@TundraTex's FRAC harness (Front/Rear Anytime Camera) Install/Review
Discussion in 'Audio & Video' started by BlueBottle, Jul 3, 2017.
  1. Feb 25, 2020 at 9:19 AM
    #151
    Spook46
    Spook46 New Member
    Tundra TRD PRO
    @TundraTex Yes it goes black, also checked the switch and the connections look fine. The only thing I haven't done is use a volt meter, the wiring under the hood is bundled up pretty good. I also used shrink wrap on most the connections.
  2. Feb 26, 2020 at 6:38 AM
    #152
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Ok. If the screen goes black, that indicates that the FRAC circuit has power and is properly switching to the front cam video line, but since there is no video to display - the screen is black.
    This means the cam is not providing video. This can be caused either by a bad camera, or no power or ground to the camera or by a disconnected or broken video line.
    Since you replaced the camera, odds are it’s ok. I suspect the cables between the camera and the FRAC or the actual RCA plug from the front cam to the FRAC circuit being loose or broken. Did you replace them when you changed out the camera? If not, they could be the problem.
    I’ve seen the small power/video connector in the cam harness go bad and I’ve seen the metallic center conductor of the Front Cam RCA actually break and get stuck the FRAC RCA without making contact.
    So focus your troubleshooting on the front cam and it’s wiring.
  3. Feb 26, 2020 at 7:07 AM
    #153
    Spook46
    Spook46 New Member
    Tundra TRD PRO
    I'll do that, thank you for your help. I'll post any findings and if I got it going. Thanks again
  4. Feb 27, 2020 at 4:46 AM
    #154
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Mine did the same thing when I installed it. I unhooked all the connections behind radio, hooked everything back up and it’s been working great ever since.
  5. Feb 27, 2020 at 10:44 AM
    #155
    Spook46
    Spook46 New Member
    Tundra TRD PRO
    I'll try that as well, thanks for the info.
  6. Feb 29, 2020 at 9:09 AM
    #156
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. The FRAC Harness ties into the wiring for the factory tailgate camera. You just need to buy a front cam.
    phogallen[QUOTED] likes this.
  7. Feb 24, 2021 at 10:36 AM
    #157
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Has there an updated harness that I missed lately?
    This thread has been inactive for a year
  8. Feb 24, 2021 at 11:08 AM
    #158
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    HulkSmurf14 likes this.
  9. Feb 24, 2021 at 11:09 AM
    #159
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Mucho thanks.
  10. Aug 1, 2025 at 2:09 PM
    #160
    Nickatnight
    Nickatnight New Member
    Nick
    98445
    2021 1794 Tundra
    Rhino running boards, Amber running lights, Underhood automatic LED Lighting, OEM Fender Flares, Tech12 Volt New Killer Audio System with factory Head Unit.
    Hi Tex, after a couple of months my Frac cameras started going to a black screen again. Took the head unit out again for the fourth time and the power/video connector (yellow) had worked itself loose again. I tried to crimp it slightly but the connection would slide apart. Need to get that connector replaced, I spend more time getting in and out of the truck to see if the hitch is lined up then looking at either camera.
    Thanks,
