Tundra2's lifetime project
Discussion in '1st Gen Builds (2000-2006)' started by Tundra2, Apr 19, 2020.
  1. Feb 17, 2021 at 6:53 AM
    #91
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    by default, it's the latest image posted in the thread.
    ha!
    Tundra2[QUOTED][OP] likes this.
  2. Feb 17, 2021 at 7:03 AM
    #92
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    KNABORES and lsaami[QUOTED] like this.
  3. Mar 14, 2021 at 7:49 PM
    #93
    Tundra2
    Noah
    Western Kentucky
    Front end overhaul reservation because I'm lazy, tired, and am going on day five of a four day body funk. Lol
    RustyShackle323 likes this.
  4. Mar 14, 2021 at 7:59 PM
    #94
    Tundra2
    Noah
    Western Kentucky
    This past Tuesday (3/9/21) I heard a tink from the rear end. Got home, and started investigating.
    Slapped my tacoma rims on because I had my tools out.
    While swapping out drivers rear I discovered some more gnarly threads on wheel studs.
    Placed an order for 12 front, and 12 rear Toy OEM wheel studs.
    Friday morning (3/12/21), I reached out to @Professional Hand Model regarding questions I had about adjusting the rear star wheels to get the drums off.
    Here's how that went.
  5. Mar 14, 2021 at 8:30 PM
    #95
    Tundra2
    Noah
    Western Kentucky
    Saturday, when I got home I made the necessary adjustments to my work space because the forecast was rain all weekend.
    It didn't rain a drop.
    https://youtu.be/DVeZbdwxUxE
    https://youtu.be/5v6tkRYI4ho
    I added a clock to all these videos I made, and strung together for real time viewing without the need for "approximations" like in the day one video.
    I just realized that I don't have a "black" picture of the drums.
    :annoyed:
    Here's the Hubs.
    No more rust behind these "schmancy" wheels makes me happy.
  6. Mar 15, 2021 at 2:26 PM
    #96
    Hand Protectors
    Shmancy Snowflakes looking nice! You’ll be stoked on the paint resto you did in the future for looks. Good eye on the Drum Crack. Coulda been gnar gnar.
    How’d the Rubber Peel Back look on the rear cylinders?
    Tundra2[OP] likes this.
  7. Mar 15, 2021 at 3:57 PM
    #97
    Tundra2
    Noah
    Western Kentucky
    :thumbsup:
    I peeled back the boots between paint cycles. I really wasn't sure if it was supposed to be a little moist, or completely dry. Once boots were peeled back there was some moistness around the cylinders. Not necessarily wet, as in fluid running down the boot. Just moistness.
    I assumed this was normal as all four boots were like this.
    One day I may get OEM wheel cylinders, and drums. That's off in the future though. I'm just glad that I am not asking my MC/Booster to do things that it can't.
  8. Mar 15, 2021 at 4:10 PM
    #98
    Hand Protectors
    Yeah. I saw some moisture seeping out. Might be time for cylinder rebuild with your high miles.
  9. Mar 15, 2021 at 4:16 PM
    #99
    Tundra2
    Noah
    Western Kentucky
    Those cylinders were replaced at 313,461 miles. Guess OEM is in my future sooner than later. Is that something that can be replaceced without taking the whole drum apart?
  10. Mar 15, 2021 at 4:17 PM
    #100
    Hand Protectors
    Oh. Forgot. Not really.
  11. Mar 15, 2021 at 4:20 PM
    #101
    Tundra2
    Noah
    Western Kentucky
    It's okay. So, about the moisture from Dot 3? I didn't know my ass from my elbow about drums before this weekend. I'm not an expert, but I do know more now.
    Moisture inside the boots is acceptable?
  12. Mar 15, 2021 at 4:33 PM
    #102
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Maybe consult the service manual, but I think moisture and leaking are two different animals. shiny=moisture, leaking=dripping/pooling. But, shiny may be on it's way :)
  13. Mar 15, 2021 at 4:42 PM
    #103
    Tundra2
    Noah
    Western Kentucky
    Fair enough. Consultation will have to wait then as my phone will no longer pull up the FSM From the link that @BubbaW posted quite some time ago.
  14. Mar 15, 2021 at 4:57 PM
    #104
    Hand Protectors
    Mine were dry as a bone with 160k.
    The Plungers were starting to give way a little under microscopic inspections. Maybe because of lack of regular brake bleeds?
  15. Mar 16, 2021 at 4:53 AM
    #105
    Tundra2
    Noah
    Western Kentucky
    Zip-tied up my center rear bumper trim.
    Almost all of the clip/tabs have broken off over the years.
    Added my VLEDS license plate reverse lights that I purchased used from @Jwood562. It was great to do business with you!
    I'll edit in some more output shots later. I'll also swap the zipties out for @Darkness approved black ones. White is all I had at the moment.
    Editing in some output shots.
    https://youtu.be/-aUFLYtoBAU
  16. Mar 17, 2021 at 5:11 AM
    #106
    Hand Protectors
    Hows the LED License Light look with the natural eye? Pics look bright.
  17. Mar 17, 2021 at 5:18 AM
    #107
    Tundra2
    Noah
    Western Kentucky
    Compared to just the LEDs in the housing its a world of difference for me. I drive with the tailgate up, and I could still see a good ways out with it up. That's something I've always struggled with. I used to turn my headlights off to back into the driveway, but I don't think I'll be doing that anymore. :D
    I can take some in cab shots tomorrow morning if you'd like.
  18. Mar 17, 2021 at 7:05 AM
    #108
    Tundra2
    Noah
    Western Kentucky
    Installed an oxygen sensor fouler on my rearward heated oxygen sensor today.
    The Go/NoGo from Fluke variety Capcom was Go as my rear sensor was still in spec at ambient temperatures.
    :yes:
    Above picture is the "dry-fit." I removed half of the fouler, and torqued the new dorman gasket down to 14 ft.lbs on the tailgate per the FSM.
    No more gap. Torqued the exhaust side of the fouler to 14 ft.lbs with a new dorman gasket also. I started the truck, and then immediately dove underneath. I felt all my new connections with my bare hands for leaks before the exhaust got too hot. No leaky leaky. :)
    Two Gaskets are needed.
    Flea-bay has removed the actual fouler I used.
    5N0W808, Voss, Filthyphil and 3 others like this.
  19. Mar 18, 2021 at 4:03 AM
    #109
    Tundra2
    Noah
    Western Kentucky
    Here are in cab comparisons of new reverse lights.
    VLEDS with LED in OEM tails. Tailgate up, and down.
    LEDS in OEM style tails. Tailgate up, and down.
    I tried to hold the camera at the same spot for each picture, but didn't do such a great job at that.
  20. Mar 25, 2021 at 12:37 AM
    #110
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    well bud. i think that sold me on the vleds license plate reverse light...
  21. Apr 11, 2021 at 12:25 PM
    #111
    Tundra2
    Noah
    Western Kentucky
    Yesterday, I did three jobs.
    1. I added an Armor-All Steering wheel cover.
    2. Added a bluetooth Adapter to my stock head unit.
    3. Reinstalled my Tool box again.
    I'm loving the adapter so far. It was brought to my attention by @jimf909 in his thread.
    After this picture I wrapped the bluetooth box in a shop rag, and ziptied the rag to it. I figured it would help keep additional rattling down inside the dash since I was leaving it loose.
    Here's a link to the one I used which utilizes the 5×7 CD plug in the back of the radio. Turn the radio off to pause the music, and turn it back on to resume. Track UP/DOWN buttons skips forward/back. Really nice!
    Link.
    JasonC. and jimf909 like this.
  22. Apr 11, 2021 at 1:45 PM
    #112
    Tundra2
    Noah
    Western Kentucky
  23. Apr 11, 2021 at 2:20 PM
    #113
    empty_lord
    05 rollover special
    Bought a new one eh? I have the factory cap off an Toyota ae86 because I liked it. Lol
  24. Apr 11, 2021 at 2:25 PM
    #114
    Tundra2
    Noah
    Western Kentucky
    Lol. Yeah, I got an idea for the old fill cap and the new one was cheap enough.
    Post up a pic of yours!
  25. Apr 11, 2021 at 5:13 PM
    #115
    empty_lord
    05 rollover special
    JasonC., Voss and Tundra2[QUOTED][OP] like this.
  26. Apr 11, 2021 at 5:25 PM
    #116
    Tundra2
    Noah
    Western Kentucky
  27. Apr 11, 2021 at 7:40 PM
    #117
    Tundra2
    Noah
    Western Kentucky
    I'm thoroughly impressed with the output of the running lights (white light) of just the parking lights. I reckon I could drive just on these babies!
    Top picture of each set is a regular photo.
    Bottom picture is a long exposure "night mode."
    The following pictures are from the drivers seat.
    It's like a second set of fogs!
    Voss, Sirfive and Lil Steve like this.
  28. Apr 13, 2021 at 8:25 PM
    #118
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    I want one
  29. Apr 18, 2021 at 10:31 PM
    #119
    Tundra2
    Noah
    Western Kentucky
    Circling back to this... finally got my switch box working after several different headaches, help from a lot of people here, and one of my friends IRL.
    Started out with testing, and another headache. Go figure. Thanks to @Festerw, @assassin10000, and @empty_lord for the most recent ideas which prompted me to figure everything out.
    ^ Initial dry run just touching leads off to make sure it was all good before the final button up which was later on in the day.
    I cleaned up my switch leg wiring from this.
    To this.
    The black wire pictured above is my HOT wire that goes on the other side of the switch to close the relay(s.) Swapping that saved me from running another wire up into the headliner.
    After some more testing, and some wiring. I had something usable, but wasn't cleanly installed.
    Yeah, my sun canopy is broken. I left it up during a rainstorm, and the weight of the water broke it in half. Bummer.
    Added in a fuse holder at the battery. Stuck a 10 amp in there because it was all Wallace wurl had that was the larger fuses the holder calls for.
    I hacked up my overhead sunglasses compartment into a usable switch mount. Drilled a hole with a step bit, and stuck the switch in. Looks pretty good.
    Here's the wiring section.
    The "Pink" wire is my HOT wire from the relay box in the engine bay. White wire is the switch leg for Relay one, and the light blue wire is my "ground" so the light on my switch would work.
    Here's a picture without any editing so you can look at everything there unhindered.
    All that work for one little ole switch. :rofl:
    Here's a shot of the switch from as close to my point of view as I could get in a photograph.
    I'm in a lit parking lot so you can't really see the output of the ditch lights.
    They aren't adjusted yet anyways...
  30. Apr 18, 2021 at 11:45 PM
    #120
    daveeasa
    David
    I take it no more oval slots open? EDIT: I see one oval blank in the middle, any reason why you didn't want to use that for a switch?
    I saw someone's center console which had 4-6 blanks in it? But maybe you have bench seats? EDIT: Yes, you have a bench up front.
    What's the scoop on the passenger fender flare?
    I need to read this whole thread I think... EDIT: Amazing work, massive rehab, youdaman.
