Tundra Won't Start
Discussion in '2.5 Gen Tundras (2014-2021)' started by Thattundradude, Jun 7, 2018.
  1. Jun 11, 2018 at 7:45 PM
    #61
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    There's half a tank of fuel in there but according to the carfax the accident happened in March. It's pretty old fuel in there.
  2. Jun 11, 2018 at 10:39 PM
    #62
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    Something should cutoff the fuel in an accident but I'm not an expert.
    Here is what I found in my owners manual:
    'Fuel pump shut off system
    To minimize the risk of fuel leakage when the engine stalls or
    when an airbag inflates upon collision, the fuel pump shut off
    system stops supply of fuel to the engine.
    Follow the procedure below to restart the engine after the system is
    activated.
    Turn the engine switch to the “ACC” or “LOCK” position.
    Restart the engine.'
    The easiest thing to do would be disconnect the fuel line where is comes into the engine and see if it is pumping fuel by putting it into a cup or something.
    I also noted your check engine light was on. Have you put a reader on it to see what it says?
  3. Jun 12, 2018 at 2:15 AM
    #63
    Thattundradude
    Platinum Tundra
    Lifted
    Yep. Only code on it was a stability malfunction
  4. Jun 12, 2018 at 2:16 AM
    #64
    Thattundradude
    Platinum Tundra
    Lifted
    Where is the fuel line I couldn't find it
  5. Jun 12, 2018 at 2:24 AM
    #65
    Thattundradude
    Platinum Tundra
    Lifted
    Btw this is a flex fuel truck
  6. Jun 12, 2018 at 2:39 AM
    #66
    Adam New Member
    upload_2018-6-12_4-38-41.jpgthe light is on in the second video when it shouldn't be. Is this your video, or something that you just found and threw up here?
  7. Jun 12, 2018 at 3:22 AM
    #67
    Thattundradude
    Platinum Tundra
    Lifted
    That's from YouTube. I'll try to make a video of mine next time I go
  8. Jun 12, 2018 at 3:54 AM
    #68
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    I would not be too worried OP.If it ran,even only briefly I would tend to believe that something simple is holding it back.As others have suggested you will need to confirm that the truck is getting proper fuel delivery and that it is not being held back by a safety feature due to the collision.
    Thattundradude[OP] and 15whtrd like this.
  9. Jun 12, 2018 at 7:57 AM
    #69
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Seems like electrical gremlins as you mentioned battery problems. I’d put a new battery. BUT, also when doing that. Make sure the battery is disconnected for at least 30 minutes to assure the residual charges on the capacitors have drained off and computers will start fresh.
    Have you been monitoring the voltage? Is is above 12.8 volts? Does it drop overnight ? Does it continue to go down?
    I had a Ford that would drain the battery due to water in the fuse box/ electrical box. It was enough of the drain to kill the battery after a few days, yes really. Owning a ford you learn a lot about trouble shooting problems.. ended up being a leaky windshield.
    More details that you may not want to do if not electrical inclined. The true test is to measure the current on the battery (negative terminal) with the engine off, doors shut, lights off. It should be very low, I’m not sure on a Tundra but my old ford it was to be about 40 ma, the drop to 20 amp. When my ford had the electrical problem it was on the order of 400 ma, enough to kill off a battery in a couple days of being parked.
    Watt maker likes this.
  10. Jun 12, 2018 at 1:21 PM
    #70
    ZPMAN
    Minnesota
    If this helps you out a little, the red arrows pointing to fuel lines hook ups, that are attached to injector rail. Not sure but could need a special tool to disconnect.
    Thattundradude[OP] likes this.
  11. Jun 12, 2018 at 2:30 PM
    #71
    Thattundradude
    Platinum Tundra
    Lifted
    Thanks for that. I'll look into the issue next week when I get back on it
  12. Jun 12, 2018 at 2:32 PM
    #72
    ZPMAN
    Minnesota
    Were all the airbags intact? I can also ask my brother about a fuel shut off if any.
  13. Jun 12, 2018 at 3:14 PM
    #73
    Thattundradude
    Platinum Tundra
    Lifted
    The driver side airbag is deployed and the left roof airbag.
  14. Jun 12, 2018 at 3:15 PM
    #74
    Not sure if it'll start when airbags are deployed as it thinks it was (is) in an accident. :notsure:
  15. Jun 12, 2018 at 3:17 PM
    #75
    Thattundradude
    Platinum Tundra
    Lifted
    That might not have to do with it. I've bought a few cars with deployed airbags and they all turned on.
    T-Rex266[QUOTED] likes this.
  16. Jun 12, 2018 at 3:32 PM
    #76
    rds95991
    rds95991 New Member
    I hope when you figure this out you will share what the issue was. If it ran for a second or so and stopped, I would be inclined to believe it is a fuel issue. If the tank had methanol or ethanol and sat, it is hydroscopic so water may be in the tank, filter, and fuel lines. Could be the fuel pump, blocked filter or lines.
    God I miss the old days when you could actually work on cars. I remember sitting in engine bays and working on an engine.
  17. Jun 13, 2018 at 1:48 PM
    #77
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Wife had a ford escort that I had slammed the door hard enough to trip the fuel cutoff switch. reseting it was easy on I figured out what it was.
  18. Jun 26, 2018 at 7:02 PM
    #78
    Thattundradude
    Platinum Tundra
    Lifted
    FIXED. Fuel tank had a big ole hole in it. Put a new tank and its working now. New battery is next.
    Watt maker and equin like this.
