Tundra Won't Start
Discussion in '2.5 Gen Tundras (2014-2021)' started by Thattundradude, Jun 7, 2018.
  1. Jun 7, 2018 at 9:14 PM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hi all. 1st time tundra owner. I've been trying to buy one for the past 2 years. Well I finally got one and it won't start. It's a 2014 5.7 Tundra.It cranks and cranks but won't turn over. It was purchased from an auction. It probably started over there because it was listed as starts and not "wont start" or "run and drive" When it came in I tried to start it but all I got was clicking from the engine, dead battery probably, the key wouldn't come out either. Next I hooked up a jumper and that's when it started doing the cranking only.
    Like this
    https://youtu.be/a5RAHRwRm2A
    https://youtu.be/QiEoINNDMyA
  2. Jun 7, 2018 at 9:21 PM
    Welcome from Texas, bad battery? Fuel pump? You bought from an auction, flood damage , salvaged title :notsure: hope you can get it going
    mudslinger79 likes this.
  3. Jun 7, 2018 at 9:22 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Got it from IAAI auction?
  4. Jun 7, 2018 at 9:24 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Yep
  5. Jun 7, 2018 at 9:24 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I have a spare battery that I'm going to try tomorrow. It has collision damage but this is the main issue right now
  6. Jun 7, 2018 at 9:26 PM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    If it doesn’t say “vehicle won’t start” then it’s probably something simple for sitting in the lot for long.
  7. Jun 7, 2018 at 9:29 PM
    15whtrd
    15whtrd Mr. Blonde
    Kill switch somewhere? Non chipped key?
  8. Jun 7, 2018 at 9:30 PM
    How did I miss that?!?!?
    15whtrd[QUOTED] likes this.
  9. Jun 7, 2018 at 9:30 PM
    Thattundradude
    Platinum Tundra
    Lifted
    It's the standard key fob and remote you get with the platinum tundra.
  10. Jun 7, 2018 at 9:31 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Yeah the pictures were taken in May, but its probably been at the location for longer than that
  11. Jun 7, 2018 at 9:35 PM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Also depends on where was it hit. Mine had the same issue turned out the engine bay fuse box was bad. Got it for $200 from junkyard and it worked.
  12. Jun 7, 2018 at 9:38 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Its hit from the front right.
  13. Jun 7, 2018 at 9:39 PM
    Thattundradude
    Platinum Tundra
    Lifted
    It also has suspension damage. The steering wheel is straight but the left wheel was still turned slightly to the left and the right wheel was straight
  14. Jun 7, 2018 at 9:40 PM
    How much you pay if ya don't mind me asking
  15. Jun 7, 2018 at 9:40 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I'm at 15500 right now.
  16. Jun 7, 2018 at 9:41 PM
    And then to fix what ya need to do to it, u didn't want a new one?
  17. Jun 7, 2018 at 9:44 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I'm probably looking at around 18 with repairs. They were selling 22+ at dealer auctions, plus I wanted a platinum that was lifted. This one has a fabtech lift. Platinum ones are going 25+ clean titles.
  18. Jun 8, 2018 at 2:59 AM
    Adam New Member
    I had this happen to me before. Used a key that had worked in the past, but had sat on the key holder inside for like 1.5 years. Was going to let a friend borrow the truck and it did exactly that. Turned out the key had somehow lost its pairing to the ignition. IDK how that happens, but the toyota dealer towed it in, reprogrammed and was on the road. I had the platinum warranty so it payed for the tow. I would have really been pissed if i needed to because all i needed to do is use my other key to start and it woulda worked.
    B737 and 15whtrd like this.
  19. Jun 8, 2018 at 11:23 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    i agree with adam, i think key is suspect.
    I have had this problem 3 times in my 2015, and its always self corrected. i have chalked it up to my directed remote start / xpresskit. but it makes sense that its most likely a problem in the fob / immobilizer.
  20. Jun 8, 2018 at 11:26 AM
    Thattundradude
    Platinum Tundra
    Lifted
    I'll look into that. First I'm going to have it scanned to see if there's any trouble code that might be causing the issue.
  21. Jun 8, 2018 at 11:28 AM
    B737
    Jersey Shore
    if you have the second key i would keep that close by if this happens again to test it out
  22. Jun 8, 2018 at 11:37 AM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    Check your fuses.
  23. Jun 8, 2018 at 12:13 PM
    Thattundradude
    Platinum Tundra
    Lifted
    this was purchased at an auction and it only came with 1 key like most cars there .
  24. Jun 8, 2018 at 12:13 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Which fuses should I check?
  25. Jun 8, 2018 at 12:19 PM
    B737
    Jersey Shore
    ah ok, i understand i missed that above. i would have a second key made up, prob wont be more than $100 at dealer.
    i dont think its "a fuse"... what "fuse" would cause intermittent starting?? fuse is either blown or its not.
  26. Jun 8, 2018 at 12:26 PM
    15whtrd
    15whtrd Mr. Blonde
    The dealer should be able to make you a chipped key with your Vin number.
  27. Jun 8, 2018 at 12:45 PM
    Thattundradude
    Platinum Tundra
    Lifted
    I can't go to a locksmith and have a key programmed?
  28. Jun 8, 2018 at 12:48 PM
    HUTCHJ
    J
    Anything related to fuel.
    Also, if it has an inertia switch, check that depending on how bad the accident was.
  29. Jun 8, 2018 at 12:58 PM
    Some can. Just call around and they can come to you.
  30. Jun 9, 2018 at 3:45 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    I have a 2nd gen but there is a red security light that flashes until a working transponder key is inserted into the ignition switch. Light goes off if key is good. I'm sure there is something similar on 3rd gen trucks.
