@TundraTex's FRAC harness (Front/Rear Anytime Camera) Install/Review
Discussion in 'Audio & Video' started by BlueBottle, Jul 3, 2017.
  1. Jul 24, 2017 at 6:43 AM
    #91
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    3/4" I believe. I used a 1/4" drill bit then used a step bit to get to the size.
    AZTundra and Skippy[QUOTED] like this.
  2. Jul 24, 2017 at 7:23 AM
    #92
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The detachable part of my cam harness wasn't long enough to reach the boot. I guess there's some variation in the supplied parts.
  3. Jul 24, 2017 at 9:32 AM
    #93
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Mine wasn't long enough either. Plus I want it near the grill so that if the grill has to ever come off the connnector is close enough.
    Tundra Fan and TundraTex[QUOTED] like this.
  4. Jul 24, 2017 at 1:44 PM
    #94
    PMG
    PMG New Member
    Yes, I would have to snake it back through the hole if I need to remove the grill.. In a sense it's good because it prevents me from buying a new grill..
    Don't get me wrong, it's a 20 second procedure. The connector fits the hole snuggly and feels great going through.
    BlueBottle[OP] likes this.
  5. Jul 24, 2017 at 2:41 PM
    #95
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    That's good thinkin right there.
  6. Jul 27, 2017 at 3:28 PM
    #96
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    @BlueBottle I have the same camera as you, and wanted to clarify first prior to installation. You had mentioned soldering the power wire to extend it into the cab, however all I need to do is connect the 2 wires in the pic, and run the RCA cable through the grommet, is that correct?
  7. Jul 27, 2017 at 3:37 PM
    #97
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yes exactly. Solder those two red wires. Then you will connect the other side behind the radio to the frac harness. I believe it says camera 12v on the wire. @TundraTex can confirm what it says on his harness.
    Skippy[QUOTED] likes this.
  8. Jul 27, 2017 at 4:55 PM
    #98
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Connect it to the FRAC harness red wire with the spade connector. It's labeled FCam+.
  9. Aug 8, 2017 at 12:03 PM
    #99
    Skippy
    San Antonio US of A
    2016 Tundra 1794
    @BlueBottle @TundraTex
    Was going to do my install when it hit me. I've wanted to get rid of my chrome air vents, and silver Nav HD Accent around the HU since I've had my Princess so now might be the perfect opportunity while I had everything out. If I'm not mistaken the Nav HD Accent piece is held in place with clips, but do you guys know if there are any bolts as well, and do you think it would be worth the extra time? Figured since you all had already yanked everything you might have some input. Thx guys.
  10. Aug 8, 2017 at 2:23 PM
    #100
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I never actually paid attention to the accent piece as a separate part of the HU. But it's only 4 bolts to pull the HU out so it's probably worth it to do it that way.
    Start at the bottom of the center stack below the HU. The power adapter panel and the heat/AC control panel are both held in place with only clips. They are separate panels but are interlocked so they usually come out together. Once the AC panel is out you can access the 4 10mm bolts securing the HU in place. The HU also has a couple clips at the top so you have to give it a little tug (straight out) once the bolts are removed.
    Hope that helps.
    BlueBottle[OP] and Skippy like this.
  11. Aug 8, 2017 at 4:13 PM
    #101
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Skippy likes this.
  12. Aug 19, 2017 at 10:13 AM
    #102
    Berettafan
    Berettafan New Member
    2017 CM
    Has anyone found a camera with wide enough angle that it shows the bumper. Have a pro grill and would like to be able to get within inches of walls, not just a foot.
  13. Aug 19, 2017 at 10:14 AM
    #103
    Berettafan
    2017 CM
    Or maybe not possible to see the bumper due to design of the grill?
  14. Aug 19, 2017 at 2:53 PM
    #104
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Look at my pictures. You can see the bumper on mine.
  15. Oct 5, 2017 at 7:43 AM
    #105
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    @BlueBottle Very nive write up. It’s because of write up’s like these that make me consider doing what you just did. This is a very sweet mod. I would love the ability to allow my front seat passengers to mess w/ the nav while I drive. And The front camera could help a lot too. Thank you. :bowdown::bowdown::bowdown:
    @TundraTex When can I get one of these harnesses? I know there’s a waiting list and I’d like to be on it for ASAP as you get more in stock. :muscleflexing:
    :benchpress:
  16. Oct 5, 2017 at 7:57 AM
    #106
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Actually, you can order one now. I ordered more parts and have them on hand to build as people order. This reduces the wait time. I'm building up some orders this weekend and will be shipping next week. Go to post #1 of the FRAC "taking orders" thread to get ordering instructions.
  17. Oct 6, 2017 at 6:15 PM
    #107
    Berettafan
    2017 CM
    can someone post some pics of the grommet in the engine bay you pass the wire through? I'm seeing more than one.
    also has anyone considered mounting the switches just below the armrest? not sure how to take the center console apart for access.
  18. Oct 7, 2017 at 6:39 AM
    #108
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    TundraTex likes this.
  19. Oct 8, 2017 at 8:44 AM
    #109
    Berettafan
    2017 CM
    got it thanks!
  20. Oct 8, 2017 at 10:47 AM
    #110
    Stig
    Stig New Member
    Getting ready to start this install.
    Do I have to power the front camera with the FRAC harness? It would be easier to power it to a switched fuse in the engine bay.
  21. Oct 8, 2017 at 10:53 AM
    #111
    BlueBottle
    '16 Platinum 4x4
    See fine print
    He provides a lead on the harness. I would use that.
    TundraTex, 4x4_Angel and Bprose like this.
  22. Oct 8, 2017 at 10:58 AM
    #112
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    what he said
  23. Oct 8, 2017 at 11:13 AM
    #113
    Stig
    Stig New Member
    Why? Then I have to route the power wire from the camera through the fire wall. I already ran the RCA wire through the firewall a month ago and left the 12VDC wires in the engine bay.
    My question is more if the camera selector button relies on the front camera being powered to the frac harness or not. I guess I'll find out soon.
  24. Oct 8, 2017 at 11:15 AM
    #114
    4x4_Angel
    Bree
    Funky Town, Texas
    I believe it does. I'm not sure how you would utilize the camera otherwise with the FRAC.
    I'm not an electrician in any way by any means either....I'm just remembering how I installed my camera and FRAC. Doesn't seem that it would work without being connected to the actual FRAC.
  25. Oct 8, 2017 at 11:18 AM
    #115
    Stig
    Stig New Member
    The front camera could always be powered when the engine is running. The camera selector switch just changes which camera is shown on the screen.
  26. Oct 8, 2017 at 11:20 AM
    #116
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Oh the reason why I said that is so the camera is only powered when in use. With switched ignition it will always be on when the truck is on. But it should still work if that's the answer your looking for.
  27. Oct 8, 2017 at 11:20 AM
    #117
    4x4_Angel
    Bree
    Funky Town, Texas
    @TundraTex toy definitely need to answer his question. I'm not wrapping around my mind exactly what @Stig is trying to ask.
    and this is my weakest link in vehicles....electrical
  28. Oct 8, 2017 at 11:27 AM
    #118
    Stig
    Stig New Member
    Just tested it, camera can be powered externally from the harness.
  29. Oct 8, 2017 at 12:01 PM
    #119
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    It can but then it's always on. I think it'll burn out quickly, don't think they're designed for that. My av cable had a little red (hot) pigtail coming out each end. That's what I used to power the cam attaching it to the red wire in the frac harness. It works great.
  30. Oct 8, 2017 at 3:13 PM
    #120
    Stig
    Stig New Member
    Not sure how the camera will burn out if it's on while I'm driving, but if that red wire coming out of the yellow RCA connector will power the camera then I might take out the head unit and do that. I didn't realize that additional red wire could power the camera, since it already has a pos and neg wire near the camera. *Edit, I see post 97 details how to do it.
    I did blow the 2 amp fuse, even after testing it multiple times before I put everything back together. How many amps is the harness supposed to draw? The closest fuse I had at the time was a 7.5 so I put that in there for now.
