Turbo Charging A Tundra!
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Oct 8, 2024 at 4:26 AM
    #1321
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Dragy
    just post the dragy
    all these number are very well laid out.
    Let's see the rubber meet the road....so to speak.
    Danimal86, TurboKits and Jego like this.
  2. Oct 8, 2024 at 4:54 AM
    #1322
    bflooks
    bflooks [OP] New Member
    Metrowest MA
    I'm happy to update the spreadsheet once I have the injectors and pump, but I'm certainly not a Dragy time pro. Heck, my times are still improving with my current setup which hasn't changed in months.
    Maybe Jesse wants to lay down some times once we do the swap. 0-60 times aren't going to be our strong point, so matching a 4.6s time for the leaders board isn't realistic for my truck. The SC freaks of nature can hold those titles.
    1/8th and 1/4 mile times and top speeds could be interesting.
  3. Oct 8, 2024 at 5:04 AM
    #1323
    nobodyintexas
    nobodyintexas What?
    South of Houston
    < to be read with a calm tone, not meant to sound argumentative. just a discussion>
    Good points.
    I'll expound...if the Turbo is a performance upgrade, under which performance specs will it be judged?
    and, what efforts have been made to demonstrate those specs?
    us knuckleheads that use the S/C, are inquisitive to this wonderful addition to Tundras.
    I am in no way doubting the efficacy of turbos...quite the opposite.
    I want to see the numbers.
    as to your last comment about 1/8,1/4 & top speed...I respectfully disagree.
    Tundras are trucks.
    at best, we are good for 0-60. maybe 1/8 mile.
    we need to be powerful & reliable. This is why I admire/appreciate the towing data.
    top speed is dangerous & largely unused.
    1/4 mile stuff is dangerous too..too much stress on a stock block. and again, largely unused.
    0-60? we do it every day.
    Silver17, ZPhilip and Jego like this.
  4. Oct 8, 2024 at 6:08 AM
    #1324
    bflooks
    Metrowest MA
    Great question regarding the metrics. I will defer the educated and informed responses to Jesse @TurboKits
    My personal thoughts: Dyno numbers don't lie, but I'm lost on how to accurately capture what I care about vs Dragy times. At baseline I don't think a single turbo is strongest in 0-60mph, but maybe I'll be proven wrong. Dragy also doesn't really afford a way to track my use case. Maybe Stage 2 and not having a 5k rpm governor will knock my socks off and put me down around 5.0s, but I don't believe I'm your huckleberry for 0-60 times. I'll absolutely give it a shot, though! I agree on top speed being silly, but I think it does capture the power throughout a prolonged pull, just like the 1/8 and 1/4 mile times would capture the same. IMO, they are more supportive of my use case since those prolonged pulls are me getting onto a highway and up to speed with the trailer. Open to ideas since I want to support the discussion until someone else comes along with a focus on the fun part of the pedal :)
  5. Oct 8, 2024 at 6:09 AM
    #1325
    TurboKits
    TurboKits New Member
    We had been looking for the TRD Pro we just got for years. I did see a local Gen2.1 with a factory TRD SC on it and was tempted to get it and install the kit for twin charging and see what would happen. Maybe some day we can attempt it. I think the kit has a great chance of fitting with some tweaks to the piping! Would be a sick project tho.
    Jego and ssmokedz like this.
  6. Oct 8, 2024 at 6:16 AM
    #1326
    TurboKits
    Yes sir, we will get the data for sure... I agree, the truck is a 2/3/4th truck. 1st spins, unles you are hammering it in 4WD and at the top of 4th, I am going almost 120 MPH, which on a lifted Tundra with larger wider wheels is pretty sketchy. I think a 30-120 metric is good, the 0-60MPH, 1/8th and 1/4 are great numbers. I think the 1/4 will really only be attempted on a track for safely tho. We are up in northwestern CT and there aren't many 1/2 mile straight, flat roads and by the time you drive around to find one and then wait for no traffic. It's easier to take the 1hr+ trip to Lebanon and hit the track. But yes, we will get this data...
  7. Oct 8, 2024 at 6:25 AM
    #1327
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Thank you.
    when you boil it down, at some point in time, a relatable comparison is warranted/needed/desired.
    and, since the only 2 viable/genuine performance upgrades are S/C's & turbos.
    I am sure there will be differences, clearly.
    my expectations are that these variances will be small.
    I reckon the 0-60 would be the common metric.
    another variable to consider is the mystical 600hp (at crank) limit of these stock blocks.
    I doubt 700hp on a stock block is "reliable". <Icarus syndrome.>
    Jego and bflooks[OP] like this.
  8. Oct 8, 2024 at 6:28 AM
    #1328
    bflooks
    Metrowest MA
    Silver17, Jego and nobodyintexas like this.
  9. Oct 8, 2024 at 7:01 AM
    #1329
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    I'm in CT. More than happy to make a run to Lebanon with ya! I hit that track at least once a season (usually with my Camaro not my truck though) but have run the Tundra there once as well.
    Silver17, Jego and Mdl like this.
  10. Oct 8, 2024 at 7:32 AM
    #1330
    TurboKits
    Now that we have proven the power, while being VERY conservative on things. We will 10000% be pushing the limits on the 2016 TRD Pro. To the point where we won't care if we blow it up, as we'll just build for more power. So the tests, trials and limits of our system will continue to be pushed...
    Heck yeah, we'll reach out when ready!
    ZPhilip, Jego, Mdl and 4 others like this.
  11. Oct 8, 2024 at 7:34 AM
    #1331
    bflooks
    Metrowest MA
    :yes:
    Jego, ssmokedz, Mdl and 1 other person like this.
  12. Oct 8, 2024 at 7:57 AM
    #1332
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Also the blower becomes the restriction we used to do this in the mustang cobra and ford lightning days.
    Jego, Mdl and TurboKits like this.
  13. Oct 8, 2024 at 8:15 AM
    #1333
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I would love to see a twin charged setup on a built engine...
    The dodge demon was twin charged awhile back. I worked on Detroit diesels 6v92ta's that were twin charged and just a cool setup. Programming is the key.
    Jego and reywcms[QUOTED] like this.
  14. Oct 8, 2024 at 8:17 AM
    #1334
    TurboKits
    Yeah I think if we were ever to try something like a twin charged, Haltech or Motec would be the tuning choice.
    Jego likes this.
  15. Oct 8, 2024 at 8:19 AM
    #1335
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    So, from a practical standpoint, twin charged engine is possible?
    I mean, I am sure the original transmission would go ka-boom so that needs a newer/super heavy duty one to work as well as fuel pump....
    But wouldn't the two system fight against itself?
    Jego likes this.
  16. Oct 8, 2024 at 8:22 AM
    #1336
    TurboKits
    Up to a flow / restriction point, the 2 systems would work well together. After a certain point tho, they would fight eachother.
    Jego, reywcms and Mdl like this.
  17. Oct 8, 2024 at 8:29 AM
    #1337
    Ghost Rider
    Ian
    Cypress, Texas
    How far out is that delta in general?
    I would imagine price is not practical for this to even exist that barely see any twin charged these days as well as the delta point basically null out the benefit of having a twin system?
    Jego likes this.
  18. Oct 8, 2024 at 8:30 AM
    #1338
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The Dodge had to ,if I remember, time the flow of air for turbo and SC to work together. That was the hardest part.
  19. Oct 8, 2024 at 8:32 AM
    #1339
    TurboKits
    Can't even guess without flow maps of both expected head units. It is more complex than ever needed and would really only be for fun, show, prove engineering prowess. But if straight power is all that you are after, turbo, build motor and trans, turn up boost. Don't over complicate the process.
    Jego and Ghost Rider[QUOTED] like this.
  20. Oct 8, 2024 at 8:35 AM
    #1340
    Ghost Rider
    Ian
    Cypress, Texas
    I need a truck, not one that blows all caskets and transmission and can only go one round.....:oops:
    Sorry for straying away from the main theme, let us return to that.....
  21. Oct 8, 2024 at 8:36 AM
    #1341
    TurboKits
    Ha Ha, no worries, we own Tundras for the reliability of it all. So I agree, the hunt for HP is great, but making sure reliability isn't lost in the process is paramount.
  22. Oct 8, 2024 at 8:38 AM
    #1342
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Speaking of motec let's figure out a plug and play system lol
    Jego, helidave and Mdl like this.
  23. Oct 8, 2024 at 8:51 AM
    #1343
    TurboKits
    We can, we have connects with a company across the pond that does all sorts of Motec PnPs. They are expensive tho!
    Jego, reywcms[QUOTED] and Mdl like this.
  24. Oct 8, 2024 at 10:13 AM
    #1344
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Was talking to some guys the other day about doing this, not on anything specific. They said what they do is use the blower for the instant torque and remove the lag, and once the turbo spools up there's a bypass valve so the turbo doesn't blow through the supercharger. They don't compound the power/boost, instead they are setup to be providing boost where they're both best used--supercharger at low rpm and the turbo at high rpm.
    Jego, Mdl, M3Tundra-JK and 3 others like this.
  25. Oct 8, 2024 at 10:57 AM
    #1345
    TurboKits
    If we were to do it, I would try compounding 7-10 PSI and see what happens :) LOL
  26. Oct 8, 2024 at 11:05 AM
    #1346
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    bflooks[OP], Jego and Ghost Rider like this.
  27. Oct 8, 2024 at 11:07 AM
    #1347
    TurboKits
    :rofl::rofl:
  28. Oct 8, 2024 at 11:09 AM
    #1348
    Ghost Rider
    Ian
    Cypress, Texas
    I mean, pretty spot on, right? lol.....
    Jego and TurboKits[QUOTED] like this.
  29. Oct 8, 2024 at 11:14 AM
    #1349
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Build motor,,, build trans,, twin turbo!!!:)
    Jego, Mdl and nobodyintexas like this.
  30. Oct 8, 2024 at 11:26 AM
    #1350
    M3Tundra-JK
    Scott
    2005 GX470
    That's what I want to see!
