Tundra Maintenance Guide
Discussion in 'General Tundra Discussion' started by csuviper, Feb 16, 2014.
  1. Feb 13, 2017 at 8:45 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    I'm still not sure about the following intervals:
    Front diff
    Rear diff
    Transfer case
    Transmission
    Does toyota really mean to say that you never need to replace these fluids if you don't tow or haul??? Anybody else thought about this?
    The diffs and transfer case are super easy and cheap, so I did the first drain and fill at 25,000k, and will do every 30k thereafter since I don't tow or haul much. I will plan to do transmission drain and fill every 60k.
    Kevsfun2021 likes this.
  2. Feb 18, 2017 at 3:01 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Even if Toyota said that you never had to change fluid CHANGE IT! Manufacturers have to keep the posted yearly cost of maintenance low so they look good. It would be crazy to think your transmission fluid or diff never needs changed. Also you never see a recommended interval to change power steering fluid on any vehicle. I flush my diffs, transfer case and trans every 15k and coolant, power steering and brake fluid every 30k. my vehicles all last with minor repairs throughout their lifetime. I tow a 7500lb camper with my tundra so driveline flushes every 15k if you don't tow do them all every 30k with synthetic fluids, you wont regret it.
    Shooter8571, Barrett50 and Rex Kramer like this.
  3. May 17, 2017 at 10:29 AM
    catchjon1
    catchjon1 New Member
    Fort Worth TX
    '15 Tundra stock max cab 5.7 v8 black on grey
    anyone know what the tire rotation interval is? Just checked the manual and they do not have that info....
  4. May 17, 2017 at 10:35 AM
    PMG
    PMG New Member
    It's quoted 2 posts above... 5k
  5. May 17, 2017 at 10:36 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Mine came with a maintenance manual and it says every 5000 miles. The dealership claimed to have done it every 5000 but when I did it I had to get behind each wheel with a wood block and a 5lb hammer to beat them loose.
  6. May 17, 2017 at 10:38 AM
    catchjon1
    Fort Worth TX
    With the manuals now posted online, were you able to find the missing info? I couldn't locate anything.
    I've personally never retorqed the shaft. Any non-tower mechanics out here have input?
  7. May 17, 2017 at 10:38 AM
    catchjon1
    Fort Worth TX
    Does anyone know the torq specs to the wheels?
  8. May 17, 2017 at 10:39 AM
    catchjon1
    Fort Worth TX
    I guess its time to shop for a chiltons manual.
  9. May 17, 2017 at 10:39 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Aluminum wheel: 97 ft lbs
    Steel wheel: 154 ft lbs
    BBTundra, TOYOTRD8 and Tundratoofun like this.
  10. May 17, 2017 at 7:20 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Are you serious? 154????
    I think my 35's are torqued at 110......
  11. May 20, 2017 at 9:03 AM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    I would say these aren't so much Toyota recommendations as tire manufacturer. I know where I work for any type of tire warranty the customers have to be able to present proof of recommended tire rotation intervals. Continental-5k, Michelin-7,5k, Pirelli-3k and so on.
  12. Feb 21, 2018 at 4:24 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Anyone know the torque specs for the prop/shaft bolts?
  13. Feb 21, 2018 at 9:16 PM
    csuviper
    Broomfield, CO
  14. Mar 3, 2019 at 12:01 PM
    yotaguy1212
    yotaguy1212 New Member
    07 tundra doublecab
    2in level, 275x65x20
    Sorry for silly question, when do we have to change water pump, tensioner etc. thanks 2 nd gen tundra
  15. Mar 18, 2019 at 8:21 PM
    Snowboard Tundra
    Snowboard Tundra New Member
    I am approaching 100k miles, thinking of lumping all the following into one service.
    • Replace transmission oil every 60,000 miles if towing, 90,000 miles if not
    • Replace transfer case oil every 30,000 miles
    • Replace differential oil every 30,000 miles
    • Replace engine coolant every 60,000-100,000 miles
    • Replace spark plugs every 120,000 miles
    • Replace brake fluid every 2 to 3 years or 24,000 - 36,000 miles.
    Shooter8571 and KickupTruck like this.
  16. Mar 19, 2019 at 7:30 PM
    yotaguy1212
    07 tundra doublecab
  17. Dec 9, 2019 at 6:08 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Yup every 5k or 6 months
  18. Jun 4, 2020 at 7:55 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Anyone have experience / words of wisdom on how to lubricate and re-torque the propeller shaft? I’ve never done that and don’t know what I’m looking for — any pics / videos would be greatly appreciated.
    Crews44 and Vr0ck like this.
  19. Jul 15, 2020 at 2:45 PM
    #49
    ErSlickEr
    ErSlickEr New Member
    2018 MGM Tundra 4x4 CrewMax 5.7L FFV Limited
    I have a 2018 4x4 MGM 5.8L Tundra FFV Limited and can tell you that my tundra does not have any zerk fittings on the Front Propeller shaft or the Rear Propeller shaft. So No Zerk Greasing!
    I did retorque them as listed below:
    Rear propeller shaft (17mm socket needed to torque nut to 52 ft lbs) 4 nuts on the front and 4 nuts on the rear of the Rear Propeller Shaft
    Front propeller shaft (14mm socket needed to torque nut to 59 ft lbs) 4 nuts on the front and 4 nuts on the rear of the Front Propeller Shaft
    I highly suggest using 3/8" Torque wrench. Also suggest having both short and long sockets and 3/8" extension bar handy. It will help with accessing nuts located in tough accessible positions.
    Also for all the people having a 4x4, I suggest putting the truck in 4Hi Mode and then park it and then go under to work on the shafts. Otherwise, when you try to torque the front propeller shaft, it will just rotate with force. (Ask me how I know?)]
    Also make sure to engage the parking brakes and then dis-engage them once you are done.
    Also suggest lifting the vehicle to better access the bottom if you are on the heavier end. Otherwise you should be able to slide under easily.
    The correct way to re-torque is to loosen the nut one or two thread rounds. Then hand tight it. Then tighten it with proper torque settings. - I know there can be an argument to just re-torque it directly but I followed this procedure.
    Also, for those who can accidentally mess up. I am one of them and am admitting it. I originally thought that the rear propeller shaft is longer and has bigger bolts so it needs to be torqued to higher settings. So I did torque it to 59 ft lbs instead of 52 ft lbs. When I was done and went inside my house and started thinking about what I did, I realized I messed up on the torque settings. So next day, I just went under with a breaker bar and loosened all the bolts and then re-torqued them to 52 ft lbs again. No issues here. This is just for people who can make mistake accidentally. It happens. Just correct it and move on.
  20. Jul 15, 2020 at 7:01 PM
    #50
    ErSlickEr
    MY SERVICING SCHEDULE (2018 Tundra 4x4 FFV 5.7L V8):
    Every 5000 Miles Service:
    Check All Fluid Levels
    Inspect Brake Pads and Rotors
    Inspect Wiper Blades
    Oil and Oil Filter Change
    Rotate Tires
    Oil/Filter: Every 5K
    Rotate Tires: Every 5K
    Re-torque propeller shaft bolt: Every 15K
    Cabin Air Filter: Every 30K (15K - if too dusty environment or if visible smell in cabin)
    Engine Air Filter: Every 30K
    Engine Coolant: Initial Replacement at 100K/120 months, Replace every 50K/60 months thereafter
    Spark Plugs: Replace 120K/144 months
    Drive Belts: Inspect at 60K/72 months. Inspect Every 15K/18 months thereafter
    Brake Fluid: Replace Every 36 months or 3 Years
    Idle Speed: Inspect Every 160K Miles
    Front Differential Oil(4WD): 15K/18 months if towing, hauling or driving on dusty or dirt roads
    Rear Differential Oil: 30K/36 months if towing, hauling or driving on dusty or dirt roads
    Transfer Case Oil(4WD): 30K/36 months if towing, hauling or driving on dusty or dirt roads
    Automatic Transmission Fluid: 60K/72 months if towing, hauling or driving on dusty or dirt roads
    For above four fluids (Front Diff, Rear Diff, Transfer Case, ATF), I have decided to change Every 60K/72 months Miles. I drive regular highway.
    I changed all the fluids at around 60K when I bought the truck (Truck was only 18 months old and had 57000 miles on it).
    Moving Forward, Next big oil service will be after 60K/72 months
    And then Every 60K/72 months after.
    Hope that helps other people!
  21. Jul 21, 2020 at 5:43 AM
    #51
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    This is something I don't understand,
    Front Differential Oil(4WD): 15K/18 months if towing, hauling or driving on dusty or dirt roads.
    I don't know about the rest of you, but when I am towing or hauling I only use 2WD never 4WD. The only exception to this would be if I somehow became stuck, (lousy boat launch) even then would only be in 4WD for a moment to get the truck out, then right back in 2WD. Otherwise only 2WD, so I don't understand the need for accelerated front differential fluid change when towing. Would seem to me the front differential is just rolling when in 2WD with no extra strain towing or not. Am I missing something?
    NUDRAT likes this.
  22. Jul 31, 2020 at 11:28 AM
    #52
    ErSlickEr
    I agree with you. I drive in similar fashion. However, I just finished my Front Differential Fluid Change and found a lot of gunk stuck on the magnet. Granted, I bought my truck used and was not sure if the previous owner did 2WD or 4WD. In any case, the front parts move, may be not under load and there may not be similar wear like if under load, but then there will be some wear anyways due to mechanical friction. This is also the reason why I will change all fluids next at after another 60,000 miles and see how the oil and the magnet looks. I already have photos of the current oil changes. If it looks bad, I will go back to normal intervals, otherwise will just stick with what I have written above.
  23. Oct 11, 2020 at 8:42 AM
    #53
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Anyone know the torque specs to the three transmission thermostat bolts?
  24. Oct 11, 2020 at 7:28 PM
    #54
    ErSlickEr
    Transmission oil cooler x Transmission oil cooler spacer or Transmission oil thermostat: 10ft lbs
    Transmission oil cooler spacer or Transmission oil thermostat x Automatic transmission: 5ft lbs
    Hope this is what you were looking for.
  25. Oct 11, 2020 at 7:41 PM
    #55
    I was told 15 pounds. Do you know where I can find this info?
  26. Nov 25, 2020 at 3:57 PM
    #56
    ErSlickEr
    I got it from a pdf file from website. Search for 2015 toyota tundra maintenance manual.
  27. Feb 26, 2021 at 6:39 AM
    #57
    dspilot
    dspilot Professional Nomad
    North Mississippi
    2019 SR5 4X4 Silver Sky Metallic
    Did you ever get an answer to this? I'm in the same boat.
  28. Feb 26, 2021 at 6:09 PM
    #58
    Bob_Wiley
    Eric
    AZ
    Negative
  29. Apr 12, 2021 at 1:25 PM
    #59
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    Bought my 2013 a few months ago with ~4500 miles, dealership changed the oil and replaced filters even though I asked all fluids be changed...Bastards
    Looks like brake fluid is the only service based on intervals for a 2nd gen as opposed to mileage. Im at ~7900 miles now, is there anything else I should do besides oil and brake fluid next?
    (Truck was driven once a week by a grandma to the dump, per dealership and looks to have been garaged)
  30. Apr 25, 2021 at 4:38 PM
    #60
    MXPCUS
    MXPCUS New Member
    Ken
    Southern IL
    2007 Tundra SR5
    Push bar and bed rails
