Tundra Total Taillight Kits - Hotshot Offroad
Discussion in '2.5 Gen Tundras (2014-2021)' started by memario1214, Oct 13, 2021.
  1. Sep 5, 2023 at 3:34 PM
    #691
    memario1214
    memario1214 [OP] Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    No bulb issues whatsoever in terms of excess heat. They manage it pretty well. :thumbsup:
  2. Sep 5, 2023 at 4:16 PM
    #692
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    Awesome thanks. Placed my order today:thumbsup:
  3. Sep 5, 2023 at 4:17 PM
    #693
    memario1214
    Colton
    Missoula, MT
    Thanks! We should be able to have them out tomorrow.
    Doxiedad[QUOTED] likes this.
  4. Sep 15, 2023 at 2:26 PM
    #694
    Doxiedad
    James
    Charleston, SC
    I installed mine today and had a little bit of hyper flash, but it went away?? Where do you plug the resistor into? Is it the spare little dongle coming off the switchback plug?
  5. Sep 15, 2023 at 2:27 PM
    #695
    memario1214
    Colton
    Missoula, MT
    BINGO. That resistor plugs into the extra little dongle hanging from the middle, switchback bulb. Make sure to mount the resistor itself to a metal surface!
  6. Sep 15, 2023 at 5:04 PM
    #696
    Doxiedad
    James
    Charleston, SC
    Awesome. Thanks for quick replies, I mounted it to the body of the bed inside the housing after I cleaned a spot. Loving these lights!!!
    jammer and RobertD like this.
  7. Oct 17, 2023 at 9:12 PM
    #697
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Edit: I wanted a little more on the low brightness for winter time so I mechanically removed any tint on outside diameters using a low speed felt bob. It's easy to melt the plastic so it was just the plain bob with no grit and only about 5k rpm or less, and almost no pressure. This leaves the area inside the endcap tinted and that's all. It worked great. The little tint in the cap just takes the edge off but they still perform awesome.
    sorry memorio I think I was born with the tinker gene, your product is still my favorite mod
    original:
    I'm happy with my latest experiment with the red bulbs. Started by removing and cleaning the bulb globes with alcohol followed by a single coat of VHT nite shade. That by itself was too dark, but by using a cotton pad with alcohol and squeezing and rotating the globe in the fingers the majority of it flakes off with a bit of force. What's left is a surprisingly even light smoked tint. Low brightness setting is now comparable to OEM lows, and high setting is still somewhat brighter than OEM highs and in every direction not just the narrow reflected band of the stock bulb. The contrast between the two is very nice. However it's not dazzling at all anymore in the middle of the night. As a plus the tinge of pink the bulbs had is totally gone. It's all very red. Plus I don't need to worry about 3d printed caps anymore. Thank heaven. I hate printing in ASA; it clogs up the print head when I switch back to PLA and it needs a lot of room ventilation.
    The turn/reverse bulbs are untouched as they aren't too bright from the rear.
  8. Nov 16, 2023 at 11:14 AM
    #698
    Ordered the bulbs and controllers for my reverse/turn signals to upgrade them from the standard kit to the Extreme kit. FYI, the only difference between the 2 kits is the switchback bulb output. The standard bulb is 900 lumen reverse, 500 lumen amber. The extreme is 1000 lumen reverse, 1400 lumen amber. The brake/tail red bulbs are 900 lumens for both kits.
    memario1214[OP] likes this.
  9. Nov 23, 2023 at 9:06 PM
    #699
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    I finally installed mine, and I’m really happy. I tried taking some photos with only one side done, but they really don’t do it justice - everything just gets washed out in red.
    But there was definitely a difference between the before and after! I’m not worried about someone not seeing my brake lights now.
    endagon, nobodyintexas and RobertD like this.
  10. Nov 24, 2023 at 9:01 AM
    #700
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    I will never understand why Toyota intentionally designed the tail lamp assemblies so they look like half the bulbs are burned out
  11. Nov 24, 2023 at 9:02 AM
    #701
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    They were just trying to imitate Chevys I think. Those always have a burnt out bulb or two.
  12. Nov 24, 2023 at 9:34 AM
    #702
    memario1214
    Colton
    Missoula, MT
    How true this is.
    TRDFerguson[QUOTED] likes this.
  13. Nov 24, 2023 at 3:08 PM
    #703
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    I think the response time is worth as much as the visibility. Other drivers see them light up at least a half tinder swipe faster than the filament bulbs. Well, at least 90 ms faster to full brightness. That's an extra 10 feet at highway speeds.
    Lazy 3rd light at 1/5 playback speed
  14. Nov 25, 2023 at 2:53 PM
    #704
    Mine don't do that...there's a fix for that.
  15. Nov 26, 2023 at 2:26 PM
    #705
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    For anyone doubting the power output of these check out the pic I snapped sitting at the red light. Passenger behind me has his hand over his eyes they’re so bright! Look at all the street signs etc lit up behind me also! That not from traffic, that’s my tail lights setting everything on fire! Lol These things Rock! @memario1214 thanks again Colton.
  16. May 26, 2024 at 7:31 PM
    #706
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    So, I am on the fence on this kit and whether it is something I want as a package or try piece it together.
    The pictures and light output upgrade is obvious for red bulbs.
    Hottails- OEM sealed connections (Big +)
    I am not trying to blind the person behind me with my brake lights.
    Main focus is on reverse lighting and maximizing stock locations first.
    Switchback is cool, but not a need.
    switching from a filament bulb to something better / brighter seems logical (although many options available)
    V6 extreme reverse kit white 3000lm (yea not exactly true)$140
    V6 extreme switchback- white-1000lm /amber 1400lm $200
    V6 Switchback white-900lm / Amber 500 lm $150
    Hottails- white-900lm / Amber 500 lm
    Is there an option to upgrade hottails to the extreme components?
    Will extreme be added to options in future?
    Are custom options available?
    Are people who purchased happy with reverse lighting performance over stock?
    Jumping from $140-> $360 is a big price point change.
    Extreme would be another $50 (msrp) jump but at that point would truely be the ultimate setup.
    would appreciate feedback, and suggestions based on what i am trying to accomplish.
    Thanks,
    Mark
  17. May 26, 2024 at 7:45 PM
    #707
    The red bulbs in the Hottails kits are all extreme bulbs. The reverse/switchback can be upgraded to the extreme bulbs.
  18. May 27, 2024 at 8:47 AM
    #708
    memario1214
    Colton
    Missoula, MT
    I can happily spec out a "full extreme" version for you. That said, what you'll notice is that the boost in power is primarily at the amber portion of the bulb, and not the reverse. I think that you'll find that if you did a poll here that the turn signal is plenty bright in the standard hottails kits thus the reason why we don't even offer it!
    In a perfect world, what would your functionality look like? Do you still want the turn signal where it located stock? If so, we could just build you out a setup where we upgrade your bulbs all around :notsure:
  19. May 27, 2024 at 8:58 AM
    #709
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    I have the full monty and its the best thing ive done to the truck. Reverse lights are stupid bright as are the brake and turn signals,toyota should have kept the turn signals amber like the prior generation had. Best mod for safety you could do.Everything is top notch. :thumbsup:
    What the!?, Doxiedad and Tundra234 like this.
  20. May 27, 2024 at 10:38 AM
    #710
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    I will also agree that the turn signals are plenty bright - no need to go brighter in my opinion. Very happy with the kit!
    I actually added extra lights to my bumper for backup lights (what can I say, camping in the middle of nowhere), so hard for me to comment on just the backup lights in the kit. They seem quite bright though. :thumbsup:
    Whatever you decide on, I know @memario1214 will take care of you and make sure it works for you.
  21. Aug 16, 2024 at 8:15 AM
    #711
    @memario1214 I discovered this earlier this morning. My left side lower bulb is stuck in "brake pressed" mode. Bad bulb possibly? I think I still have one of my original V6's that I can slave in and see what happens. About 2 months ago I started the truck and turned on the parking lights. When they came on, that same side was in "brake pressed" mode for a second or 2 before it switched to normal. I didn't notice at the time if it was just the lower bulb or not. Passenger side is fine.
  22. Aug 16, 2024 at 8:24 AM
    #712
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I might be wrong and @memario1214 can whoop my ass if I am wrong, but honestly, the hot tails set is plenty bright, and don't forget, there is a hyper-flash rely in the set that I am not sure if VLED has?
    But yea, one of the best mod I ever had, along with the hitch-pod, I rarely have people tail me, one brake light later it is two car's length until the next idiot.
    nobodyintexas and WFD473 like this.
  23. Sep 20, 2024 at 5:58 PM
    #713
    AthenaOffroad
    AthenaOffroad YouTube wannabe
    Niko
    2014 Blue Ribbon Metallic Tundra DC SR5
    Do you have sales on these?
  24. Sep 20, 2024 at 6:03 PM
    #714
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    He’s always got free shipping and no sales tax. Can’t beat it.
  25. Sep 21, 2024 at 4:05 AM
    #715
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I have the same set setup, hitch pod too
    it’s damn bright
    It’s the best set up
    the turn signal is awesomely bright
    My son has similar on his 15 4R.
  26. Sep 21, 2024 at 5:38 AM
    #716
    Doxiedad
    James
    Charleston, SC
    I've had mine installed for a year now, and still very happy with the purchase. No second guessing like i normally have. Noticeably brighter and the backup lights are much better. I had the Hhitchpod for a while, but I tow about once a week on average and got tired of changing it out for the hitch honestly.
  27. Nov 24, 2024 at 7:42 AM
    #717
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    @memario1214 Is there an option to purchase just the harness? I dont really want the vleds bulb. I just want the look.
    Thanks
  28. Nov 24, 2024 at 7:49 AM
    #718
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The harness doesn’t work that way. The connectors plug into the factory light connections and then have 3 or 4 pin round connectors that work with the VLEDs.
    memario1214[OP] and 1lowlife like this.
  29. Nov 24, 2024 at 7:51 AM
    #719
    BrandonL812
    Brandon
    Darn. I was hoping it would.
    Anyway, when you opened the oem tail lamp to paint the inside, what paint did you use? Satin black? Did you baked the lamps then pry open? I liked how you did it. Smoke just enough.
  30. Nov 24, 2024 at 7:56 AM
    #720
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah I used satin black for the paint - but to open up the tails, you actually have to cut around the perimeter with a dremel or a fancy ultrasonic knife like @memario1214 has. They don’t bake apart like the headlights do, so it can get a little difficult and tedious. I think I saw someone post a factory tail clone that was blacked out though, which I would probably go with instead of cracking open another set. I’ll see if I can find a link.
