great!
    ZappBrannigan and Jego[QUOTED] like this.
  20. Feb 4, 2025 at 2:22 PM
    #1640
    centex
    centex New Member
    That’s really nice and clean @Jego
    I got the meth kit about 70% done. Tank is remounted, level sensor wired in to the harness, meth line routed to the engine bay and zip tied out of the way for the moment. Going to steal jego’s idea for the solenoid mount. I got the wiring harness pulled into the truck and over to the glovebox but I don’t think I want to mount it there. All in all I’ve got about 3.5hrs into it today.
    Was looking at the gauge pod and decided to order a Rago dash mount and will mount the meth controller and scan gauge there. Still in my eye line while driving and something different. Gonna suck running the wires up there but it was gonna suck doing it to the pillar also so meh.
    My plan tomorrow is the boost solenoid, map sensor, meth solenoid (annoyed I’ve got to find screws that fit it since it didn’t come with any), and then start moving the fuse box and wiring around.
    What’s everyone using for a switched 12v source?
    HulkSmurf14, TurboKits and Jego like this.
  21. Feb 4, 2025 at 4:11 PM
    #1641
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Nice!
    For the 12v power source, in my case... a fuse tap to the lighter adapter circuit will power the switch panel. This way when the truck is off all relays will be turned off by default even if a switch (from the panel) is in the On position.
    Here are better photos of the solenoid. I used a recycled radio mount bracket and 2 aluminum rivets.
    e30cabrio and TurboKits like this.
  22. Feb 4, 2025 at 4:28 PM
    #1642
    centex
    centex New Member
    That’ll work and what my plan was as well. I’ve got a 8 circuit relay box from Amazon I was going to utilize for this.
    TurboKits, Black@Blue19 and Jego like this.
  23. Feb 5, 2025 at 8:48 AM
    #1643
    centex
    centex New Member
    Meth and map mounted. Boost solenoid is going to go back towards the firewall on the fender but need some longer self tappers.
  24. Feb 5, 2025 at 9:48 AM
    #1644
    bflooks
    Metrowest MA
    Disregard previous post: Based on photos, I think you are correct. Language referenced:
    2.4 MAP sensor 1. The MAP sensor MUST be installed with the hose fitting facing down.
    e30cabrio, Jego and TurboKits like this.
  25. Feb 5, 2025 at 9:58 AM
    #1645
    TurboKits
    It's downwards so no moisture or any vapor build up sits on the electronics.
    e30cabrio, Jego, centex and 1 other person like this.
  26. Feb 5, 2025 at 10:04 AM
    #1646
    bflooks
    Metrowest MA
    That is the part I was fuzzy on. For the life of me I couldn't remember where the port was on it, I just knew they wanted it down. The engine bay is far more convenient to access than behind the dash.
  27. Feb 5, 2025 at 11:42 AM
    #1647
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    The highlighted statement above made me think to install the map sensor in the interior. The vacuum hose have to go into the interior anyways for the gauge and w/m controller, but I see how covenient is to install it in the engine bay. :monocle:
    e30cabrio likes this.
  28. Feb 5, 2025 at 11:44 AM
    #1648
    TurboKits
    We've had them installed both in the engine bay and under the dash and did not have any issues either way.
  29. Feb 5, 2025 at 12:25 PM
    #1649
    AZTundra
    Paul
    Phoenix, AZ
    I installed mine here on the left of the brake booster.
  30. Feb 5, 2025 at 12:47 PM
    #1650
    centex
    centex New Member
    Started the wiring harness relocation. Got nearly done and realized I don’t have a 2.5” hole saw. I have a 2” and a 3” but not a 2.5”. Fairly straight forward process. I’ll pick up the saw tonight and finish that and the heat tape wrap tomorrow. So far today I’m about 2.5hrs into it and the hardest part was pulling the dang fender liner out. Who designed those ridiculous clips?
    Jego, bflooks[OP] and TurboKits like this.
