Tundra2's lifetime project
Discussion in '1st Gen Builds (2000-2006)' started by Tundra2, Apr 19, 2020.
  1. Jul 5, 2020 at 4:07 PM
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Drove down to @FirstGenVol's stomping ground. Helped him install his Brute Force Fab bumper in exchange for his "old" one. Replaced my front bumper with his old one.
    Here are pictures of my bumper before removal.
    1Old Bump wid lights.jpg 20200629_200118.jpg 20200629_200107.jpg Below is a side shot of my drivers side fender. The seam damage is from a deer impact in mid August, 2019. (Pics attached.)
    ^The deer impact was 20-30 mph. Bent my fender, and pushed my bumper into my tires. For immediate repair at the time I pulled the bumper back out with a ratchet strap, and a tree.20200630_171126.jpg 20200705_102828.jpg 20200630_214842.jpg
    ^After settling back in from my day trip to help Erik out, I decided it best to paint the "skid plate bar" (left in last pic), and the bumper support (right in last pic)20200701_075512.jpg
    ^Started the tear down the next day by removing the deer guard first. Thankfully, when I installed my light bar I left plenty of cord for just such an occasion as this.20200701_083337.jpg
    ^Here is everything dismantled. At this point I discovered the "bumper filler" (painted bar below headlights) was loose on driver's side. Tightened all 10 mm nuts that were loose. From here I continued my frame inspection, and grease rub.20200701_085340.jpg
    I put my camera lens close to the hole marked with a green arrow, and shined a flashlight into the frame with my other hand. Started taking pictures. Starting on the driver's side.20200701_084759.jpg 20200701_084844.jpg
    ^This is NG situation. Sprayed Ospho metal treatment inside the frame, and spritzed some in with a misting spray bottle. Waited for the "fizzing" to stop, and then sprayed PB Blast inside the frame. Followed by Red'n'tacky spray grease in the aerosol can.I hope that was enough to last me a few years.
    ^This is the passenger's side. For some reason this one has fared much better through the years. It got the same PB blast, and grease treatment.
    ^Relocated my Transmission cooler to a better spot for airflow.
    https://www.youtube.com/watch?v=F7nnxf1LVCc
    https://www.youtube.com/watch?v=rwRiJy4GLvo
    Below is a shot of completed trans move with as close to the same angle as I could get.20200701_104457.jpg 20200701_104346.jpg
    ^The rags are temporary vibration absorb-ers until @lsaami's OG trans cooler arrives.
    Before installing the new bumper I took a minute adjust my fender, and see if I could get the "door seam" to fall back into place.20200701_133544.jpg
    :yes:
    Below is a video of installation of new to me bumper.
    https://www.youtube.com/watch?v=XTvhO_zMq-4
    I also tried to pull out the bend in the lower bar of my deer guard.
    https://www.youtube.com/watch?v=K3VwGKpe2-o
    JasonC., Mountun Goat and FirstGenVol like this.
  2. Jul 5, 2020 at 4:56 PM
    Tundra2
    Noah
    Western Kentucky
    Next project on the agenda was the dash cam wiring kit. Started by removing all things on the head liner. Sun visors, lights, grab handles, trim pieces, top seat belt mounts, etc. Sorry, no pics of this process. 20200701_193120.jpg After removing all of that I tilted both front seats down, and carefully removed the headliner. 20200701_193240.jpg
    Once the headliner was out... I tested to make sure my new fuse block tap actually worked. In hindsight, I should have done this first. Regardless, it worked! Removed lower kick panel for better access during install.
    I took a break from crouching to work on the roof. Taped up the loose wires between roof, and head liner.
    Below is my set-up for pulling the cord through the dash. 24 inch long zip tie. Fed the zip-tie through the dash with ease!
    Once it was fed through, I started working on cable management. Followed the Original wiring harness up the drivers side pillar, and into the roof. Looped it around the wiring harness. Blue line is a close representation of cable route. RED arrow is the origin of the High mount stop light/cargo light. Wires run from there to the stop light in a slight "diagonal" line.20200705_120955.jpg
    After I had the cable set up the way I wanted with enough slack at both ends as strain relief, I taped the cable to the OEM harness in red locations.
    Started going back together with the head liner. Put headliner back in, and started putting trim, visors, etc back in. While all the electrical connections were exposed I touched them up with electrical grease. Took the lever apart on center dome light for lube service.
    The ball is held in place by a spring in the lever. Upon rotation of the lever to desired location ball will fall into the "track," or seam between the electrical connectors. The mounting screws are your ground. Without it mounted the "ON" function won't work. Only the door function. Do not be fooled by it, because I was. :D
    Do not misplace any of the three tabs for the rear of the liner. I misplaced one, and spent 20-ish minutes looking for it, before giving up. Continued with the install, and happened to find it. :rofl:
    Continued on with the install until all was in place. No pics of full headliner, but I do have a picture of the final product.20200702_181013.jpg
    Sweet-ness!​
    Mountun Goat likes this.
  3. Jul 5, 2020 at 5:11 PM
    Tundra2
    Noah
    Western Kentucky
    Next project! Tail light wiring, and rear breather relocation mod.
    Here is the kit I used ordered from the yotashop.com? It came with the correct hose barb for rear axle, hose clamp, and 8 feet of hose? with new breather already installed in the hose!
    :yes:
    Removed old breather, and installed the new hose barb. Applied lube to outside of barb for easing the hose on. :D Ran the hose up to the frame, and followed the rear wiring harness until I got to the end of the bed, after that I followed the wiring harness for drivers side tail light up into the tail light area. Before zip-tying in place I verified there was enough slack at both ends of the hose for up/down action of the axle. Turned the end of the hose down into the cavity pictured below.
    As a bonus, I replaced the drivers side tail light, and harness with a non cut one. SWEET!
    Old on left, and new on right!
  4. Jul 5, 2020 at 5:43 PM
    Tundra2
    Noah
    Western Kentucky
    Next project! OEM running boards (rb) Per @Professional Hand Model's recommendation I sanded them down with a fine sanding sponge, wiped the dust off with mineral spirits, and sprayed with Rust-o-leum bed liner for added traction.
    I crawled under the truck, and tapped all three holes per side at the front of the cab as prep work. M8X1.25 tap.
    It was tricky to say the least, but I did tap all 6 holes. :rofl:
    Dry fitting after that. Installed one bolt up front, and used two zip ties to hold up the other two brackets while I adjusted the aluminum mounting brackets to fit my trucks mounting points.
    When I had it looking mint I loosened the carriage bolts, and then drilled pilot holes for sheet metal screws. I have always had bad luck with self tapping screws so opted not to use them. In the above picture you can see the M8X1.25 threaded stud, and weld nut on the cab mount. 20200703_080449.jpg
    I had to make reinforcement brackets since I didn't have that rare critter. Pictured above is a sample of 3X3 square tubing left over from my bed repair. The pink area is the weld nut mentioned earlier.
    Here is my cutting set up. The center RB reinforcement bracket needed some extra cut off. Thats what the blue line is on the smaller piece.
    Once I had all 4 pieces cut, and painted I went back on with them. If I had a do-over... I would have cut a socket hole in the white location. Ended up using a stubby 13 mm wrench.
    For the center brackets I had to cut down the stubby wrench. Just wasn't stubby enough. :sawzall:
    Finally I had all of the RB reinforcement brackets on, and TIGHT! Gave her a test go with my 250 lb self.
  5. Jul 5, 2020 at 6:22 PM
    Tundra2
    Noah
    Western Kentucky
    Next job was painting my wheel well trim, and side mouldings. Below is a before picture.
    Taped everything up, and gave all the fixins' a good fine sanding, then a quick mineral spirits bath. 20200704_161433.jpg
    ^Used a interior body trim tool to get the tape BEHIND the wheel well trim.
    ^Painting after that.
    https://www.youtube.com/watch?v=scStjmqWRZM
    Oh, almost forgot to mention the bed caps.
    While I had the bed liner out, I did the mud flaps also. Had to modify the mounting points for rear right flap.20200703_201430.jpg 20200703_201516.jpg
  6. Jul 5, 2020 at 6:43 PM
    Tundra2
    Noah
    Western Kentucky
    Next job before my return to work tomorrow. Drivers door exterior handle was loose. No pics till the end of the job. Couldn't find my phone. Sorry.
    Pulled the door panel, and started looking around for mounting points. Found two 10mm bolts. Started to reach for my palm (thumb wheel) ratchet when I noticed a plastic "star" plug above the rear mounting bolt. Popped that off, and then got an extension with a socket. Gave her a 1/4 turn, and she was tight! excellence. While I had the door panel off I did another job, again inspired by @Professional Hand Model. LED door strip tied into the door marker light. Used two t-taps, two solder-n-seal connectors, one piece of heat shrink, a lighter, and some masking tape.
    Black heat shrink over the two solder/seal connectors in blue circle. I tried a few different ways to route the cable straught up into the door, but it just wasn't working out. (Pink Highlight) Ended up running it up the door a little, and then over behind the door panel. Tape in white location is temporary until I figure out something better.
    20200704_192858.jpg 20200704_225914.jpg20200704_202016.jpg 20200704_204202.jpg
  7. Jul 6, 2020 at 6:21 AM
    Hand Protectors
    Nice job! That light is amazing. Had a New Mercedes owner say they really liked this door light and how much better it was than theirs. :yes:
    Tundra2[OP] likes this.
  8. Jul 8, 2020 at 3:20 AM
    Tundra2
    Noah
    Western Kentucky
    You can really see the difference here.
    Never got around to doing the tailgate cap.
  9. Jul 13, 2020 at 2:32 AM
    Tundra2
    Noah
    Western Kentucky
    Just verified voltage range was in spec for MAF from wiring harness. :thumbsup:
    Auto hold function is SUPER sweet for a guy like me. Not an extra pair of hands in sight. Lol Take your reading and then DMM will continue to show reading. Supa nice.
    Old OEM MAF resistance test.
    At ambient temp the specc'd range is 2.2-2.7 K-ohms
    Pass side "star wheel" peephole boot.
    Drivers side shoe inspection boot.
    I looked all over the internets for a generic plug. Couldn't find the right things. Finally broke down, and ordered from the stealer.
    Daily first gen thread link 1
    Daily first gen thread link 2
  10. Jul 13, 2020 at 2:33 AM
    Tundra2
    Noah
    Western Kentucky
    Replaced PCV valve, grommet, and stealership hose. All were rock hard.
    Replaced all these cracked, rock hard vacuum lines with thick wall silicone tubing. Link to website.
    Replaced my tired, and well used injectors with @dirtydeeds 12 hole injectors. No review on those yet. I was worried about fitment, and leaks because the new ones from Keith looked radically different than these. (See pics)
    I went ALL the way back together with the plenum (top/bottom) started putting my tools up, and found this.
    I reached out to @empty_lord to hypothesize where it lives. He told me "Lower plenum bolt in the center." I'll be damned if he wasn't 110% correct. Got her fixed up, and torqued down.
    All lines in green were replaced. I think I will hit up the stealership for line in pink. Part of PCV system from drivers side VC to intake hose.
    Did a 5S activity on my plug wires. Organized them, and ran them cleanly.
    Here is a video of the first start up after 2nd round of work was completed.
    https://youtu.be/CU07P0y1Ous
    I couldn't find my tri-pod to make a decent video for you all. I'm sorry.
  11. Jul 13, 2020 at 6:52 AM
    Tundra2
    Noah
    Western Kentucky
    Here is my dirty throttle body. Didn't clean this up. That is a project for another time.
  12. Jul 13, 2020 at 6:56 AM
    Tundra2
    Noah
    Western Kentucky
    Broken wire loom protector.
  13. Jul 20, 2020 at 8:05 AM
    Tundra2
    Noah
    Western Kentucky
  14. Jul 20, 2020 at 8:46 AM
    Tundra2
    Noah
    Western Kentucky
    ATF service. 315,500 miles. Last known service was around 90k miles. Old fluid pic posted below. 20200720_102450.jpg
    I used the same bucket to catch the ATF fluid as I did the engine oil. I suspect the engine oil residue made the ATF fluid look darker than when it was actually in the transmission. When it was draining it looked cloudy, and dark red. Torqued drain plug to 15 Ft. Lbs. Per FSM.
    I carefully measured out 16 cups (4 quarts/1 gallon) and slowly started pouring it into the dipstick tube. I added the large funnel to my little funnel because my measuring cup was allowing fluid to run down the side of the cup.
    NG.​
    ^^^Added this amount to compensate for my spillage.
    I noticed that the accuracy of the dipstick depended just as much on HOW you pull it out as much as the flat level surface the truck sits on.
    Daily 1st gen link
  15. Jul 26, 2020 at 1:16 PM
    Hand Protectors
    Hows your Manifold Gasket leak that you thought you heard? The throttle body looks nasty!
  16. Jul 26, 2020 at 2:03 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    What exactly is this that you did here? Anything that can quiet the cab is of interest to me.
    Tundra2[QUOTED][OP] likes this.
  17. Jul 26, 2020 at 3:24 PM
    Tundra2
    Noah
    Western Kentucky
    After some investigation I have determined that I do NOT have a manifold leak. I do indeed have a leak somewhere, but each time I investigate it seems like the leak "moves" to the firewall or on drivers side of the engine.
    Throttle body cleaning is on the agenda. I just haven't gotten to it yet.
    Installed closed cell foam backer rod between the dash, and the windshield. It keeps the dash from squeaking.
    Be easy pushing it in the crevice if this is something you do.
    robabeatle[QUOTED] likes this.
  18. Jul 26, 2020 at 3:29 PM
    robabeatle
    AZ
    So did the ccf work for you here?
  19. Jul 26, 2020 at 3:59 PM
    #49
    Tundra2
    Noah
    Western Kentucky
    Yes. Absolutely. The only reason I broke my windshield while doing this was there was a piece of gum over the vin plate. I was trying to get it out and made a $270 boo-boo
  20. Jul 26, 2020 at 4:02 PM
    #50
    robabeatle
    AZ
    Ouch!
  21. Jul 26, 2020 at 8:23 PM
    #51
    Tundra2
    Noah
    Western Kentucky
    Out of curiosity I pulled the lock button to see how it worked. Lubed up this area with Dielectric grease.
    20200726_074817.jpg Removed the old green led, and installed the new white crisp LED.
    You can see the difference between foglight button, and window switch now. Major improvements.
  22. Jul 26, 2020 at 8:40 PM
    #52
    Tundra2
    Noah
    Western Kentucky
    Replaced my OEM ignition coils with new Denso, and installed new TOY OEM plug wires. Checked resistance, and all 3 coils, and plug wires were in spec.
    For coil torque I torqued mine to 10 ft.lbf because my TW doesn't go that low.
    Removed spark plugs, and inspected. Torqued back down to 14 ft.lbf
    Pass side front to back is cyl 1, 3, and 5 at rear.
    Drivers side front to back is Cylinder 2, 4, and 6 at the rear. 20200726_204129.jpg 20200726_204351.jpg 20200726_204601.jpg
    The pictures make the spark plug threads look more dirty than they really are. Wiped the threads with a dry cloth, reinstalled, and torqued down.
    New toy plug wires came with all clips, and proper heat shielding. Installed all new clips.
    Also, added a little flavor!
  23. Jul 26, 2020 at 8:52 PM
    #53
    Tundra2
    Noah
    Western Kentucky
    Old coils! I had 316,238 miles on these!
    Resistance checking the old ignition coils. There are two methods to check the resistance value of my ignition coils.
    According to the FSM temperatures are as listed below.
    "Cold" is 14°F to 122°F.
    "Hot" is 122°F to 212°F.
    All testing below will be "cold."​
    I'll start with Cylinder 1 coil.
    Primary coil Test A: 2.5Ω
    Secondary coil (plug wire) Test B: 1.352 MΩ
    Cylinder 3 coil.
    Primary coil Test A: 2.6 Ω
    Secondary coil (plug wire) Test B: 1.209 MΩ
    Cylinder 5 coil.
    Primary coil Test A: 1.8Ω
    Secondary coil (plug wire) Test B: 0.780MΩ
    Ohmed out roughly 4 times with each test. Readings were consistently around the values listed above on results.
  24. Jul 27, 2020 at 3:52 PM
    #54
    Hand Protectors
    Coils were way off. Good job.
  25. Aug 2, 2020 at 9:09 PM
    #55
    Tundra2
    Noah
    Western Kentucky
    Under hood led lighting. August 2nd, 2020.
    Pulled the hood off to make working easier.
    Four 12 mm bolts, the gas struts, the washer nozzle hose, and the hood is free as a bird.
    Laid the hood upside down on my bed.
    Prepped all my tools, and plugged in my soldering iron. Cleaned all surfaces with 100% isopropyl alcohol, and then wiped away all the dirty juice left behind. Wiped again with a alcohol rag. Wiped again with a dry rag.
    Laid the first run of 3M VHB tape down (gray under strip), and then laid the first run of lights down on that.
    Spooged some flex shot (FS) under neath the heat shrink, and then shrunk it down around the connections using a map gas torch.
    Used a razor knife to carefully seperate the gel water proofing from the little white conductor strips. Used my soldering iron to "cut" the gel because the razor knife couldn't do it! "Tinned" the copper connections as seen in the above image. A tricky task, but doable!
    Soldered in my jumper wires. A strong connection! I tested a few of them, and tugged on them. Felt real good!
    This is a different spot than the jumper wire image above, but this is what the finished connection looks like. Heat shrink over the jumper wires, with FS in that too. Heat shrink over the actual connections, and FS in those also. Shrunk the heat shrink down until a decent amount of FS spooged out. Wiped away excess.
    Expanded view of the above water proofing.
    Kept at it until I was all the way around the hood. Pictured above is a mid-project image. In the white circle you can see my jumper test wires I soldered in at the end, and touched them off to my M12 milwaukee battery to test each new addition. The green arrows show you the heat shrink underneath the light strip. I did not finish water proofing until I was sure the next strip worked. I chose to run the light strip in front of the hood seal. (Blue arrows.) Couple ideas behind that. If the front strip ever comes off while I'm driving, I'm hoping that the hood seal, and the radiator will keep it out of my fan.
    Almost done! I cut that heat shrink long enough to cover both jumper wires, and connections. FS inside the heat shrink, and then heated up!
    Blue locations are heat shrink for the previous set of jumpers. Green location is where I soldered on my power wire.
    Finished soldering test pic. This dude is SERIOUSLY bright. :cool: removed my test jumper wires here since they were no longer needed.
    Mounted the hood, and aligned it back in. You can see my "alignment" marks on the hinges.
    Cleaned up the hood with alcohol using the same method earlier. Used zipties, and stickies to keep it organized. A better shot of my "alignment" marks too.
    A lot going on in this image.
    In blue, more stickies with zip-ties. In green, my ground. In red, my toggle switch JB welded to the fuse box cover for ease of access. In pink, my connections. One side is heat shrinked, and the other isn't. Deciding whether I want to get water proof connectors.
    https://youtu.be/tjbv-BKwB6k
    Well worth my time!
    Editing in a shot from about 35 yards away.
    1st gen lunch table prototype link
    Mr.bee, JasonC., BubbaW and 4 others like this.
  26. Aug 2, 2020 at 9:53 PM
    #56
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Noice. :popcorn:
  27. Aug 2, 2020 at 9:54 PM
    #57
    Tundra2
    Noah
    Western Kentucky
    I think I'll go home, and tinker with my new sunvisors from @lsaami's parts truck that have the built in light from the LIMITED trim
    After I have a small celebratory meal, of course.
    Lil Steve[QUOTED] likes this.
  28. Aug 3, 2020 at 12:33 AM
    #58
    BubbaTun1794
    BubbaTun1794 New Member
    '16 Tundra 1794
    NICE
  29. Aug 3, 2020 at 1:49 AM
    #59
    Tundra2
    Noah
    Western Kentucky
    Thank you! Lots of love has went into this.
    Fish River Tundra likes this.
  30. Aug 25, 2020 at 8:41 PM
    #60
    Fish River Tundra
    Fish River Tundra New Member
    JD
    Nashville
    ‘16 Platinum
    Just found this thread and couldn’t stop reading it. Way to save and bring this truck back to its youth. Congrats on all the work so far
